Toshiba c660-15g no display on screen but have display on external
  • infotech1321
    • Dec 2013
    • 9
    • Saudi Arabia
    good day sir what is the problem of the laptop with no display on lcd and have on external.
    i check lcd its working on other laptops and lcd cable..
    thanks in advance..hope you can help me...
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: Toshiba c660-15g no display on screen but have display on external
    board model?
    • infotech1321
      • Dec 2013
      • 9
      • Saudi Arabia
      MB model - PWWAA LA-6841P
      REV: 1.0
      LA-684 SIR...
      • highpulse
        i hate HP
        • May 2013
        • 1490
        • portugal
        chek altough if the image on your laptop with the original screen , isn't on the background ( also chek for lvds signal , such as 19volts line , and enables line 3.3 v
        after that we can carry on more tests
        • Topher_UK
          • Feb 2014
          • 19
          • Northern Ireland, UK
          Shine a torch on the laptop screen while it is switched on, preferably in a darkened room, to see if there is a faint picture there. If so, but the screen works on other laptops, then I would query the inverter board (if it's LCD) or the backlight controller chip on the motherboard.
          If there's no display at all, make sure you haven't set the laptop to display to external screen only
          • highpulse
            i hate HP
            • May 2013
            • 1490
            • portugal
            chek in the lvds connector , what are the voltage value for the following pins.
            pin 1 10 12 20 22 24 and 28
            • teknikbursa
              • Sep 2014
              • 64
              • turkey
              Same problem with hp G62 and after programming bios with programmer
              its ok,So pls try bios programming first
              • JaYmEz
                • Nov 2014
                • 21
                • Portugal
                highpulse, i have a Toshiba C660-1LX with the same problem, no display on LED screen but the LED backlight is on. On external screen everything is OK.
                Motherboard: LA-6841P rev. 1.0
                Here are some of the voltages on JLVDS conector:
                Pin - Voltage
                1 3,2v
                10 3,2v
                12 3,2v
                20 3,2v
                22 3,2v
                24 3,2v
                28 19,2v
                thanks, hope you can help me! =)
                • dj_ricoh
                  • 2073
                  Pin - Voltage
                  1 3,2v
                  10 3,2v
                  12 3,2v
                  20 3,2v
                  22 3,2v
                  24 3,2v
                  28 19,2v
                  i fix yesterday a compaq c700 same problem backlight on, on internal and video on external reflow did the trick!
                  P.S. Celeron CPU LOL
                  • JaYmEz
                    • Nov 2014
                    • 21
                    • Portugal
                    Just did a reflow on the GPU and the problem continues the same, no change. It just turns on the backlight and no post, if i plug an external monitor it posts OK
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3628
                      • slovakia
                      replace igp
                      • FShahid
                        • Nov 2012
                        • 57
                        • United Kingdom
                        I know it's too late to post on this topic, but I want to share the experience to help others. I was replacing the 15.6 LED screen on C660D-10F (AMD) but after the replacement it wasn't showing the backlight on it (display comes but no light), tried the old screen again but same issue (however whenever I switch it off it did flicker backlight briefly before turning off).
                        Read this topic and did the reflow of AMD IGP and to my surprise the backlight works again.
                        • dlshad96
                          • Apr 2016
                          • 39
                          • Us
                          i have same problem with 3 laptops
                          L530
                          C660
                          E520
                          have backlite no video ( in internal LED 15.6")
                          working well in external screen!!
                          Could any one please give me help
                          • dlshad96
                            • Apr 2016
                            • 39
                            • Us
                            i know its too late for this But i have same problem but the V on pin only 3.3v and 19v others pins no V at all (0) what i have replace please
                            anu help please
                            Thanks you in advance
                            • plyanthony
                              Razer Blade 15 no external display with attached screen disconnected from motherboard
                              by plyanthony
                              Computer in question : Razer Blade 15 2020 Base Model
                              Model# RZ09-03286E22
                              BIOS CHIP: WINBOND W25Q128BV
                              What I'm trying to accomplish:
                              I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
                              What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
                              W/Stock BIOS - 1.06:
                              Disconnect the...
                              02-01-2023, 09:35 PM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • ArchangelGabriel
                              Aorus 17G YD laptop, broken display, could not switch to external monitor
                              by ArchangelGabriel
                              Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
                              11-23-2023, 03:55 AM
                            • DqMagetz
                              Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                              by DqMagetz
                              Good day!
                              I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                              Here are the voltage readings:
                              • Input – 19V (stable)
                              • +LCDVDD – 3.3V briefly, then drops to 0V
                              • EDP_HPD – 3.3V briefly, then drops to 0V
                              • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                              • EC BKOFF# – 1.8V briefly, then drops to 0V
                              • PANEL_OD_EN – 0.3V
                              Is it possible that the EC chip is corrupted or damag...
                              07-12-2025, 09:37 PM
                            • sikocan
                              Razer Blade 15 Gaming Advanced RZ09-0421 Laptop - No Display, External Screen Only
                              by sikocan
                              Hello Colleagues,
                              I'm dealing with a perplexing issue on a client's laptop and would appreciate your insights. The user experienced a sudden screen blackout during regular use (not gaming), although the laptop continued to operate normally otherwise, with music playing and indicator lights active. An external display connected via HDMI works fine, indicating the display itself is functional. The device manager shows the Intel XE GPU as disabled, with Windows reporting a related error, while the NVIDIA RTX GPU operates without issues, even supporting gaming.
                              Upon inspection,...
                              11-28-2023, 12:14 AM
