ASUS Zenbook 13 Laptop UX333FN Need Help with SMD Capacitor Identification
  • jkucukov
    • Feb 2025
    • 73
    I have a ASUS Zenbook 13 UX333FN motherboard that I need to replace a SMD capacitor. This SMD capacitor is located on the back side of the motherboard and is really small (C0201), however I need to find the specs of the capacitor (Voltage rating and Capacitance).
    I was fortunate to find Boardview file for however all I was able to get from the file is the Capacitor reference designator (C6353), here is the information: Click image for larger version
    How would I be able to get Voltage rating and Capacitance of the SMD Capacitor?
    Thanks,
  • mon2
    • 16795
    Pick a voltage to exceed the power adapter voltage. Suggest for 25V or higher. For the capacitance, study the charger IC that is onboard and review other reference schematics and/or datasheet if available for that part. Share the topside markings of the charger IC for more details.
    • jkucukov
      • Feb 2025
      • 73
      The closest chip is this RMC ALC3288, I’ve circled the capacitor in red, the capacitor is currently canted where one leg is not touching.
      • jkucukov
        • Feb 2025
        • 73
        What I've been unsuccessful with this whole time is to find a datasheet for the IC chip, ITE IT8225VG-128.
        Could somebody help me with the data sheet for it?
        Thanks,
        • schematic_archiver
          admin
          • Jul 2023
          • 232
          more of an ic pinout than a datasheet but hope it helps
          • jkucukov
            • Feb 2025
            • 73
            I’m still up against the wall on this SMD capacitor capacitive rating. So far what I know is it’s grayish white in color, C0201 size format, rated for 25V. Some say the color makes it out to be in picofarad range, could somebody help me with the capacitance rating please.
            • mon2
              • 16795
              As per post #2, which charger IC is onboard? Are you confident that this cap is sitting on the ac_bat_sys line? This signal is linked to the charger ic. Suspecting the size to be 0402 and not 0201 which is common to cell phones. If on this signal, could be 10uf 0402 25v ceramic. Suggest X5R or X7R type. Review the other side of this pcb which may have the charger ic. Also be sure to flux and clean this cap are to confirm that there are no shorts under this part.
              • jkucukov
                • Feb 2025
                • 73
                I may have been mislead with the C0201 from the Boardview file. The IC charger is the IT8225VG-128 it sits on the back side of the board near the battery connector.
                There was another post with the same exact motherboard and the same exact SMD capacitor that the guy was replacing: Asus VivoBook UX333FN boardview needed - Badcaps
                • mon2
                  • 16795
                  No. This is the EC. Post pics of the board of square black body chips. Guessing it is the TI BQ series charger IC.
                  What is the IT8225VG-128?
                  • Type: It is a Super I/O and Embedded Controller (EC) integrated circuit.
                  • Usage: Manufacturers like ASUS use it in modern laptops to manage power, keyboards, and fan speeds.
                  • Secrecy: ITE keeps technical documentation and pinout diagrams confidential, meaning technicians rely on reverse engineering and community notes.
                  • mon2
                    • 16795
                    Would love to take Asus, Apple and a few others into the Squid Game. Them and their secret private labelled parts…
                    • jkucukov
                      • Feb 2025
                      • 73
                      Thank you, I’m learning something new every day. Took me some time to screen the board and locate the BQ chip, here is the attachment on the front side of the board circled in red. The chip reads BQ 24780S TI 8BIClick image for larger version  Name:	IMG_0650.jpg Views:	0 Size:	1.32 MB ID:	3927620
                      • jkucukov
                        • Feb 2025
                        • 73
                        From reviewing the Boardview schematic the capacitor isn't tied to the BQ chip, instead its tied to the chip called APW6002 power management IC chip.
                        Here is the capture of the APW6002
                        No luck finding datasheet of this IC chip
                          • 25687
                          No datasheet but there are 2 of those APW6002 chips in the Asus TP401CA schematic https://www.badcaps.net/forum/troubl...01ca-schematic
                          Which one of those pins is that cap connected to .
                          • jkucukov
                            • Feb 2025
                            • 73
                            according to the boardview it’s tied to 21, 22, 23, 24, and 33. All of them are AC_BAT_SYS.
                            • jkucukov
                              • Feb 2025
                              • 73
                              Anyone with the ability to look up the capacitance for the capacitor I need to get, thanks
                                • 25687
                                1uF 25V or 10uF 25V
                                • jkucukov
                                  • Feb 2025
                                  • 73
                                  1uF 25V or 10uF 25V
                                  Sorry it took me a while to get back to you, I did finally got around and took a close look at the diagram you shared last month, I come to find that those 3 referenced caps are close to the APW6002 chip, in this diagram below: Click image for larger version
ID:	3942191These seem much larger caps compared to the one in the back of the board that I'm after.
                                  I think from looking at your diagram it appears that these caps are siting on the P_DDR_VIN_S rail and perhaps the other the one im after sits from the AC_BAT_SYS node to ground, I dont know I'm just throwing that out. There are at least dozen of these caps sitting on the AC_BAT_SYS to Ground.
                                  • Boardview and Schematic Bot
                                    ASUS ZenBook UX333FN-A3153TS Notebook 13 Specification for Upgrade or Repair
                                    This specification for the ASUS ZenBook UX333FN-A3153TS Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX333FN-A3153TS boardview and UX333FN-A3153TS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                    09-06-2024, 12:36 PM
                                    ASUS ZenBook UX333FN-A3214R Notebook 13 Specification for Upgrade or Repair
                                    This specification for the ASUS ZenBook UX333FN-A3214R Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX333FN-A3214R boardview and UX333FN-A3214R schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-06-2024, 11:39 AM
                                    ASUS ZenBook UX333FN-A3215R Notebook 13 Specification for Upgrade or Repair
                                    This specification for the ASUS ZenBook UX333FN-A3215R Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX333FN-A3215R boardview and UX333FN-A3215R schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    ASUS ZenBook UX333FN-A3110T Notebook 13 Specification for Upgrade or Repair
                                    This specification for the ASUS ZenBook UX333FN-A3110T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX333FN-A3110T boardview and UX333FN-A3110T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-06-2024, 12:10 PM
                                    ASUS ZenBook UX333FN-A3067T Notebook 13 Specification for Upgrade or Repair
                                    This specification for the ASUS ZenBook UX333FN-A3067T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX333FN-A3067T boardview and UX333FN-A3067T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-06-2024, 12:08 PM
