HI everyone, I'm new here, so please tell me if I'm doing something wrong.
I bought a Gigabyte Aero 15 OLED model YB from ebay, spares and repairs, after talking to the seller and realising it ~mostly worked. Issues he pointed to:
- SSD intermittently cuts out, leading to booting to Windows Recovery Environment
- Battery doesn't work at all, possibly swelling
I have since realised a key piece was missing: this thing was dropped at one point. The location of the drop seems to have been the GPU side heatsink. The SSD was faulty and the battery isn't detected (but not swelling), but more concerningly, once I freshly installed Windows on a little test drive, many parts were not being detected. On opening it up to take apart and diagnose, one capacitor was loose, and came off in my hands with basically no force, accidentally, while removing the CMOS.
Original specs/model number:
Gigabyte Aero 15 OLED YB 10th gen
i9 10980HK
RTX 2080 Super Max Q
64GB DDR4 3200MHz (But I'm pretty sure the slots max out at 2933)
Pantone certified 4k HDR OLED panel
You can see why I want to fix this, it was basically top of the line at launch! But, I did buy it with the expectation I'd learn something about repair, and have fun.
Motherboard model/rev:
GA-RP75YB Rev 1.1
It also says: "Assem: A0-11C" which I presume to be a factory code? But, you can know, anyway, in case it isn't.
The missing parts, in Windows:
- The GPU was totally undetected
- The wifi card did not work, but sent enough information to Windows to show up as a PCI Device, with an intel HW ID. Bluetooth was detected, and functional, which I understand is on the same card, but not the same rail?
- Ethernet did not work and was undetected.
What did work:
- USB ports, keyboard
- Bluetooth, as previously mentioned
- The CPU
- The panel
- The replacement drive, in both NVME slots
- Speakers
What I did not/could not test:
- USB C port
- HDMI port
- SD Card slot
- Headphone jack
- Mini DP
The Capacitor that fell:
It's labelled an M96H 15 25V, from a spot labelled 3CL2, it seems to be upstream of a MOSFET, and then a MAGIC 3R3, but I don't actually know much about this, so I could be totally wrong.
What I'd like to know:
- First, any schematics would be totally appreciated! I found on the site some for related models, but none for specifically rev1.1 or model YB. I'm not sure how intercompatible these are? Considering mine says rev 1.1, probably it's not so reliable.
- I'm going to buy a replacement capacitor, what are the chances it's responsible for powering some sort of PCIe controller, leading to issues with a number of such devices?
- Since I'm pretty sure the GPU will have a direct line to the CPU, there should be some form of damage near it, and this particular capacitor is not. There is an empty... Diode? spot labelled Q1100, upstream of the GPU's VMUs, that could easily have been knocked off in the drop. Does anyone know what kind of part this would take? I've checked in the case and delivery packaging, and there's absolutely nothing rattling around, so I don't have this thing, whatever it was.
I can easily sub in new drives, replace batteries, or just run it on mains. I'm just looking for help getting started on trying to repair this myself! I have some very minor experience soldering onto laptop motherboards, but I'm still definitely a total newbie.
Any help welcome! I can post pics if anyone wants, too.
i9 10980HK
GA-RP75YB Rev 1.1
What did work:
- The CPU
- The panel
- Speakers
- USB C port
- HDMI port
- SD Card slot
- Headphone jack
- Mini DP
