G62-B15SV northbridge problems
  • lefos
    • Nov 2013
    • 321
    • Greece
    Hello everybody,
    Need your help on this one please. A friend of mine brought with problem no picture. Saw that it had the notorious 216-0752001 (amd cpu + external vga), so I have changed the NB with a new one. I am pretty sure that it is soldered very well. When you connect the ac adaptor it powers on by itself and fan turns at high speed then slows down. No picture on LCD / VGA output. Have tried other CPU. The original one was manufactured on 2010 but the new one 2014. Is it possible that it might need a bios update or do you have any suggestion?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: G62-B15SV northbridge problems
    yes. no postcard?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      I have seen this before. Sometimes when the NB goes bad the BIOS gets corrupted as well. Try a BIOS reflash before anything else.
      A working TV? How boring!
      • lefos
        • Nov 2013
        • 321
        • Greece
        Thanks for your replies. Is it possible for anyone to have the bios of this please?
        • marioo
          • Sep 2014
          • 8
          • croatia
          hi
          I have same problem but i bought refurbished motherboard from china.
          Problem with that motherboard is same like yours i also tried with new processor , and they told that i try to connect only processor and ram ,no result boot picture sometimes come but very rarely. After that they said it is probably cooling on gpu but it is problem with refurbishing that wasn't good done
          • degutji
            • Dec 2012
            • 173
            • Indonesia
            Try this https://www.badcaps.net/forum/showthread.php?t=36823
            • lefos
              • Nov 2013
              • 321
              • Greece
              Thanks for the link. Got lazy to search. My programmer can't recognize the chip so I guess it is off. I will order one and get back to you with the results.
              • lefos
                • Nov 2013
                • 321
                • Greece
                I have received the bios chip but the bios file wasn't correct.
                My mother board is PM_A_HPC_S MV_MB_V1 - 610160-001.
                Ι have found this http://1bios.ru/bios/notebook/hp/g-series/hp-g62-b14er after re-programmaning it the laptop powers on immediately with fan turning full speed, afterwards turns normally, with no picture on panel / external monitor.
                Any ideas please?
                • jean luc ferre
                  laptop hp g72 b52sf screen problems
                  by jean luc ferre
                  on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                  the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                  i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                  i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                  06-07-2025, 03:27 PM
                • Hondaman
                  USB problems?
                  by Hondaman
                  Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                  (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                  I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                  08-12-2024, 03:26 PM
                • clabr
                  Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                  by clabr
                  Need help to solve some problems with this laptop.
                  After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                  After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                  Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                  Before this had happened I observed some other problems:
                  When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                  12-02-2021, 08:09 AM
                • ohren
                  What problems could this blown cap cause in a Marantz SR5400?
                  by ohren
                  I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
                  R533 right below it in the photo is charred, but measures the correct value.
                  1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
                  10-21-2025, 09:02 AM
                • jean luc ferre
                  display screen problems after changing motherboard
                  by jean luc ferre
                  First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
                  I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
                  Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
                  Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
                  09-11-2025, 10:28 AM
