Lenovo YOGA 7 14ACN6 Stuck in Tablet Mode
  • sotya2003
    • Jun 2023
    • 12
    • Surabaya
    hi newbie here, touchpad and keyboard not working when os start to boot, still work on bios, i need to know which sensor causing tablet mode. thx
  • mon2
    • 16628
    To fix your Lenovo YOGA 7 14ACN6 stuck in tablet mode, first try toggling the Rotation Lock in your Windows settings. If that fails, uninstall the Intel Precise Touch Device in Device Manager to force a driver reset. Finally, clean the hinges gently to clear any trapped dust or debris. [1]
    1. Toggle Rotation Lock and Tablet Settings
    Windows 2-in-1 laptops use internal sensors (like accelerometers) to figure out when you flip the screen. An accelerometer is a tiny sensor that measures how fast and in which direction your computer is moving or tilting.
    • Go to Settings > System > Display.
    • Find Rotation Lock and turn it On (or Off, and then back On).
    • If you are running Windows 10, go to Settings > System > Tablet. Under the "When I sign in" section, select Use desktop mode. [1, 2, 3]
    2. Update or Reinstall Sensor Drivers
    Sometimes, the software that talks to your hinge sensor gets confused. Rebuilding this connection fixes it. [1]
    • Right-click the Start button and select Device Manager.
    • Expand the Sensors section.
    • Right-click HID Sensor Collection V2 (or your specific hinge sensor) and select Disable device. Wait a few seconds, then right-click again and select Enable device. [1]
    • If this does not work, right-click the sensor, choose Uninstall device, and restart your laptop. Windows will automatically reinstall a fresh copy of the driver.
    3. Clean the Laptop Hinges
    Your laptop disables the keyboard and touchpad based on physical sensors located near the 360-degree hinges. If dust or dirt gets stuck inside, the laptop thinks the screen is folded all the way back even when it is standing upright. [1, 2]
    • Gently clean out the small gaps around the hinge area using a dry, soft-bristled brush or a can of compressed air. [1]
    • sotya2003
      • Jun 2023
      • 12
      • Surabaya
      none of that works, but orientation sensor just work fine using sensor app from mstore, there is any chance something causing touchpad and keyboard got disabled by system after boot?
      • reformatt
        • Feb 2020
        • 1760
        Serial IO drivers installed? Sensors for tablet mode on wrap around Yoga's are usually within the display. Need to list the motherboard part number to check.
        • sotya2003
          • Jun 2023
          • 12
          • Surabaya
          all driver installed with no issue, only stuck in tablet mode in every os like windows, linux or any os. Only work in bios and simple os like MemTest86.iso .here the board number
          • reformatt
            • Feb 2020
            • 1760
            Schematic only available on paid sites, but boardview is available. There are two sensors listed on the EDP connector, LID_360_SW_N and LID_0D_SW_N. Both are pulled high to +3VL_EC so assumption is that sensors are in display and pulls these lines low when activated by a magnet in the lower case. One will be for lid close, the other for tablet mode. Check RE32, LCD cable and the sensor itself. Don't know if the LCD assembly can be easily disassembled on this model.
            • sotya2003
              • Jun 2023
              • 12
              • Surabaya
              already open the lcd, got the sensor beside webcam, try to disconnect the flex cable that goes to webcam, and yea sensor not working like orientation mode, but... it keep disabling keyboard and touchpad right when windows loader animation show up. i found the LIS2DWLTR ic under IT8300FN ic, could be thats the problem? is that okay to lift it up with hot air gun? no worry i have skill using it, just need a clue what happen here 🙃
              • reformatt
                • Feb 2020
                • 1760
                From the boardview, I don't see how that IC is related so I am not following your logic. What is the voltage at RE32/RE56? To me, this is a logic low if the tablet mode sensor is triggered.
                In WIndows 10, there used to be a button in Action centre to display whether it was in tablet mode or not, but it's been removed in Windows 11 and the function is automatic. You might try installing Windows 10 to confirm the issue is indeed Windows converting to tablet mode before you go down a rabbit hole.
                I note there is also a tool for Yoga laptops called 'Lenovo Yoga Mode Control Application for Windows 11' which according to Reddit provides a solution to it getting stuck in Tablet mode. You might try installing that.
                • sotya2003
                  • Jun 2023
                  • 12
                  • Surabaya
                  heres the result, idk why its a bit different from boardview, even though its the same board number
                  • reformatt
                    • Feb 2020
                    • 1760
                    Boardview is correct, RE49, RE56, RE77, RE52 are 0 ohm and are just copper pads on the board instead.
                    RE32 is a 100K pullup to +3V for the LID_360_SW_N logic line. If it's low, the machine will be in tablet mode I would surmise. So the problem is either the sensor is faulty in the lid or a damaged LCD cable.
                    • sotya2003
                      • Jun 2023
                      • 12
                      • Surabaya
                      i see, thanks for the guide, i will try to replace one of them, hope this solve the case, many thanks
                      • Boardview and Schematic Bot
                        Lenovo Yoga 7 14ACN6 Hybrid (2-in-1) Specification for Upgrade or Repair
                        This specification for the Lenovo Yoga 7 14ACN6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7 14ACN6 boardview and 7 14ACN6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                        09-07-2024, 05:00 AM
                        Lenovo Yoga 7 Carbon 14ACN6 Notebook Specification for Upgrade or Repair
                        This specification for the Lenovo Yoga 7 Carbon 14ACN6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7 Carbon 14ACN6 boardview and 7 Carbon 14ACN6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                        09-07-2024, 04:30 AM
                      • Maxpower3
                        Brand name and Model Type for Lenovo error 2202 product name is invalid
                        by Maxpower3
                        Info for error 2202 LenovoThinkPad models and type
                        Extract from ThinkPad Maintenance Utilities Configuration File
                        plnsrv.ini Version 1.01
                        Some information that may be useful
                        There must also be missing models, add them to the list if you know of any.
                        Code:
                        brand name
                        20B1=ThinkPad Edge E445
                        20B2=ThinkPad Edge E545
                        20BC=ThinkPad Edge E145
                        20BM=ThinkPad X140e
                        20BL=ThinkPad X140e
                        20A3=ThinkPad X230s
                        20AH=ThinkPad X230s
                        20AK=ThinkPad X240s
                        20AJ=ThinkPad X240s
                        02-21-2024, 10:27 AM
                      • iamdirac
                        Yoga Slim 6 14IRP8 82WV SN:YX07A9YJ - Stuck in BIOS recovery loop after interrupted update
                        by iamdirac
                        I have a Lenovo Yoga Slim 6 14IRP8 that got stuck in a BIOS recovery loop after a BIOS update was interrupted through Lenovo Vantage.
                        Here are my device details:
                        - **Model:** Yoga Slim 6 14IRP8
                        - **Serial Number:** YX07A9YJ
                        - **OS:** Windows 11 64-bit
                        **Problem:**
                        Every time I boot, I get the message: "Do you want to recovery ROM part? (Caution: Not every OS is bootable in Recovery Mode.)" with two options: YES or NO. The screen just stays there with both options and does not do anything on its own. When I...
                        04-07-2026, 11:49 AM
