Hello, I am working on a surface go 2 that died due to an input power issue with the charger. I have identified this component labeled 2920M as a possibly bad part. This component starts screaming on thermal imaging as soon as the charger is plugged in. Problem is I cannot for the life of me find a datasheet or anything on this. I can't tell if it's a type of mosfet or what. Anyone have any ideas?
surface go 2 Part identification
This topic has been answered.
Answer selected by tlavite at 06-07-2026, 03:20 PM.
Review the datasheet and find a better brand like Texas Instruments or Diodes to replace it with same pinout and foot print in sot23-5.
This is a common fixed 3.3v ldo. Note the high Vin support which may be more difficult to source. Before you purchase, post your short list or ask AI to find a valid sub using Digikey or Mouser as a vendor.
https://www.atombilgisayar.com/g2920...JFNirZ3-3w3BSO- Selected Answer
thank you!!Review the datasheet and find a better brand like Texas Instruments or Diodes to replace it with same pinout and foot print in sot23-5.
https://www.atombilgisayar.com/g2920...JFNirZ3-3w3BSOComment
by paparazzo79Hi guys.
I want to purchase Surface Pro 7 from the link below but it does not come which charger,but it does come with Surface dock and it's charger.
May I use my charger from Surface Pro 5 which is rated as:
OUTPUT: 15V=4A, 5V=1A
The Surface I want to purchase is:
https://olx.ba/artikal/55430643/10-06-2023, 08:55 AM -
by ntecI’m trying to fix a Corsair mechanical keyboard but could someone tell me what the circled part is as I think it may be the issue. There is 2 legs with a small square seethrough piece at the top that is separated inside almost like a fuse but it’s labeled d140 which I assume is some type of diode?. I tried searching but couldn’t find any part that looks like this....
by Baludoki80I have a wrong motherboard,does not switch on,no power.the framed part heats up,and the smd market is RUA3 but I couldn't find this part.I search schematic thank you...
by paparazzo79Hi guys.I got myself Surface Book 1 but instead of charger I got this (from pics).
May I use it to charge the Surface Book or I need original charger?
6 Amps seems to much.... -
by rsa4092Acer Nitro 5 - AN515-54-52PY - LA-H501P
Hello, I’m having a problem with my Acer Nitro 5 laptop, which has a Compal LA-H501P motherboard.
Initially, the CPU power regulator was replaced because the computer shutdown unexpectedly, and couldn't be turned on, the service centre diagnosed a short circuit in the CPU power regulator, replaced it and laptop was working. After about two months, a new problem arose – the laptop would shutdown under heavy load, even when connected to charger. In addition, the battery was charging very slowly – or rather, discharging – despite... - Loading...
