Often but not every time when I remove the charger the picture will instantly go garbled with random multi-coloured lines or dots. It has to be forced off and rebooted.
Tested with other known working LCD and RAM and CPU so ruled these out.
The GPU is integrated in the CPU.
I've never seen it do it on the charger only on the battery. If I boot it from the battery and wait a while sometimes it will suddenly do it.
Always works perfectly with the charger!
All board voltages appear normal including the CPU / GPU ones (1.1v and 0.45v).
It does the same whether using the charger or bench power supply.
Many thanks.
Many thanks.
