using none genuine charger for Acer
  • paparazzo79
    • Dec 2018
    • 360
    • Bosnia
    Hi guys.
    I got myself used Acer Predator 17 G5-793 which came with none genuine charger (pic below).
    Any issues I could come across using such charger?
    Voltage is okay.
    What is the worse case scenario that could happen using such charger?
    As you see on pic there is no even who made the charger.
  • mon2
    • 16638
    It *may* be ok but you are truly at the mercy of the mfr of this non-descript adapter. There are reports of designs where the adapter contained a lower power adapter under the shell of the device. Monitor this adapter for heating or excessive heat during use. If too hot, avoid using this adapter. On this note, the adapter may be ok to use but the vendor did not seek out the expensive safety certifications like ETL / CSA / cUL, etc. If the adapter has real certifications (not photo shopped stickers) then you have a 3rd party approval that the adapter is capable of supporting the heavy currents as listed. Worst case if too hot, the adapter can burn out or cause a fire. Tons of these on Amazon for sale.
    • paparazzo79
      • Dec 2018
      • 360
      • Bosnia
      Yeah, the adapter gets very very hot during use.
      Can it damage the laptop in some way, during use?
      I don't have alternative since genuine at this spec can not find here, and amazon does not ship to Bosnia.
      • paparazzo79
        • Dec 2018
        • 360
        • Bosnia
        Found this one, selling even in my city.
        This one okay?
        • mon2
          • 16638
          DO NOT use the adapter that is running hot. It is obviously a fake and has a lower power adapter internals but the stickers are for the higher current. Scummy.
          Yes, like the ACER branded unit which appears to be the real deal. As long as the DC adapter tip mates with your unit, you are good to test this unit.
          • paparazzo79
            • Dec 2018
            • 360
            • Bosnia
            Hmm., but my model of laptop is not listed judging by this
            https://www.ebay.com/itm/286795356077
            Compatible Model(s): Acer Aspire V15 Nitro Series: VN7-593G-738X VN7-593G-73KV VN7-593G-76SS VN7-593G-57NE VN7-593G-59F9 VN7-593G-73HP VN7-593G-742C VN7-593G-73E7 VN7-593G-786F VN7-593G-79L1 VN7-593G-70U4
            Acer Aspire V17 Nitro Series: VN7-793G-717L VN7-793G-71AG VN7-793G-719P VN7-793G-741P VN7-793G-709A VN7-793G-758J VN7-793G-722D VN7-793G-52XN VN7-793G-5811 VN7-793G-738J VN7-793G-79MN VN7-793G-53K5
            Acer Predator Helios 300 Series: G3-571-77QK G3-571-51NK G3-572-78JY G3-572-7526 G3-572-73FH G3-572-72YF G3-572-72MT G3-572-795X G3-572-770 PH317-51-70KH PH317-51-78SZ PH317-51-787B PH317-51-75GZ PH317-51-77QK
            Is the jack/tip same size and shape?
              • 24922
              Man, you have a pair of eyes , look at the tip of the cheap nasty one compared to the ebay one are they the same or different... does the non genuine shitty one have a big 7.4mm X 5mm barrel like this one
              Click image for larger version  Name:	Screenshot 2026-09-02 142554.png Views:	0 Size:	106.7 KB ID:	3928386
              • paparazzo79
                • Dec 2018
                • 360
                • Bosnia
                A guy who has genuine Acer Adapter contacted me, and tomorrow I will try if tip fits, because
                I am confused, if the tip is the same and will be compatible with my Acer Predator G5-793-7108, because on e-bay site, my model of the laptop is not listed under compatible models.
                Why is that?
                He measured his tip is 5.5 mm but required is 5.0 m.m, correct?
                Could that make a difference?
                Yeah, the replcement adapter has big tip too.
                • paparazzo79
                  • Dec 2018
                  • 360
                  • Bosnia
                  Friends,lets try to short this out:
                  Will his adapter (the one I posted pictures above) be okay to use for my laptop Acer Predator 17 G5-793-7108,and will it fit?
                  • paparazzo79
                    • Dec 2018
                    • 360
                    • Bosnia
                    Mate, if his adapter is in some way malfunctioning, can it damage my laptop?
                    • mon2
                      • 16638
                      Anything is possible and is too risky to use. Under stress, the adapter can leak out the wrong voltage and cause the motherboard (at least the DCin mosfets) to be damaged. Seek out the proper adapter from Acer for this unit. Ebay may have som good finds. I know that we scored some real Dell heavy duty adapters for almost the same price as the copycat fake ones not too long ago. Acer units should be up there as well.
