X1 Carbon Gen 9 (20XW, NM-D341) - EC never enables VCCCORE VR (IMVP_PMBUS_EN stuck low), 3s shutdown
  • unusual722
    • Oct 2025
    • 16
    I'm working on a ThinkPad X1 Carbon Gen 9, Type 20XW, board NM-D341
    BIOS 1.77 / N32ETA1W.
    Symptom: press power, fan goes 100% for about 3 seconds, then everything shuts off again. Headless bench test right now (no display, no battery attached). USB-C PD negotiates 20V fine, and the battery charges.
    Firmware first, because that's where I began. I read the U49. BIOS region was not corrupt it is byte-identical to a known-good
    image.
    The power tree checks out almost completely:
    - Suspend chain: VCC3_SUS 3.3V, VCC3_SUS_PWRGD 3.3V, VCC1R8_SUS 1.8V, V1R8_SUS_PWRGD_R 3V
    - VCCPCHCORE 1.8V (MP2941, VIN 12.3V, EN high). PCHCORE_PWRGD = 1.76V
    -> that comes off a 100k/100k divider from VCC3M. Is that actually the level the EC expects to see on this input?
    - SoC requests S0: SLP_S5#, SLP_S4#, SLP_S3# all deasserted during the 3 seconds (checked on scope)
    - VCC1R1A/1R8A/0R6A (TPS51487), VCCST / VCCSTG / VCCSTG_TERM ~1.05V, CPUCORE_ON 3.3V
    - VCCCORE VR: U257 MP2940A — VDD33 3.3V, VDD18 1.8V, EN (pin 21) 3.3V.
    Power stages are 3x MP86941, VIN 12.3V, VCC = VCC3M
    - EC (MEC1503) monitored inputs all present: VCC3M / VCC3B / VCC3SW / VBAT / VCC1R8_SUS, AC_PRESENT high, lid open, EC_THERM_MON0-5 all ~2.5V
    The one thing that never happens: IMVP_PMBUS_EN (EC GPIO254, pin F3) stays at 0V and is actively driven low, there is a 10k pull-up to VCC3M on that net. It goes to the PE pin (20) of U257. EN is high, so the controller is enabled, but the PMBus/protocol enable never comes.
    PWM1-3 just sit at ~1.5V static (scope confirms, no switching), no VCCCORE. Without VCCCORE there is no VCCIN for the dies, no VCCIO (that one is generated inside the package from VCCIN), no CPUCORE_PWRGD, and the SoC aborts after 3s.
    Things I forced:
    - PE high via 1k
    - TEMP (pin 26) high
    - SYSPWR_PRES&VCI_IN3#/TOP_SWAP_EN reads 0V natively, forced to ~2.9V
    - PCHCORE_PWRGD raised to 2.2V
    A couple of things I can't explain and would like to cross-check against a working board:
    - RSMRST# sits at 2.2V constantly. Shouldn't that be 3.3V?
    - BPWRG and EC_PWRREQ are 0V. No battery attached at the moment, is BPWRG supposed to go high on AC-only, or is it battery-related?
    - SYSPWR_PRES/TOP_SWAP_EN reads 0V. Normal?
    So the actual question: does anyone know what condition the MEC1503
    firmware wants fulfilled before it drives GPIO254 / IMVP_PMBUS_EN high? Could the 2.2V RSMRST# be the reason it holds off? Any hint is appreciated!
  • unusual722
    • Oct 2025
    • 16
    After removing U257 (MP2940), RSMRST goes to 3,3V.
    Does that maybe mean U257 is broken?
    • unusual722
      • Oct 2025
      • 16
      I have replaced the U257 with a known good one from another board, so it has the correct programming.
      But still the IMVP_PMBUS_EN is not getting high.
      I have measured U23 for voltages it should get, but somehow it will not enable IMVP_PMBUS_EN
      Any tips?
      • unusual722
        • Oct 2025
        • 16
        Just checked some more things:
        PCH and EC are not communicating with each other. No clock, no signals.
        But the BIOS Chip seems to be read, there is CLK, MOSI and MISO activity for about 242ms.
        So it looks like the PCH is doing something, and maybe it is still an BIOS image issue and I need to check again if I made a mistake here.
        • Fripatomik
          Acer Nitro 5 (LA-K862P Rev 1.A) - Dead CPU or shorted cap? (0 ohm on VCCCORE after PQZ3 failure)
          by Fripatomik
          I am troubleshooting an Acer Nitro 5 motherboard (LA-K862P Rev 1.A with RTX 3060 GN20-E3-A1).
          Initial state:
          • Laptop was totally dead due to a blown High-Side MOSFET (PQZ3).
          • An NVMe SSD connected to the board was getting abnormally hot during early tests.
          Current state & steps taken:
          1. Replaced PQZ3. Both 16MB Main BIOS (UV2) and 2MB VBIOS (UV10) have been re-flashed with clean binaries.
          2. The board now powers on (blue LED, fans spinning, keyboard backlight), but stays in a NO-POST state (black screen, no Caps Lock response).
          3. Isolated the CPU
          08-24-2026, 03:37 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
        • RMKyle
          Lenovo Thinkpad X1 Carbon Gen 9 (20XW) - Not working after backlight fuse replaced
          by RMKyle
          I have a Lenovo Thinkpad X1 Carbon Gen 9 (20XW) and it had no backlight. I saw the backlight fuse (F7) was blown so I replaced it with a known good fuse. Then the device does not power on at all and I get no charge light. I removed the backlight fuse and it went back to how it was, working but with no backlight. Replaced both F3 and F7 and still same issue, no power no charge light.
          Any one got any ideas what could be causing this?
          If you need any specific details I will try my best to answer.
          Attached image of the sticker on the board...
          04-02-2026, 10:09 AM
        • myth77
          acer la-e921p dramrst missing but vcccore present!?
          by myth77
          This laptop came with problem turning on, no picture. PU1401 was getting hot and shorted on NVVDDS_BST1 line. After replacing all was ok on first...i have every voltage, even vcccore, but no picture...then i noticed that dramrst was only 0.07 Vol. First, i dont understand how it is possible to have vcccore without dramrst!? tried with two different bios but the same, signal DDR_DRAMRST# only rises to 0,07V. plt_rst is ok. I tried three different ram sticks. Any ideas?
          boardview and schmetic attached...
          01-23-2023, 01:08 PM
        • battery.12v
          Asus G512LI VCCCore raise and drop
          by battery.12v
          Hello guys, Asus G512LI, came with 3.3V drop down immediately .... 5V was stable ... after search and work found that +3VSUS_MUX is the issue (caused by U4701A TUSB1146RNQR) , left off the ic .. 3.3V came up again stable ... after power on laptop turn on for 3 seconds and power off ... VCCcore raise 0.9V for 1.5 seconds and drop down all other voltages do same thing ... Ram voltage , Gpu voltages, concerning VCCGT 0V all the time
          05-03-2024, 03:43 AM
