A1932 no power
  • madjid911
    • 486
    • France
    A1932 no power
    Hello, I have a MacBook A1932 (820-01521-02) that won't start up at all. The trackpad clicks fine, but the keyboard is unresponsive and there is no display. There is no oxidation—the motherboard is very clean—and I haven't found any shorts. DFU mode works, and I was able to restart the T2 chip without issue (I don't want to restore it because the client needs their data).
    Here are the measurements:
    PPDCIN_G3H 19V80
    PPBUS_HS_CPU 12V63
    PP2V7_NAND 2V49
    CHGR_VBAT 12V62 - 0V163 cycle
    PPBUS_G3H 12V62
    PP5V_S5_LDO 5V
    PP3V3_G3H_RTC 3V27
    PP3V3_UPC_XB_LDO 3V23
    PP1V2_S3 1V19
    PP3V3_G3H 3V31
    PP5V_G3S 5V12
    PP1V8_G3S 1V8
    PP1v8_S5 1V8
    PP3V3_AWAKE 3V3
    PP3V3_S5 3V3
    PP1V1_SLPS2R 1V1
    R7061 R7062 R7063 are good​
    The bare motherboard's current draw is 0.20 A at 19.9 V.
    The CHGR_VBAT / PPVBAT_G3H_CONN voltage drops to 0V163, returns to 12.62V, then repeatedly drops back down
    Can you help me find the source of the problem, please?
    Schematic & Board View :
    https://www.badcaps.net/forum/docume...tic-board-view
  • mon2
    • 16671
    Remove all power. Meter in lowest resistance scale.
    Measure the resistance across capacitor C7020. Next, touch your meter probes together and this is your 0R ohms baseline on your meter.
    Subtract this baseline value from the measured resistance across C7020. What is the value?
    • madjid911
      • 486
      • France
      C7020 : 2,7 ohms
      • mon2
        • 16671
        This is ok.
        Do you have a battery attached? Disconnect it if it is connected. Any difference on the power on cycle?
        Measure the voltage to ground of:
        SMBUS_3V3_BATT_SCL
        SMBUS_3V3_BATT_SDA
        at the battery connector.
        • madjid911
          • 486
          • France
          No change with the battery and audio ribbon cable disconnected.
          SMBUS_3V3_BATT_SCL : 3V22 3V31
          SMBUS_3V3_BATT_SDA​ : the same
          another measure:
          SWE010 3V27
          PCH_PWRBTN_L 3V31​
          • mon2
            • 16671
            These are ok. The nand voltage may be lower than normal. What is the voltage of the power good signal for this rail? This is P2V7NAND_PGOOD.
            • madjid911
              • 486
              • France
              P2V7NAND_PGOOD : 2V46
              • mon2
                • 16671
                PP2V7_NAND 2V49
                Can you confirm with another multimeter or test with fresh batteries?
                On the A1932 MacBook Air logic board, a reading of 2.49 V on the PP2V7_NAND rail is critically low and indicates a fault. This power rail must measure exactly 2.7 V to supply the T2-managed NAND flash storage chips.
                Because PP2V7_NAND is missing its full voltage, the SSD cannot initialize, preventing the Mac from turning on or booting.
                Why the Rail is Low
                • Short Circuit to Ground: A failing capacitor on the PP2V7_NAND line or a damaged NAND chip itself is pulling the voltage down.
                • Failing SSD Power Controller: The buck regulator IC (U9000, typically ISL95870B) responsible for creating this rail is damaged or lacks proper feedback.
                • Corrupted T2 Firmware: The T2 security chip may not be enabling the rail cleanly, requiring a DFU restore. [1]
                How to Diagnose the Issue
                1. Check for Shorts to Ground
                  • Disconnect all power from the logic board.
                  • Switch your multimeter to Diode Mode.
                  • Place the red probe on ground and the black probe on a PP2V7_NAND testing point.
                  • A reading close to 0.000 V indicates a dead short, usually caused by a bad capacitor. [1]
                2. Inspect the Regulator Enable Signal
                  • Measure NAND_P2V7_EN while power is applied.
                  • This signal must be a clean 1.8 V logic high coming from the T2 chip to tell the buck regulator to turn on.
                3. Check the Buck Regulator Inputs
                  • Confirm the chip generating this rail is receiving its main input voltage, PP5V_G3S.
                • madjid911
                  • 486
                  • France
                  Yes, I confirm that P2V7NAND_PGOOD is 2.46 V.
                  Does ISL95870 correspond to U8110 here? I don't have a U9000 on my board.
                  I measured 0V49 on U8110 PVCCIOS0_SREF. Is that normal?
                  U9060 :
                  P2V7SSD0_EN and P2V7NAND_EN : 1V8, R9060 it's ok O,1 hom, which manages P2V7NAND_EN ? it's U7800 ?
                  P2V7SSD0_FB : 0V79
                  P2V7SSD0_VOS : 2V46
                  Diode mode reading PP2V7_NAND : 0.327
                  • madjid911
                    • 486
                    • France
                    I replaced the CHIP U7800, but the result is the same: P2V7NAND_EN is still at 1.8V, P2V7NAND_PGOOD 2V49
                    . Click image for larger version
                    • madjid911
                      • 486
                      • France
                      I removed L9060 and injected 2.7V into P2V7NAND to try to boot the MacBook and recover the data, but it didn't work; I replaced U9060, but the result is the same. Do you have any ideas?
                      • mon2
                        • 16671
                        What is the voltage to ground of ALL_SYS_PWRGD?
                        • mon2
                          • 16671
                          Attached power sequence.
                          • madjid911
                            • 486
                            • France
                            ALL_SYS_PWRGD 0v
                            mode diode 0.433
                            • mon2
                              • 16671
                              ALL_SYS_PWRGD 0v
                              Confirm the pull-up resistor on this open-drain circuit has a voltage. This is R8005 - test both sides of this pull-up resistor for a voltage.
