Strange Issue After A2681 Panel Only LCD Replacement
  • Teeheeze
    • Mar 2021
    • 21
    Hey everyone,
    I have a pretty strange issue I've experienced w/ 2 different A2681 2022 MacBook Air 13" devices now.
    The problem occurs after I replace the LCD panel on the screen assembly (panel only repair). After the repair and being assembled, I'll power on the device and you'll see the backlight illuminate, but the image on the LCD panel itself remains black. Once the keyboard backlights light up and the device boots to the macOS login screen, if I close and re-open the lid, then TADA.. The image comes up perfectly and the device continues to function normally until it is fully shutdown again. I've discussed this with the vendor and at first was told this was an issue with the lid angle sensor, but I've replaced it on both and the issue continues to occur. Also, the angle sensor functions perfectly when the lid is closed or opened (the backlight turns off and on when you close and open the screen respectively) so I don't think it has anything to do with the lid angle sensor. The issue returns when the device is fully shutdown or restarted, and you can always get the display to function perfectly by just closing and re-opening the lid after the device boots up.
    Does anyone have any suggestions or know why this is occurring? It seems to only happen on certain A2681 MacBook Airs because I've repaired several and only 2 have had this issue.
    I have a Google Drive link I can add of a video showing exactly what's happening.
    Thank you!
  • devicefixer
    • Feb 2026
    • 41
    • China
    Originally posted by Teeheeze
    Hey everyone,
    Thank you!
    This issue you're having is really strange and definitely hard to troubleshoot. I feel it's better to just stick to a simple train of thought to tackle this: is it possible that the screen itself is flawed or has a hidden defect?
    First, you have to be absolutely sure the screen is not the problem. As far as I know, original pulled screens are priced differently based on their quality grades. Of course, we can't rule out the probability of encountering defective ones even within the same quality grade. What I mean is, you could try buying a higher-priced screen, or get one from a seller with a higher reputation rating to test it again. That's really the only way, but just make sure they support no-reason returns and refunds first.
    There is another method: for the original screen you took off the customer's laptop, is it just physically cracked but still able to light up normally? If it can still light up, you can plug that broken screen back in to see if it turns on normally from a completely powered-off state, or if it shows the exact same symptom you are dealing with now.
    We have to completely rule out the screen before making any further deductions, otherwise this problem is just too difficult to trace. After all, it's highly unlikely that a perfectly normal machine would suddenly have a logic board issue out of nowhere, right?
    • Teeheeze
      • Mar 2021
      • 21
      So this is not an original screen. It is a panel only replacement, meaning I'm using the original backlight panel and diffuser and have replaced the LCD panel. I've done this numerous times on A2681 MBAs and haven't had any issues with the panels, other than 2 devices w/ the exact same issue. At first I thought it could be I needed to chip swap from the original panel to the replacement panel like we used to do, but that shouldn't be necessary with the latest macOS. Also, to answer your question, I thought about the same thing and plugged the original LCD panel back in to test and the issue disappears. That is why this is so strange. It's acting the same as an issue with the lid-angle sensor but I've replaced that on both devices and the same thing occurs. From the research I've done, it's possible that the calibration info for the LCD panel from the factory is causing an issue since the panel may be from a different manufacturer.
      To make absolutely sure it's not the lid-angle sensor, I've ordered a replacement from Apple that should be here in a day or two (hopefully). I'm not very optimistic that it will resolve the issue but I'm not unfolding the LCD panel's flex from it's adhered state to swap the chips on this because the panel will almost certainly crack from just trying to remove the flex cable and it's not worth the $150 or so for the panel to try. Just hoping that someone has another idea that I haven't thought of.
      Thanks for the response!
      • devicefixer
        • Feb 2026
        • 41
        • China
        I know you didn't replace it with an original screen, and I know you only replaced the LCD panel itself, not the entire screen assembly. What I mean is, is it possible that the panel you bought has an issue? Since plugging the original cracked screen back in makes the issue disappear, that means everything else on the laptop is perfectly normal. It only started acting this way after you swapped the panel.