                      • paparazzo79
                        • Dec 2018
                        • 360
                        • Bosnia
                        I am affraid I don't have anymore solutions then these 2:
                        1. Either ti keep using replacement adapter which is very very hot during use.
                        2. Purchase used genuine Acer adapter from online seller in unknown condition and use that one.
                        • mon2
                          • 16638
                          Review the adapter you have already and post a clear pic of the end adapter connector that mates with the logic board. It should have a needle like center pin.
                          • paparazzo79
                            • Dec 2018
                            • 360
                            • Bosnia
                            Okay, here:
                            • paparazzo79
                              • Dec 2018
                              • 360
                              • Bosnia
                              Nope, his adapter does not fit..
                              His tip is a lot smaller in diameter and his adapter does not have this "needle" in the middle, like my replacement one has.
                              He also told me that it will be tough to find such genuine adapter.
                              • mon2
                                • 16638
                                Found on Aliexpress. Seller is stating it is the original and has shared pics.
                                From the linked vendor:
                                Click image for larger version  Name:	pic2.png Views:	0 Size:	348.9 KB ID:	3929015
                                Click image for larger version  Name:	pic1.png Views:	0 Size:	476.4 KB ID:	3929014
                                https://www.aliexpress.com/item/1005...origin_prod%3A
                                • paparazzo79
                                  • Dec 2018
                                  • 360
                                  • Bosnia
                                  I never ordered over aliexpress, nor do I know if it is possible, will check on that.
                                  Until then, what can I do with replacement one during use, since it is heating up very much to the point yoi can not hold hand onto it??
                                  Maybe make breaks during use, shutdown laptop for 10-15 min then turn back on again???
                                    • 24922
                                    https://www.aliexpress.com/item/1005012866988404.html
                                    It doesn`t say in the description that it`s a genuine acer charger it only says Original AC Adapter Charger , here`s where the wording is sly . The Acer (or Delta?) writing on the label is blanked out as well at the listing on ali. This one on Amazon is a compatible charger https://www.amazon.co.uk/ADP-180MB-A.../dp/B0DSPKPCCJ , similar fake Delta label .
                                      • 24922
                                      Keep a fire extinguisher next to it
                                      • mon2
                                        • 16638
                                        The vendor has shared a short video of the product and has confirmed the adapter is the Acer brand OEM adapter.
                                        • rsa4092
                                          Acer Nitro 5 - AN515-54-52PY - LA-H501P - low voltage on ASGATE, no power from charger on +19VB
                                          by rsa4092
                                          Hello, I’m having a problem with my Acer Nitro 5 laptop, which has a Compal LA-H501P motherboard.
                                          Initially, the CPU power regulator was replaced because the computer shutdown unexpectedly, and couldn't be turned on, the service centre diagnosed a short circuit in the CPU power regulator, replaced it and laptop was working. After about two months, a new problem arose – the laptop would shutdown under heavy load, even when connected to charger. In addition, the battery was charging very slowly – or rather, discharging – despite...
                                          06-23-2026, 06:00 AM
                                        • reessi
                                          Acer Aspire E1-571 - (LA-7912P Motherboard) - Garbled Multi-coloured dots or lines on Image when removing charger!
                                          by reessi
                                          Often but not every time when I remove the charger the picture will instantly go garbled with random multi-coloured lines or dots. It has to be forced off and rebooted.
                                          Tested with other known working LCD and RAM and CPU so ruled these out.
                                          The GPU is integrated in the CPU.
                                          I've never seen it do it on the charger only on the battery. If I boot it from the battery and wait a while sometimes it will suddenly do it.
                                          Always works perfectly with the charger!
                                          All board voltages appear normal including the CPU / GPU ones (1.1v and...
                                          05-28-2026, 01:25 AM
                                        • Boardview and Schematic Bot
                                          09-06-2024, 05:27 AM
                                        • Trademark
                                          Acer Predator Triton 16 PT16-51-99GL (DA0ZQDMB8AE Rev. E) - Looking for original 32MB BIOS dump (Winbond W25Q256JVEN)
                                          by Trademark
                                          I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
                                          This is NOT a BIOS password removal request.
                                          I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
                                          Laptop Information
                                          • Model: Acer Predator Triton 16 PT16-51-99GL
                                          • Motherboard: DA0ZQDMB8AE Rev. E
                                          • Main SPI flash: Winbond W25Q256JVEN (32MB)
                                          • Secondary
                                          07-22-2026, 08:57 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
