ASUS GU603ZM liquid damage - unidentified hot IC near battery connector
  • 964758
    • Jul 2017
    • 44
    • Georgia
    Hello.
    Laptop: ASUS ROG Zephyrus M16 GU603ZM.
    Customer tried to clean the DC jack area with liquid cleaner while battery was still connected.
    After that laptop became completely dead.
    Findings:
    • No reaction to power button
    • Battery not charging
    • Main power rail was shorted
    • Injecting voltage with current limit causes one IC near battery connector to heat up heavily
    • This area had visible liquid damage/corrosion
    • After removing this IC, short circuit disappears completely
    • After soldering it back, short returns immediately
    Could someone help identify this IC or explain its function?
    I currently do not have schematic/boardview.
    Attached photos.
  • mon2
    • 16428
    The eH* SMD code corresponds to the SY8386 (and variants like SY8386ARHC or SY8386BRHC). It is manufactured by Silergy. [1]
    Key Specifications
    • Component Type: High-efficiency, synchronous step-down (buck) DC/DC regulator.
    • Package: 16-pin QFN (QFN2.5×2.5-16).
    • Input Voltage: 4.5 V to 24 V.
    • Output Current: Up to 6 A.
    • LDO Output: Features an internal fixed 3.3 V / 100 mA LDO.
    • Marking Format: The *** portion of the code represents tracing codes (production lot, year, and week) which change between manufacturing batches. [1, 2, 3]
    • 964758
      • Jul 2017
      • 44
      • Georgia
      Thank you very much for your help and for identifying the IC. This information was very useful for my diagnosis.
      • Geeker007
        Macbook Pro M2 Pro Liquid damage motherboard repair
        by Geeker007
        Hi All,
        I just got a Macbook Pro M2 Pro from marketplace for a repair project. There was no power, neither on Magsafe nor on all USB C. So there was PD negotiation as Magsafe led was not coming on at all. Its all dead. After opening the Macbook, I found liquid damage and I know exactly where there was a liquid damage.
        I have cleaned the motherboard properly with Isopropyl but looks like 2 of the SMD caps/res were blown so they came off while cleaning. I could see brown burn mark on the bottom plate as well.
        Can someone please let me know what are these...
        05-13-2026, 08:52 PM
      • av4x
        Fujitsu U7511 liquid damage, wont turn on anymore, does not respond to charger in any way.
        by av4x
        Good morning, everyone!
        I've gotten my hands on a few laptops with various defects because I want to get more involved in repairing electronics.
        First up is a Fujitsu Lifebook U7511.
        It won't turn on anymore and doesn't respond in any way when you plug in a power adapter.
        Model: Fujitsu Lifebook U7511
        CPU: Intel Core i5-1135G7
        GPU: Intel Iris Xe Graphics
        RAM: 16GB DDR4 - 3,200 MHz
        PCB manufacturer: ASKPCB?
        PCB serial numbers: CP801602, CP7984241-Z4, E239218, CP809978-01
        Damage: Liquid damage
        The liquid probably...
        11-01-2025, 03:09 AM
      • tommy97
        A2337 No power - Liquid damage 5V (820-02899-A)
        by tommy97
        Hi guys,
        We're having an issue with an A2337 following liquid damage.
        Both CD3217 ICs were severely liquid damaged, so we replaced them. Initially, UF400 was stuck at 5V 0A, while UF500 negotiated to 5V 0.2A and then restarted. FF200 measured 0V.
        We then replaced the PPVBUS_USBC0 diode, which restored 5V. However, the behaviour remains the same on both USB-C ports: current rises to 0.2A, stays there for a few seconds, and then drops back down.
        The laptop now powers on from the battery. With only the trackpad connected (and no battery attached),...
        06-14-2026, 04:22 AM
      • giulio93
        HP Victus 15-fb0002sl liquid damage
        by giulio93
        Hi everyone. I have this HP Victus mb DAG3PMB38A0 rev:A that has liquid damage. In particular water hit the USB-C area as you can see in the pics. I clean up the zone and 4 caps (i suppose caps) went of the board. I tried to power on the laptop and I have a 0,06A drawn and then stuck 0,014A. I check the main power line and I have the 19V after the input circuit current sensor. I have also 3,3 V around the EC chip. I unplagged the charger and check the coils. I notice the 1,7 Ohm coil next to the damage area. I injected 1V and the chip UP1666Q on the back of the board went hot. On the other way,...
        04-08-2026, 10:32 AM
      • Timp74
        Macbook Pro 14 M4 a3401 820-03400 Secure Element Liquid Damage...
        by Timp74
        Hi All. I have an A3401 820-03400 motherboard with liquid damage to the area of the board that has the Secure Element, display current sensor and TPAD_CONN I2C and microphone DMIC level shifters. Everything works but the fans ramp up to full speed once MacOS is booted. I've checked the power and signals on all damaged IC, everything looks okay with the exception of the Secure Element which dosen't have 1.8v on any of the 4 VDD* caps(C5009/C5010/C5015/C5016). I can't find much information on the Secure Element, although ApplePay stores cards okay. Could the Secure Element be the cause of the...
        03-25-2026, 01:17 AM
