HP Pavilion 15S-FQ motherboard DA0P5HMB8J0 Rev J missing S5_ON
  • Serbentas
    • Sep 2016
    • 27
    HP Pavilion 15S-FQ motherboard DA0P5HMB8J0 Rev J missing S5_ON.
    Laptop gets 19V, light on, charges battery. No 3V and 5V because no S5_ON to enable them as far as I understand. Don't mind changing EC but Bios chip doesn't get 3V on pin 8 so how it will get firmware loaded?
    No shorts anywhere
    Please, any help anyone?
  • mon2
    • 16421
    Does this board have a RTC coin cell battery? Replace it if yes. If not, test with a known good battery pack.
    Which charger IC is onboard? Is there a schematic for this board? If not, share the details of the battery charger IC and then need the measurements from this charger IC for a review.
    VCC
    ACDET
    ACOK
    REGN (if applicable)
    • Serbentas
      • Sep 2016
      • 27
      Don't think it has RTC battery. Its newer Intel i5 11th gen board. You mean get a new battery? Even if charging light changes to red and battery is charged? Sure, can order one.
      Charging IC is BQ24728H. Attaching schematic shot.
      VCC-19v
      ACDET-2v
      ACOK-no such a line, I guess its newer IC
      REGN-3.1v
      • mon2
        • 16421
        Hold off on the battery sourcing.
        This is ACPRES on your charger IC. What is the voltage to ground of pin #5 on the charger IC?
        REGN-3.1v
        Can you confirm this again? It should be ~6v. If still around 3v, remove all power -> meter in resistance mode -> test the resistance to ground of this REGN pin. Testing if there is a short on this low current rail.
        ACDET-2v
        Confirm this one too. It is too low and should be 2v4 or higher.
        Are you using the official and proper rated power adapter on this unit?
        • Serbentas
          • Sep 2016
          • 27
          ACPRES-3.01v
          REGN-6v (sorry, before was measuring wrong pin)
          ACDET-2.02v
          Yes, using proper HP charger
          • mon2
            • 16421
            Better measurements. Still concerned about ACDET which is often required to be > 2v4 to accept the adapter as a valid power source.
            What is the voltage to ground of ACDRV pin #4 on this charger IC? This must be ~25v to enable the DCin power path mosfets which in turn will power the always on 5v and 3v3 missing power rails.
            • Serbentas
              • Sep 2016
              • 27
              Tried different power on board (contains switch on button) and now it starts , fan spins but no display. Caps lock light blinking 3 long 2 shorts
              • Serbentas
                • Sep 2016
                • 27
                One ram module or slot-works now fine with one. Thanks Mon ! Will look at other but that's basic. So on old power on board was missing mosfet:
