Macbook Air 15.3 A2941 won't turn on and power cycles
  • mgollob7
    • Aug 2026
    • 7
    • Austria
    I’m new to board level repair, so apologies if I’m missing something obvious.
    I have a MacBook Air 15.3” (A2941) that won’t turn on. No keyboard, no trackpad. It does show up in DFU mode using a DFU Blaster Pro. On all ports it power cycles between 5V and 18V.
    I’ve attached a video of the cycling and a screenshot of the DFU Message
    Any idea where to start looking, or what I should measure first?
    Thanks!
  • mon2
    • 16638
    What is the voltage to ground of PPBUS_AON?
    • mgollob7
      • Aug 2026
      • 7
      • Austria
      PPBUS_AON is not stable: with the charger connected it ramps up to ~12.3 V, collapses to 0 V and repeats. The light on the magsafe charger flashes orange in sync.
      • mon2
        • 16638
        Flux and remove the fuse(s) linked to the PPBUS_AON. This is to isolate the regulator from the downstream consumer side.
        Then power up again. Is PPBUS_AON on the regulator side stable or still power cycling?
        • mgollob7
          • Aug 2026
          • 7
          • Austria
          On the 15” board there is no fuse on PPBUS_AON — the charger output cap bank sits directly on the rail, nothing in between. So I can’t isolate the regulator by pulling a fuse. What should I lift instead Or did i miss something?
          • mgollob7
            • Aug 2026
            • 7
            • Austria
            Update — a lot of measurements since my last post. No short found, and I’m now stuck at interpreting the behavior.
            What I measured:
            • Diode mode on PPBUS_AON: 0.5 to ground at the tantalum bank and at U5700 VIN, same everywhere. No short found on the rail.
            • On a 5V USB 2.0 supply, U5200 boosts PPBUS_AON to a stable ~12.3V and holds it.
            • PP3V8_AON stable at 3.8V the whole time.
            • DFU mode works: device enumerates, ECID reads, both Apple Configurator and DFU Blaster Pro identify it as Mac14,15.
            • Every restore attempt fails at the same point though. Configurator: “The device is not connected”. DFU Blaster: “error restoring the device with status 1” right after _AMDFUModeDeviceFinalize, then it retries.
            Rail behavior during restore (measured live):
            The NAND rails (PP2V58_AWAKE_NAND_VCC from BUCK6/L7760, PP1V25_AWAKE_NAND_VCCQ, PP0V88_AWAKE_NAND_VDD, PP1V2_NAND0_S5E0_PCI_AVDD_H — 1.26V measured) come up during the early restore steps and hold stable for a few seconds. When the restore reaches the later step, they go down and the cycle repeats. PPBUS and AON stay up through all of it.
            Also noticed: without DFU, the board power cycles on every power connect (the 5V–18V cycling from my first post). In DFU it sits quietly until a restore runs.
            Board is the 256GB config, single NAND (UN000 only, UN100 not stuffed).
            Where I’m at: Supply side looks healthy to me, and the failure seems tied to the point where the NAND gets involved — but I’m not sure how to read this. Is this pointing at the NAND itself / BGA joints, or is there something else that gets enabled at that stage that I should check first? What would you measure next before considering a reflow on UN000?
            • ed-service
              • Mar 2026
              • Украина
              I had an A2991 that wouldn't turn on and would flash orange when the charger was connected; the problem was the battery.
              • ed-service
                • Mar 2026
                • Украина
                I fixed the battery, and the MacBook turned on.
                • mgollob7
                  • Aug 2026
                  • 7
                  • Austria
                  Okey thank you I will try that
                  Did it Turn on without the Batterie connected ?
                  • ed-service
                    • Mar 2026
                    • Украина
                    No
