Asus , board 532lws R1..3 Power rail 5v , 3v dsw
  • User 4574
    • Jun 2026
    • Slovensko
    Hi everyone .
    I have model g712l And In stuck.
    Originally this laptop has a short on main Power rail . Thé main short is gone, i have found 2 pea16b mosfets Next to the SN51285ARUKR shorted , and the Chip Intself was Also shorted , i have removed them and main Power rail IS not shorted anymore , but right Now im still eating for this parts And in checking rest of the board . But pin 14 od the SN51285ARUKR when this chip od removed is shorted to ground Its +5VSUS has 6ohms , And that can not be , i have check mosfets All over the board And i have found ONLY one tahat ís shorted its pea16ba shorted source to drain . Its locsted next to the PCH , mosfet od removed measured And Its ok , short present .
    I have an ASUS ROG G712L motherboard and I am stuck with a power rail issue.
    Originally the laptop had a hard short on the main power rail (AC_BAT_SYS). After troubleshooting, I found two PEA16BA MOSFETs next to PU8701 (SN51285ARUKR) shorted source-to-drain. The PU8701 controller itself also appeared damaged.
    I removed:
    • PU8701 (SN51285ARUKR)
    • both PEA16BA MOSFETs
    After removing these components, the main AC_BAT_SYS short disappeared completely.
    I am currently waiting for replacement parts, but while checking the rest of the board I found something strange.
    With PU8701 completely removed from the board:
    • Pin 14 (VO1 / +5VSUS sense) measures almost shorted to ground.
    • The +5VSUS rail measures approximately 6 Ohms to ground.
    • PL8701 was removed during troubleshooting.
    • The MOSFET side (LX node) measures normal.
    • The +5VSUS side still measures very low resistance.
    I started isolating loads from the +5VSUS rail:
    • PU8201 (NB692GD-Z) isolated -> no change
    • PU8601 (DDR regulator) isolated -> no change
    • PU8302 (+1.05VSUS regulator) isolated -> no change
    • PCE8701 removed -> no change
    The +5VSUS rail still measures around 5.8-6 Ohms.
    I also injected voltage into +5VSUS:
    • 1.0V -> ~0.175A
    • 1.5V -> ~0.255A
    The current increases linearly and nothing gets noticeably hot.
    Another thing I found:
    There is one more PEA16BA MOSFET located near the PCH area which measures shorted on the board. After removing it and testing it out of circuit, the MOSFET itself is good, but the short remains on the motherboard side.
    At this point I am unsure whether:
    1. 5.8-6 Ohms on +5VSUS is actually abnormal for this platform.
    2. There is still another load connected to +5VSUS that I have not isolated.
    3. The fault is somewhere in the +3VA_DSW / +5VSUS generation area.
    4. I may have damaged an internal PCB layer when the original PU8701/MOSFET failure occurred.
    Has anyone worked on this platform and knows what resistance is normally expected on +5VSUS with PU8701 removed?
    Any advice would be greatly appreciated.
    Thank you.Hi everyone,
    I removed:
    • The +5VSUS rail measures approximately 5.8-6 Ohms to ground.
    • The MOSFET/LX side of PL8701 measures normal.
    I personally believe the remaining fault is somewhere on the main +5VSUS power rail.
    • 1.0V -> ~0.175A
    • 1.5V -> ~0.255A
    Current increases linearly and behaves as expected for roughly 5.8 Ohms.
    Unfortunately I do not own a thermal camera, so I cannot easily identify a hotspot. I tried voltage injection and cooling spray, but nothing becomes noticeably warm.
    There is one more PEA16BA MOSFET located near the PCH area which measures shorted while installed on the board. After removing it and testing it out of circuit, the MOSFET itself is good, but the low resistance remains on the motherboard side.
    PU8801 (SN1409049DPUR) measurements:
    • Input pins 1, 2, 4, 6 and 7 measure very low to ground.
    • Output pins measure normally (around 800-1200 in diode mode).
    • PQ8801 source side measures normally (~600 diode mode).
    • PQ8801 drain side is connected to the low-resistance rail.
    3. The fault is somewhere in the +3VA_DSW / +5VSUS generation section around PU8701.
    4. The original failure damaged an internal PCB layer.
    5. I am chasing a normal resistance and looking in the wrong place.
    Has anyone repaired this platform and knows what resistance is normally expected on +5VSUS with PU8701 removed?
    Would you continue isolating loads from +5VSUS, or would you rebuild the complete PU8701 section first and continue troubleshooting after restoring +3VA_DSW and +5VSUS generation?
    Thank you.
    0
    Bad cap
    0%
    0
    Shorted internal layer in thé motherboard
    0%
    0
  • Nagy Daniel
    Lowest possible resistance on laptop motherboard rail - Guide Table request
    by Nagy Daniel
    Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
    I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
    I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
    So, I generated a table with AI so I can...
    03-04-2025, 08:24 AM
  • Victor Moreira Silva
    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
    by Victor Moreira Silva
    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
    Well, my decice specs are the following:
    Model: Acer Nitro 5 AN517-54-55T5
    CPU: Intel Core i5-11400H
    GPU: NVIDIA GeForce GTX 1650
    Motherboard: GH51G LA-L181P Rev:1c
    The symptom:
    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
    05-26-2025, 10:49 AM
  • CharlesBHaskins
    RTX 2060 Laptop VRAM Rail Resistance
    by CharlesBHaskins
    I'm checking the VRAM power rail on an RTX 2060 laptop GPU and I'm not sure whether the resistance I'm measuring is within the normal range.
    Has anyone measured the VRAM rail resistance on a similar board? What values did you get, and how can you tell if there's a short?
    Thank you so much!
    06-18-2026, 01:11 AM
  • bimole
    Weird behavior on 3.3V rail of a CORSAIR CX600
    by bimole
    A colleague gave me an apparently ill CORSAIR CX600.
    He told me that he heard a banging noise, and smelt the magic smoke.
    After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
    I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
    It's another story on the 3.3V rail...
    I have some devices to test deeply PSUs (scope, AC source, electronic load)...
    02-13-2025, 04:49 AM
  • privato89
    Asus Q409ZA (NB5936_MB_V3) – V1P8A rail shorted, CPU heating, no boot after BIOS reflash
    by privato89
    Hi guys,
    I’m working on an Asus Q409ZA motherboard (NB5936_MB_V3) in my lab that does not boot. I already reprogrammed the BIOS chip but the behavior did not change.
    Powering the board via USB-C, I measure about 20.23 V and 0.2 A at startup, and these values remain completely stable with no current or voltage oscillation. Using a thermal camera, I see the CPU heating up to around 60–70 °C, and next to the CPU there is a QFN chip marked “NFDF” (PU1301) that heats up to about 40 °C and is supplied by the V1P8A rail. The V1P8A rail is shorted to ground and does...
    01-04-2026, 03:36 AM