        You also mentioned you've always done replacements this way before, and it's only these last few times that this issue has popped up. You've probably been using panels bought from the exact same supplier this whole time, right? You also did some research, and it's very likely that this batch of screens from the supplier just has a compatibility or calibration issue. What are the odds that two completely separate MacBooks would develop the exact same lid-angle sensor fault at the exact same time? I also feel the same as you—ordering a replacement sensor probably has a very low chance of fixing it. So I still suggest you get this batch of screens exchanged. Normally, screen parts come with a warranty, right? If you install them and find an issue, you can usually just apply for a return or exchange directly.
        You could try buying another panel from that same supplier to test, or go to a different supplier and buy one that's a bit more expensive than your current one to see what happens. I mean, even if it is a sensor or panel issue like you suspect, and even if you confirm it, you can't possibly do a chip swap every single time you replace a screen, right?
        This... this is clearly just the screen and the logic board not being compatible. When I buy a screen, isn't the point that it should just work right when I install it? Am I supposed to replace a screen and then have to fix or swap another component myself just to make it work? It's not like this is some niche laptop model with an obscure screen where you have to do extra DIY part-swaps just to get it functioning normally. The market share for this model is massive!!
        There is no way this issue requires some crazy workaround. Otherwise, the forums and product reviews would be flooded with complaints, people would be raging over it!!
        • Teeheeze
          • Mar 2021
          • 21
          Yeah we've been using the same supplier. The strange issue is that I've replaced the panels on several A2681s w/ Tahoe installed that have not had the issue in-between the ones that have had this issue. Most of them are fine, but there have been 2 that have had this issue. I will be trying something today that was suggested that should wipe the calibration data away and hopefully resolve the issue. I'll update the post if it works.
          Appreciate the responses.
          • DIY Addict
            DELL S3220dgf Display Panel Replacement
            by DIY Addict
            My monitor's screen was damaged recently and I've been trying to figure out where I could, at the very least, consider replacing the screen to salvage an otherwise perfectly functional monitor. The LCD panel model is an LSM315DP03-C01 and I have found DP01/05 models, but I don't know whether or not these are compatible with the other hardware components. As it stands right now, I need to either figure out where I might be able to find a replacement panel OR whether or not a different panel version is something that would be something I could viably consider. Any assistance, insights, and perspectives...
            08-26-2026, 11:11 PM
          • sikorak666
            Macbook M4 Air 13" 16/256 memory replacement issue | 820-03597
            by sikorak666
            I'm hoping someone here can shed some light on this issue I'm dealing with.
            I recently bought a MacBook Air M4 13" with the base 256GB storage (16GB RAM). As you can probably guess, the storage quickly became a problem, so I decided to look into an upgrade. I found a company that offers post-warranty repair services for Apple computers, and they specifically advertise SSD upgrade services. They ordered 2TB NAND chips for the replacement.
            Here's the problem: after the installation, the computer doesn't see the new storage and won't boot....
            06-16-2026, 09:29 AM
          • ezenia
            PS4 controller left stick potentiometer replacement issue
            by ezenia
            Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
            So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
            I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
            09-30-2023, 02:19 PM
          • JayFixesIT
            LG 65UH9500 TV Panel replacement seal?
            by JayFixesIT
            I am in the process of replacing the backlight boards on the LG 65UH9500 TV. It requires the separation of the front glass/panel to get to the boards. The panel is help on to the frame with some kind of strips that I cannot reuse to adhere the screen to the frame. Anyone have any experience/Ideas on what I can use to securely hold the 65" Panel to the frame. I would hate for the panel to fall face forward. Thank you in advance....
            09-08-2024, 11:15 AM
          • Ancient1
            I'm stuck . Panasonic TH-L32U20M panel's boards issue
            by Ancient1
            Hi
            The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
            Actions :
            1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
            1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
            Obviously the fault is from or on the Right, secondary board
            2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...
            09-03-2023, 03:51 AM
