Hi, I have a Dell Latitude 5410 motherboard (LA-J37), REV A00 PWB P/N 8578V.
I'm building a custom setup similar to a tablet but without touch capability by attaching this motherboard to the back of a USB-C monitor without the chassis. I have several critical questions before proceeding:
First, does my specific motherboard revision REV A00 PWB 8578V support USB-C power delivery charging, in order to be able to use the external monitor with just one usb c cable for both charging and receiving the image from the mb? I've read conflicting information suggesting some 5410 variants lack the PD feature despite being the same model.
Second, I'm planning to buy a replacement power button fingerprint reader module to be able to power on the mb. Can I use it standalone by just plugging the connector into the motherboard and pressing the button manually, or does it require the full palmrest assembly to function? Otherwise, is there a BIOS option to enable autoboot on plugging a usb c charger (or at least on plugging the barrel jack connector charger)?
Third, which two pins on the SWME1 connector should I short to power on the motherboard without a physical power button? There are three pins but no inscription as to which is power on, suspend, ground or otherwise.
Thank you very much for your help.
