HP Envy 13m-bd0023dx forget unplug battery now display blank
  • virtue
    • Jan 2023
    • 5
    • Indonesia
    HP Envy 13m-bd0023dx forget unplug battery now display blank, before display was working normal, i release and attach the display cable without removing laptop battery
    some friends say i blew up the display chipset
    does someone here had same experience? may can share some tips on fixing it?
    i just hope that i blew come caps, and can fix it, becasue i open it up just to change the LCD, already bought the new LCD also...
    greatly appreciate your opinions guys...
    thx
  • virtue
    • Jan 2023
    • 5
    • Indonesia
    this is what the socket looks like
    • mon2
      • 16628
      Can you confirm that you see ‘LA-K261P’ silkscreened (white text) on the motherboard?
      This will assist us to find the correct schematics for your board.
      • virtue
        • Jan 2023
        • 5
        • Indonesia
ID:	3906420 GPT32 LA - K261P
        • mon2
          • 16628
          Does the unit turn on? Any sign of life?
          What is the voltage to ground of +20V_CHG? This is the main power rail. This is to confirm that the power adapter is passing the voltage onto this main power rail through the DCin mosfets.
          • reformatt
            • Feb 2020
            • 1760
            Check continuity of FU2
            • virtue
              • Jan 2023
              • 5
              • Indonesia
              i check FU2 it was ok good continuity,
              i use usb C to HDMI still can get image/displaying windows normally on external monitors
              • mon2
                • 16628
                Confirm the voltage to ground of RV19 = pin #1 on UV1. This LDO is required to output 3v3 to power the LCD display assembly. Suspecting that this regulator has failed since the backlight fuse is ok. The fuse should be ~0R ohms if ok.
                Click image for larger version  Name:	edp.png Views:	0 Size:	59.2 KB ID:	3907169
                Also test the voltage to ground of the DISPOFF# signal. If this voltage is low = 0V, then the display will remain OFF. Vice-versa, require a voltage to enable the display panel.
