Dell G5 15 5500 (DP/N 03GNH6) - Auto power on, no POST, black screen - BIOS not accessed?
  • Mize27
    • Jun 2026
    • 5
    • Deutschland
    I'm looking for some help with a Dell G5 15 5500.
    Service Tag: 6044B63
    Mainboard DP/N: 03GNH6
    Board markings:
    SELEK MLK N18P
    19795-1
    Symptoms:
    - Automatically powers on when AC adapter is connected.
    - Black screen, no Dell logo.
    - Keyboard backlight turns on.
    - Fans spin briefly and the board continues attempting to boot.
    - No response to the power button.
    - Boot loop continues even on battery power until the battery is physically disconnected.
    What has already been done:
    BIOS:
    - Backed up original Winbond (8MB) and Macronix (16MB) SPI dumps.
    - Dumps were read multiple times and verified identical.
    - Several experienced members here provided cleaned/rebuilt BIOS files.
    - Flashed:
    - Winbond only
    - both SPI chips
    - another complete BIOS set from a different member
    - Every flash:
    - Erase OK
    - Blank Check OK
    - Program OK
    - Verify OK
    - Absolutely no change in behaviour after any BIOS combination.
    Hardware checks:
    - Display cable checked and reseated.
    - RAM tested.
    - PCH pressure test while powering on:
    -> No change.
    - PCH gets warm.
    - CPU gets warm.
    - NVIDIA GPU gets warm.
    Voltage measurements (board powered on):
    CPU VCore (R10 coils):
    ~0.8-1.0V stable
    2R2 coil:
    2.92V
    R47 coils:
    Left: 1.20V
    Right: ~7V
    USB VBUS:
    0V
    Resistance/Diode checks:
    No obvious short found on the main power rails.
    SPI flash measurements:
    Winbond W25Q64:
    Pin 8 (VCC): 3.3V
    Pin 4 (GND): 0V
    Pin 2: 3.3V
    Pin 3: 3.3V
    Pin 7: 3.3V
    Pin 1 (CS#): ~2.66V
    Pin 5 (MOSI): 0V
    Pin 6 (CLK): 0V
    Macronix MX25L128:
    Pin 8 (VCC): 3.3V
    Pin 1 (CS#): 3.3V
    Pin 5 (MOSI): 0V
    Pin 6 (CLK): 0V
    (I know a DMM cannot properly display SPI clock activity, so these are only DC measurements.)
    Since multiple known-good BIOS images produce exactly the same behaviour, I'm starting to believe this is no longer a BIOS issue.
    Could someone point me to the next logical measurements for this board?
    Should I check:
    - RSMRST#
    - PLT_RST#
    - SLP_S3#
    - SLP_S5#
    - PCH power-good signals
    - EC signals
    or something else?
    Any guidance would be greatly appreciated.
    Thanks in advance
    Michael
  • mon2
    • 16565
    USB VBUS:
    0V
    Remove all power. Meter in resistance mode. What is the resistance to ground of the same VBUS line? Testing if the USB load switch is defective and causing this fault.
    • Mize27
      Mize27 commented
      Editing a comment
      Resistance from VBUS to GND with all power removed is OL (meter shows "1"). No short to ground. Meter probes together read ~0 Ω
  • mon2
    • 16565
    Is your meter auto scaling or a manual type? If manual type, select a higher meter scale till you have a measurement.
    Review if there is a usb load switch nearby the usb connector. Share the topside markings of this part.
    • Mize27
      • Jun 2026
      • 5
      • Deutschland
      mon2
      My meter is manual ranging. I measured VBUS to GND with the board unpowered. On the 20 kΩ range it reads OL ("1" on the display), so there is no short to ground, i also tried on 200K.
      Please see the attached close ups of the USB area. I reckon you mean USB802 (AP5934 VW56F)?
      • Mize27
        Mize27 commented
        Editing a comment
        Found the EC: Microchip MEC1515-NP.
        EC area measurements:
        - 3.3V present near MEC1515 decoupling caps.
        - Other caps around EC show 1.8V and 0V as expected.
        Coils near EC:
        PL5101: approx. 3.0V on one side, 1.2V on the other side
        PL4501: approx. 2.7V / 3.0V
        Could someone please point me to EC_RST#, RSMRST#, SLP_S5# or PLT_RST# test points for this board?
        EDIT:
        CPU VCore inductors: 0V on both sides.
        CPU VRM MOSFETs have ~20V VIN.
        Several small capacitors near the CPU VRM area measure 5.13V.
        However, the CPU VCore never comes up.
        The fan starts immediately when the AC adapter is connected, but there is no POST and no display.
        At this point it looks like the CPU VRM is not being enabled. I'm trying to determine whether the NCP81266 is missing VCC, VR_ON/ENABLE, or another prerequisite power-good signal.
        If anyone has a boardview/schematic or knows the VCC and EN pin/test points for the NCP81266, I'd really appreaciate it.
        Board markings:
        SELEK MLK N18P
        19795-1
    • Tesla
      Dell XPS-15 (9520) Mostly Bricked after common BIOS-Firmware upgrade - Full Repair Log
      by Tesla
      I have a Dell XPS-15 (9520) with the LA-L402P motherboard. It seems to have bricked itself after a common BIOS-Firmware upgrade. Now, it just shows BIOS screen for a few seconds before turning-itself back Off (and doesn't seem to be fully Posting). I've done these many times before with no problems.
      I was hoping to please have my own-thread to work-through this (hopefully successful) repair as a whole. Apart from the possible need to have a BIOS-dump fixed-up, I have a feeling I'm going to have other questions. This includes using my new XGecu-T76 for the first time (should be here...
      03-19-2026, 07:51 PM
    • zenius
      by zenius
      12-08-2024, 06:13 AM
    • mikeybass
      by mikeybass
      04-23-2025, 04:30 PM
    • capoplays
      Help with BIOS update on Dell G15 5515 after chip replacement
      by capoplays
      Hey everyone,
      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
      When I check the BIOS using the F12 menu Flash...
      10-24-2025, 06:53 AM
    • Sathsul
      Dell Latitude 5431 issues with dumping bios
      by Sathsul
      So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
      The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
      However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
      10-28-2025, 07:49 AM
