HP Pavilion x360 – No power / no boot, voltages and resistances match a working board
  • woodboy971
    • Dec 2025
    • 9
    • guadeloupe
    I'm looking for some help with an HP Pavilion/Envy x360 14 motherboard.
    Board reference: Nittany RPL 8L / 213224-1Q / 448.0T404.001Q
    The motherboard does not power on.
    I have another working motherboard with exactly the same board reference, so I can compare both boards directly.
    Here is what I have done so far:
    • Compared resistance to ground on the main power rails between the working and faulty boards. The values are similar and I found nothing abnormal.
    • Compared the main voltages between both boards. They also seem similar.
    • Checked the 3.3V and 5V LDO outputs.
    • Checked the input/charging circuit.
    • Replaced the charging IC on the faulty board, with no change.
    • Read the SPI BIOS several times with an RT809HSE. All dumps are identical.
    • Dumped the BIOS from the working motherboard.
    • Flashed the complete BIOS dump from the working board onto the faulty board and verified the write successfully.
    Unfortunately, the faulty board still does not boot, even with the BIOS from the working board.
    At this point, the resistances and voltages I have checked are very similar between both boards. Replacing the charging IC and flashing a known working BIOS made no difference.
    What would you recommend checking next in the power-on sequence?
    Thanks for your help.
