Huawei MateBook D16 (RLEF-X) - Touchpad dead in Windows, works in BIOS, Intel UHD driver gives black screen
  • Fabián Morin
    • Nov 2024
    • 18
    • México
    I'm working on a Huawei MateBook D16 and I'm stuck with a persistent issue. I hope someone here can help.
    The problems:
    1. Touchpad: Works perfectly in the BIOS (cursor moves), but it's completely dead once Windows starts. It doesn't appear in Device Manager.
    2. Display: The Intel UHD Graphics driver causes a black screen when booting Windows normally. However, in Safe Mode, the Intel driver works flawlessly and the display is stable. If I uninstall the Intel driver and use the generic Microsoft Basic Display Adapter, the screen works, but the touchpad remains non-functional.
    Background / What I've already tried:
    • Reprogrammed the BIOS using a CH341A programmer. I used a BIOS image from a post that i made here, which changed the system model name to 'RLEF-XX'.
    • Disabled automatic driver installation via Windows Update (Device Installation Settings).
    • Uninstalled and reinstalled the touchpad driver from Device Manager.
    • Installed the 'Intel Serial IO' driver from the Huawei support page and via the Huawei PC Manager.
    • Updated the BIOS to the latest version through the PC Manager.
    • Used DDU in Safe Mode to completely clean the Intel graphics driver.
    Key observation: The Intel driver works perfectly in Safe Mode, which rules out a hardware failure or a corrupt driver. The issue seems to be a conflict with another driver or service that loads during normal Windows startup.
    Questions:
    1. Could the model name change in the BIOS (from RLEF-XX to RLEF-X) be preventing the Huawei PC Manager from installing the correct touchpad drivers?
    2. Does anyone have a clean BIOS dump (with a clean ME region) for this specific model (RLEF-X) that I could try?
    3. How can I identify which driver or service is conflicting with the Intel driver during normal boot? (I've tried using msconfig to disable services, but I haven't been able to isolate the problem).
    4. Is there a specific, stable version of the Intel UHD Graphics driver known to work with this model in normal boot?
    Any guidance would be greatly appreciated. I've attached screenshots of Device Manager and the PC Manager.
    Thank you!
    I'm attaching the original BIOS dump (from the factory) and the new BIOS image I flashed onto the chip. I would really appreciate it if someone could compare them and point out any differences that could be causing the touchpad and Intel graphics driver issues.
    MOD EDIT: Link to bios request topic -
    https://www.badcaps.net/forum/troubl...i-matebook-d16
  • mon2
    • 16638
    See if this helps:
    https://github.com/momentics/BLTP784
    • sosit
      • Feb 2023
      • 75
      • oman
      Bro, I suspect this isn't a hardware fault.
      I suggest you install Linux and verify if the issues persist. There is a 90% chance that it will run smoothly on Linux. If the problem disappears in Linux, then it’s likely a driver compatibility or communication issue within Windows.
      Performing a BIOS ME region clean-up might resolve it, though I can't guarantee it
      • Fabián Morin
        • Nov 2024
        • 18
        • México
        I suspect the issue is the ME Region of the laptop. I've already done several software tests and everything points to that, but I don't know how to fix it. Could you guide me? The touchpad doesn't work in Windows at all: no cursor, no gestures, no buttons. What information or files should I provide so you can help me? Thanks.
        • Bios-Newbie
          Huawei Matebook D16 RLEF-X (2022AP2559) Bios needed
          by Bios-Newbie
          I got the following Laptop from a good friend. She told me, that she couldn't boot after a bios update from huawei.
          Only CapsLock, Shift and FN lit up. Fan went on for a few seconds, Power-Led blinks and it shut down. This behavior looped and after 4-5 times it would stay off.
          She gave the laptop to a repair shop and the guy told her he would try to replace the Bios-Chip.
          After she got it back it wouldnt boot at all. Repair guy said it is not worth it to investigate any further and that the mainboard is dead.
          The Mainboard seems alright....
          08-05-2026, 02:49 PM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • zathan
          Huawei Matebook D15 2021 Intel bios request
          by zathan
          I help need help for BIOS.
          Huawei Matebook D15
          Model: BoDE-WDH9 (Huawei Matebook 15 2021)
          Motherboard model: H98D
          Motherboard DAH98DMB8B0 Rev:B HF
          S/N: CWYPM23103000640
          Thank you...
          03-26-2026, 08:28 PM
        • Boardview and Schematic Bot
          Huawei MateBook Matebook D 15 Notebook D 15 AMD Specification for Upgrade or Repair
          This specification for the Huawei MateBook Matebook D 15 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Matebook D 15 boardview and Matebook D 15 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-07-2024, 06:21 AM
          Huawei MateBook Matebook 16 Notebook 16 Specification for Upgrade or Repair
          This specification for the Huawei MateBook Matebook 16 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Matebook 16 boardview and Matebook 16 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-07-2024, 06:11 AM