                              Also, U1910 for the PP1V8_S5 rail.
                              • madjid911
                                • 486
                                • France
                                R8005 it's ok 1koms, PP1V8_S5​ 0V, I had it before, but I don't anymore since I replaced U7800 U9060 U8100
                                • mon2
                                  • 16671
                                  Confirm the resistance to ground of the missing PP1V8_S5 rail.
                                  If the resistance is high, then the PP1V8_S5 rail is not shorted. [1]
                                  The problem is either a missing enabling signal, a blown current sensing resistor, or a faulty PMIC (Power Management IC). Because this rail must turn on before the board can reach higher power states, its absence will freeze the boot sequence. [1]
                                  Key Troubleshooting Steps
                                  1. Verify Input Power: Check if the PMIC is receiving its primary input voltage on the PP3V3_G3H_RTC rail.
                                  2. Measure the Enable Signal: Locate the PMIC (U7800). Check if it receives the enable signal for this specific 1.8V rail from the T2 chip.
                                  3. Inspect Output Components: Check the series inductors and current-sense resistors directly connected to the output of the 1.8V buck regulator circuit for physical damage or cracks.
                                  4. Test the PMIC Outputs: If the input power and enables are present but the rail measures 0V, the U7800 PMIC itself is likely defective and requires replacement.
                                  • madjid911
                                    • 486
                                    • France
                                    U7800 seems fine; I have most of the voltages, but P2V7NAND_EN is at 1.8V instead of 2.7V.
                                    The T2 chip might be defective or corrupted, but I need to recover the client's important data; is there a way to recover data from the soldered NAND chips on this model?
                                    • mon2
                                      • 16671
                                      Try TARGET mode access. Use external keyboard with this MacBook.
                                      How to use Target Disk Mode
                                      Because your MacBook Air (Model A1932, a 2018-2019 Intel model) features a T2 security chip, you can share its storage using a few simple steps. [1, 2, 3]
                                      1. Connect: Plug a fast Thunderbolt 3 (USB-C) cable into both your MacBook Air and the second (host) Mac. Note: Regular USB-C charging cables will not work for data transfer. [1, 2]
                                      2. Turn on Air: Make sure your MacBook Air is turned off.
                                      3. Boot into Mode: Press and hold the T key on your MacBook Air. Press the Power button while still holding the T key. [1]
                                      4. Locate Disk: Keep holding the T key until a floating Thunderbolt or USB logo appears on your screen. Your MacBook Air is now acting like an external hard drive. [1]
                                      5. Access Files: Open the Finder app on the second Mac. Your MacBook Air will show up in the left-hand sidebar under "Locations". [1, 2, 4]
                                      6. Eject: When you are done moving files, drag the MacBook Air's drive icon to the trash can on the host Mac to safely eject it. Turn off your MacBook Air to exit the mode.
                                      • bouch
                                        unlock macbook air A1932 2019
                                        by bouch
                                        hi
                                        i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                                        i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                                        i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                                        have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                                        I need help or information?
                                        Does anyone have the minat2 activator 1.4 software?
                                        Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                                        Thank yo...
                                        03-12-2025, 10:14 AM
                                      • thuygsm
                                        Macbook A1932 cpu very hot
                                        by thuygsm
                                        Hello everyone!
                                        I have a MacBook A1932, powered on with 20V, 0.60A, 12.33W (no battery, only the motherboard).
                                        1. The Caps Lock does not light up, and the trackpad does not respond.
                                        2. When plugged in, there is a sound.
                                        3. The CPU gradually heats up to about 100°C.
                                        4. After about 2 minutes, the CPU's temperature decreases gradually, with 20V, 0A, 0W....
                                        07-02-2026, 08:31 AM
                                      • Bolik
                                        Macbook A1932 motherboard 820-01521-02 20V 0.1A not starting
                                        by Bolik
                                        as mentioned in the title, the Macbook A1932, when connected to the charger, goes to 20V and the startup sequence stops, and the power consumption is 0.1A.
                                        PPBUS_G3H - 12.7V
                                        PP3V3_G3H - 3.26V
                                        PP0V8_SLPS2R - 0.808V
                                        PP1V1_SLPS2R - 1.12V
                                        PP1V8_SLPS2R - 1.825V
                                        PP0V82_SLPDDR - 0.828V
                                        PP0V9_SLPDDR - 0.906V
                                        PP1V1_SLPDDR - 1.109V
                                        PPVDDCPU_AWAKE - 0.76V
                                        PPVDDCPUSRAM_AWAKE - 0.806V
                                        PP1V2_AWAKE - 1.213V
                                        PP1V8_AWAKE - 1.808V
                                        PP3V3_AWAKE - 3.26V
                                        P3V3MAIN_PGOOD - 0V
                                        P1V8G3S_EN - 0V
                                        PP1V8_G3S -...
                                        03-14-2026, 04:59 PM
                                      • Stevechurch
                                        Macbook Air A1932 no sound from speakers
                                        by Stevechurch
                                        Good afternoon All
                                        i have a Macbook Air A1932 with no sound from speakers, but it does have sound from jack plug with corded earbuds plugged in
                                        i have checked left and right amps in diode mode all all checks out ok, i think it is unusual for both speakers to stop working together but i have no history regardin this mac
                                        i have both 820-01521 and 820-01124 boardview and schematics
                                        Has anyone encountered this before?
                                        kind regards
                                        Steve
                                        01-12-2026, 09:11 AM
                                      • astroboypaul
                                        Macbook A1932 Some Keys Not Working
                                        by astroboypaul
                                        Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
                                        Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left...
                                        06-10-2024, 05:32 AM
