MacBook Pro A2779 Non Genuine Display Replacement Confusion
  • jiraiyaishere
    • Aug 2022
    • 9
    I bought a screen replacement from AliExpress to repair a Macbook A2779 screen for my friend that from what I am guessing had a tear in the display ribbon cable.
    When the MacBook Pro boots up, the webcam light on the new screen seems to flash about 3 times for a period of 2 seconds for each flash. It also does it again when logging in and then it did it one time randomly about 2 minutes after logging in...
    Does anybody recognise this behaviour/know what the reason is? I have messaged the seller but judging by the quality of what I received (very long backlight and display cables that obstruct the antenna bar a bit, lid angle sensor was torn on arrival and screw on it was wrong so I have to use my original one which doesn't work- I guess because it's not calibrated properly with this new display) I don't think they will be very receptive.
    The camera does work but I was just wondering if it's camera malfunctioning or something more nefarious? The camera does work...
  • driftkingisback
    MacBook Pro A2779 – No power / board troubleshooting 820-02655
    by driftkingisback
    I’m troubleshooting a MacBook Pro A2779 that does not power on.
    its my personal laptop and i want to try to fix it, i really need your help.
    PPVBAT_AON=12,1 V
    PP3V8_AON=CORRECT
    Symptoms:
    • MagSafe connected: LED initially turns green, then orange
    • Measured at MagSafe: approximately 20 V / 3.1 A / 63 W
    • The MacBook itself does not boot
    • No display, no normal fan activity
    • If I disconnect the keyboard / power button flex cable, the fans start spinning
    • With the keyboard/power button connected, pressing the power button does
    08-18-2026, 11:56 AM
  • survivalbloke
    Need a suitable replacement for this coil on a MacBook
    by survivalbloke
    I've got a lot of MacBook donor boards, but none with this part on them.
    MacBook A2338, Board 820-02020
    Component: L7800 - open/burnt
    Donor boards I have available, but not sure what a suitable replacement component is, since I don't have the exact board:
    820-00165
    -01987A
    -3476-A
    -3437-B
    -4924-A
    00928-A
    01700-A
    01827-01
    00928-A
    00138-A
    It's gray with a black dot on it. This is on 820-02020 and is L7800
    Thanks!...
    06-24-2026, 12:36 PM
  • Boardview and Schematic Bot
    Apple MacBook Pro 13 M1 820-02020-A 820-02020 Boardview and Schematic
    Apple MacBook Pro 13 M1 820-02020-A boardview 820-02020 V1.0 Boardview
    Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB
    Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Physical scanning image
    Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Location map...
    06-20-2026, 10:11 AM
  • sikorak666
    Macbook M4 Air 13" 16/256 memory replacement issue | 820-03597
    by sikorak666
    I'm hoping someone here can shed some light on this issue I'm dealing with.
    I recently bought a MacBook Air M4 13" with the base 256GB storage (16GB RAM). As you can probably guess, the storage quickly became a problem, so I decided to look into an upgrade. I found a company that offers post-warranty repair services for Apple computers, and they specifically advertise SSD upgrade services. They ordered 2TB NAND chips for the replacement.
    Here's the problem: after the installation, the computer doesn't see the new storage and won't boot....
    06-16-2026, 09:29 AM
  • nicocorradini
    MacBook Pro A2779 (820-02841) doesn't turn on after shutdown and LID close...
    by nicocorradini
    Hi everyone! As I said in the title, I’m having a really strange problem with a 14” MacBook Pro A2779 with an 820-02841 logic board.
    As long as the machine is powered on, everything works fine: it charges the battery, all three USB-C ports work fine, the LID Angle Sensor is OK, and it sleeps and wakes up without any problems.
    The problem starts when I completely shut down the machine, close the lid, and disconnect the MagSafe cable. About a minute later, it becomes completely impossible to turn it on again. I have to remove the bottom cover, disconnect the BMS flex,...
    08-27-2026, 08:50 PM
