Lenovo ThinkPad T530 (LKN-4 UMA MB 11223-3 Mainboard) - Brain dead / no image
  • mitchw
    • 162
    • Slovenia
    I've been trying to repair this old T530 laptop. It is in really good condition, with no almost signs of use.
    However it is dead. There was no prior information provided, how it died, or so. The board is extremely clean, there is no dust inside, etc.
    It does power on and it charges the battery. However the display stays black, also the USB devices (like a mouse) don't initialize or power on - that means it is essentially brain dead.
    Fan spins for about 4-5 seconds, then stops. The CPU will get really hot eventually, but the fan will not spin up, nor the laptop will shut down.
    I tried powering up only the board with no other cards attached, with one known good stick of RAM. Also I removed the RAM and checked if it will beep.
    Nothing works.
    Next I tried flashing the BIOS with some (3 or 4) dumps from the internet. There are two chips (ME and BIOS), I did flash them both. Nothing. And I used the right dumps, as some of them were for the version with discrete GPU.
    Next I reflashed the original BIOS and cleaned the ME region (manually - that might be a problem?), still nothing.
    I put the original BIOS back for now.
    Next, I measured every single power rail and it seems they are all present. I also checked most of the fuses (Lenovo loves them apparently), and they all check good.
    Next, I used the thermal camera to check if anything was getting hot on the board. Sadly it is covered with that darned black tape, but nothing sticks out.
    Measured the two crystals near the PCH with an oscilloscope (32KHz and 25MHz), both are spot on.
    I also replaced the CPU with another one - probably known good, can't test it really in another machine. Behavior stayed exactly the same with the other CPU.
    The board is taking 1A at 20V, or sometimes 0.8A at 20V. Current is steady all the time.
    Interestingly sometimes it decides to draw 1A, sometimes just 0.75-0.8A.
    Since I wasted enough time on that board, I am asking here if perhaps anyone has any info about those Lenovo boards or what to check next?
    Thanks!
  • mitchw
    • 162
    • Slovenia
    No ideas?
    I tried another (known good) CPU and also the thing is still very much dead.
    Also tried plugging in the ethernet cable, and the card is alive (was thinking it could have been damaged by lightning strike). So it is not that.
    I discovered something called a Libreboot BIOS, and it also exists for T530.
    Don't know much about how it actually works, but I was looking for a bin file(s) that I could flash and try that one, but you need to compile it yourself.
    Does anyone have more info how to do it, or already has a premade image for T530, that I could just directly flash using a SPI programmer?
    Except for this BIOS, I now really don't have any more ideas...
    • pashagaponuk
      Lenovo ThinkCentre M90q Gen5 IQ6X0IL1 - Mainboard LQ674 - NM-G071 BIOS request (dead after failed update)
      by pashagaponuk
      I need a BIOS dump for the following board, please:
      Motherboard: Lenovo ThinkCentre M90q Gen 5 (Tiny)
      System model: IQ6X0IL1
      Board model: LQ674
      Board code: NM-G071
      Chipset: Intel Q670
      CPU support: Intel 13th/14th Gen (LGA1700)
      SPI flash chip on the board: Winbond W25R256JVEN
      Problem: BIOS got corrupted during a firmware update, motherboard is now dead/bricked (no POST, no display).​
      I can attach my corrupted dump if it helps with diagnosis.​
      Any help would be greatly appreciated. Thank you!​
      07-02-2026, 11:48 AM
    • re-atari
      MSI A520M Pro mainboard - need boardview and/or hires photo's of components surrounding RT8894 PWM controller
      by re-atari
      Recently I was donated a defective MSI A520M Pro rev. 1.0 mainboard, that I am now trying to get back on its feet again. The error description when I received it, was that it wouild not boot, with the CPU error led lighting up.
      When inspecting the board with a magnifying glass, I noticed someone had slipped with a screwdriver when installing the CPU cooler. Not just once, but 2 times at that. Go figure. In the end the result was 2 scratches with damaged copper traces and a few knocked off (and missing) components around the RT8894 PWM controller. No wonder the...
      01-21-2026, 11:58 AM
    • jamesp
      Acer Aspire A315-55 Dead mainboard
      by jamesp
      Hello, can someone please help me. i have a dead laptop mainboard, aspire a315-55 with board model DA0ZAWMB8G0 rev. G
      upon checking of voltages at s5, 19v is present Vin, 5v and 3v is present at PL6001 and PL6000 respectively, but no signal from MAINON And s5_ON to be able to produce +3v_s5 to give power to vcc of BIOS CHIP U2. MAINON and S5_ON is coming from ec chip U37 it8987e/cx.
      do i need to reflash the EC? any advice? thanks...
      09-30-2024, 08:24 AM
    • 3mz3t
      ThinkPad T14 Gen1 Intel, dead mainboard
      by 3mz3t
      NM-C931 mainboard, does not start, no light, no nothing. Draws 20.56 V / 0.14 A from a wall charger.
      Under thermal camera, the only thing that show is the ThinkEngine chip (BD4179MWV / UTE1B) heating up (also quite hot to the touch), there's 19.75 V on the VREGIN20 (pin 45).
      Is the BD4179 dead? WDYT?
      Thank you....
      08-05-2024, 04:59 AM
    • cruiser_
      A1342 820-2567-A brain dead
      by cruiser_
      hi everyone,
      i've got this ancient board here, repairing it as an exercise really. it seems to be brain dead.
      upon triggering start via SMC_ONOFF the fan starts to spin, USB powers up, CPU gets hot but there is no further activity.
      nothing on the video output, no USB activity (using pendrive with an LED).
      I've read the bios, it looked ok, valid checksums, model/.mb match etc.
      I cleared VSS and wrote the bios back. NO change.
      any suggestion as to what might be the cause of this?...
      12-02-2023, 04:19 PM
