The ferrite bead for the camera power rail is the one worth the first review. Test the voltage and also the resistance across this device (without power to the board).
Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
Apple macbook air A2337 camera refuses to work,
The camera is a MIPI CSI interfaced device. Respectively, each MIPI CSI linked component is a suspect. Confirm the EMI filters are present on the MIPI camera lines. One for the camera data lines; one for the camera clock lines. Confirm the power rail for the camera is present.
Hey, I have a macbook air M1 A2337 i replaced the display on using an AM display from MobileSentrix for a customer they returned because the camera wasn't working i tried another display from mobile sentrix still no camera, updated the software still nothing, i just took a display off our store macbook and no display still calibrated it using self repair and still no camera, so I have come to the conclusion its a board issue, any else ever encounter this, or any ideas on where to look on the board for shorts or anything.Tags: None
Apple MacBook Pro 13 M1 820-02020-A boardview 820-02020 V1.0 Boardview
Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB
Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Physical scanning image
Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Location map...-
Channel: Schematics and Boardviews
Apple MacBook Pro 17" A1150 Daughter Board
Camera Sensor Board M9 Proto 820-1920 051-6978 Schematic...-
02-12-2026, 06:32 AM -
by berlincapsDear BADCAPS Forum,
I am happy to have found this place and would love to get some input on my issues with a MacBook Air M1 (A2337).
A couple of days ago, I was using the MacBook on a low battery, and while running VS Code it shut down due to low battery. I rarely let it reach the point where it turns itself off, and if it does, I usually charge it immediately. This time, however, I left it uncharged until the next evening, and when I plugged it in, nothing happened. I waited until the following day, and still nothing.
I followed all the recommended troubleshooting... -
by SkrndeljHello all,
I am repairing a Macbook A2337 and i have a problem
The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
I inspected the whole board and everything seems fine.
Can anyone help me as i didn't fiddle with trackpad... -
Apple MacBook Air 13" M1 A2337 820-02016 Schematic & Board View...
- Loading...
