Goes to recovery when plugged in with another Mac, shows in finder with a question mark and serial number. When revived fails at error 9 (the laptop turns off and on?) In the Apple Configurator when in dfu, gives error restores device removed before restore completed 0xFAA (4010). Tried in intel and m1 based Macs.
History, came in with severe liquid damage and bubbly motherboard
Transplanted t2/ recalled ram, u4730, all 4 nands and u4770.
Below is the log from console, the usb meter negotiates at 19v and goes as high as 2.4A
Apr 1 08:36:25 macs-MBP UARPUpdaterServiceDisplay[1440]: Entered:_AMRecoveryDeviceConnected, libusbrestore-device:0x0x7fc96e71ea90
Apr 1 08:36:25 macs-MBP UARPUpdaterServiceDisplay[1440]: This is here just to make sure we empty our found devices queue
Apr 1 08:36:25 macs-MBP UARPUpdaterServiceDisplay[1440]: Entered:__thr_AMRecoveryDeviceConnected, libusbrestore-device:0x0x7fc96e71ea90
Apr 1 08:36:25 macs-MBP UARPUpdaterServiceDisplay[1440]: (null)
Apr 1 08:36:25 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Entered:_AMRecoveryDeviceConnected, libusbrestore-device:0x0x600003f2ab20
Apr 1 08:36:25 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Entered:__thr_AMRecoveryDeviceConnected, libusbrestore-device:0x0x600003f2ab20
Apr 1 08:36:25 macs-MBP com.apple.configurator.xpc.DeviceService[831]: failed to get board config from recovery mode device
Apr 1 08:36:25 --- last message repeated 1 time ---
Apr 1 08:36:25 macs-MBP MobileDeviceUpdater[770]: Entered:_AMRecoveryDeviceConnected, libusbrestore-device:0x0x7fad05f19ce0
Apr 1 08:36:25 macs-MBP AMPDeviceDiscoveryAgent[827]: Entered:_AMRecoveryDeviceConnected, libusbrestore-device:0x0x7fdf23a0ac40
Apr 1 08:36:25 macs-MBP AMPDeviceDiscoveryAgent[827]: Entered:__thr_AMRecoveryDeviceConnected, libusbrestore-device:0x0x7fdf23a0ac40
Apr 1 08:36:25 macs-MBP MobileDeviceUpdater[770]: Entered:__thr_AMRecoveryDeviceConnected, libusbrestore-device:0x0x7fad05f19ce0
Apr 1 08:37:52 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Entered:_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x600003f2ab20
Apr 1 08:37:52 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Entered:__thr_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x600003f2ab20
Apr 1 08:37:52 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Recovery mode device disconnected
Apr 1 08:37:52 macs-MBP MobileDeviceUpdater[770]: Entered:_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x7fad05f19ce0
Apr 1 08:37:52 macs-MBP MobileDeviceUpdater[770]: Entered:__thr_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x7fad05f19ce0
Apr 1 08:37:52 macs-MBP MobileDeviceUpdater[770]: Recovery mode device disconnected
Apr 1 08:37:52 macs-MBP AMPDeviceDiscoveryAgent[827]: Entered:_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x7fdf23a0ac40
Apr 1 08:37:52 macs-MBP UARPUpdaterServiceDisplay[1440]: Entered:_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x7fc96e71ea90
Apr 1 08:37:52 macs-MBP AMPDeviceDiscoveryAgent[827]: Entered:__thr_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x7fdf23a0ac40
Apr 1 08:37:52 macs-MBP UARPUpdaterServiceDisplay[1440]: Entered:__thr_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x7fc96e71ea90
Apr 1 08:37:52 macs-MBP AMPDeviceDiscoveryAgent[827]: Recovery mode device disconnected
Apr 1 08:37:52 macs-MBP UARPUpdaterServiceDisplay[1440]: Recovery mode device disconnected
Apr 1 08:37:53 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Entered:_AMDFUDeviceConnected, libusbrestore-device:0x0x600003528780
Apr 1 08:37:53 macs-MBP com.apple.configurator.xpc.DeviceService[831]: _findMatchingLocationID: Failure to create 'locationID' property from IORegistryEntry
Apr 1 08:37:53 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Can't send blind command since device is not in recovery mode
Apr 1 08:37:53 macs-MBP com.apple.configurator.xpc.DeviceService[831]: failed to get board config from DFU mode device
Apr 1 08:37:54 --- last message repeated 1 time ---
Apr 1 08:37:54 macs-MBP AMPDeviceDiscoveryAgent[827]: Entered:_AMDFUDeviceConnected, libusbrestore-device:0x0x7fdf23810f80
Apr 1 08:37:54 macs-MBP MobileDeviceUpdater[770]: Entered:_AMDFUDeviceConnected, libusbrestore-device:0x0x7fad06a50510
Apr 1 08:37:54 macs-MBP UARPUpdaterServiceDisplay[1440]: Entered:_AMDFUDeviceConnected, libusbrestore-device:0x0x7fc96e71e9c0
Apr 1 08:37:54 macs-MBP MobileDeviceUpdater[770]: _findMatchingLocationID: Failure to create 'locationID' property from IORegistryEntry
Apr 1 08:37:54 macs-MBP UARPUpdaterServiceDisplay[1440]: _findMatchingLocationID: Failure to create 'locationID' property from IORegistryEntry
Apr 1 08:37:54 macs-MBP AMPDeviceDiscoveryAgent[827]: _findMatchingLocationID: Failure to create 'locationID' property from IORegistryEntry
Apr 1 08:37:54 macs-MBP com.apple.configurator.xpc.DeviceService[831]: failed to get board config from DFU mode device
Apr 1 08:38:04 --- last message repeated 3 times ---
Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Created state machine for device with ECID=0x1229991E608026
Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: State Machine Dump, status:RUNNING - [state
FU remaining-cycles:2 (current state)] -> [state:Recovery remaining-cycles:2] -> [state:RestoreOS remaining-cycles:1]
Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: DFU mode device can't get board config with NULL device map
Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: failed to get board config from DFU mode device
Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: failed to get serial number from DFU mode device
Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: AMRestorableDeviceCopyPSDProbe: Failure to locate probe for [0x14300000] in IORegistry
Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Could not find parent entry!
Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Could not get builtin port for service 44819
Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: amai: AMAuthInstallBundleCopyBuildIdentityForVariant: AMAuthInstallBundleCopyBuildIdentityForVariant: Found variant: Customer Upgrade Install (IPSW)
Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Failed to create recovery OS variant , no recovery variant in options nor restore variant.
Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: amai: AMAuthInstallBundleCopyBuildIdentityForVariant: variant not specified, will use first variant found for this device in build manifest
Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: amai: AMAuthInstallBundleCopyBuildIdentityForVariant: AMAuthInstallBundleCopyBuildIdentityForVariant: Found variant: Customer Erase Install (IPSW)
Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Couldn't find recovery OS variant in the restore variant based on the behavior based variant.
Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: no override trust object found
Apr 1 08:38:05 --- last message repeated 1 time ---
Apr 1 08:38:05 macs-MBP com.apple.configurator.xpc.DeviceService[831]: amai: AMAuthInstallApImg4CopyPayloadVersionProperty: failed to parse version property: 1952607603, error:1
Apr 1 08:38:05 macs-MBP com.apple.configurator.xpc.DeviceService[831]: amai: AMAuthInstallApImg4CreateMeasurementsWithTag: could not get tbms property, status:23
Apr 1 08:38:05 macs-MBP com.apple.configurator.xpc.DeviceService[831]: amai: AMAuthInstallApImg4CopyPayloadVersionProperty: failed to parse version property: 1952607602, error:1
Apr 1 08:38:05 macs-MBP com.apple.configurator.xpc.DeviceService[831]: amai: AMAuthInstallApImg4CreateMeasurementsWithTag: could not get tbmr property, status:23
Apr 1 08:38:05 macs-MBP com.apple.configurator.xpc.DeviceService[831]: amai: AMAuthInstallRequestSendSyncWithHeader: SSO function returned NULL and no SSO token was provided, SSO disabled.
Apr 1 08:38:05 macs-MBP com.apple.configurator.xpc.DeviceService[831]: amai: AMAuthInstallRequestSendSyncWithHeader: received tss response (server version: 2.1.0)
Apr 1 08:38:05 macs-MBP com.apple.configurator.xpc.DeviceService[831]: <DFU Device 0x600003528780>: production fused device
Apr 1 08:38:06 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Entered:_AMDFUDeviceDisconnected, libusbrestore-device:0x0x600003528780
Apr 1 08:38:06 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Entered:__thr_AMDFUDeviceDisconnected, libusbrestore-device:0x0x600003528780
Apr 1 08:38:06 macs-MBP com.apple.configurator.xpc.DeviceService[831]: DFU mode device disconnected
Apr 1 08:38:06 macs-MBP AMPDeviceDiscoveryAgent[827]: Entered:_AMDFUDeviceDisconnected, libusbrestore-device:0x0x7fdf23810f80
Apr 1 08:38:06 macs-MBP AMPDeviceDiscoveryAgent[827]: Entered:__thr_AMDFUDeviceDisconnected, libusbrestore-device:0x0x7fdf23810f80
Apr 1 08:38:06 macs-MBP UARPUpdaterServiceDisplay[1440]: Entered:_AMDFUDeviceDisconnected, libusbrestore-device:0x0x7fc96e71e9c0
Apr 1 08:38:06 macs-MBP AMPDeviceDiscoveryAgent[827]: DFU mode device disconnected
Apr 1 08:38:06 macs-MBP UARPUpdaterServiceDisplay[1440]: Entered:__thr_AMDFUDeviceDisconnected, libusbrestore-device:0x0x7fc96e71e9c0
Apr 1 08:38:06 macs-MBP UARPUpdaterServiceDisplay[1440]: DFU mode device disconnected
Apr 1 08:38:06 macs-MBP MobileDeviceUpdater[770]: Entered:_AMDFUDeviceDisconnected, libusbrestore-device:0x0x7fad06a50510
Apr 1 08:38:06 macs-MBP MobileDeviceUpdater[770]: Entered:__thr_AMDFUDeviceDisconnected, libusbrestore-device:0x0x7fad06a50510
Apr 1 08:38:07 macs-MBP MobileDeviceUpdater[770]: DFU mode device disconnected
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Entered:_AMRecoveryDeviceConnected, libusbrestore-device:0x0x600003f29860
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Entered:__thr_AMRecoveryDeviceConnected, libusbrestore-device:0x0x600003f29860
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Recovery mode device connected
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: amai: AMAuthInstallBundleCopyBuildIdentityForVariant: AMAuthInstallBundleCopyBuildIdentityForVariant: Found variant: Customer Upgrade Install (IPSW)
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: _AMRUSBDeviceSendDeviceRequestTO_block_invoke: AMRUSBDevice error (-536854449): {
"Error message" = "DeviceRequest failed: 0xe000404f (IOKit return code). DeviceRequest was index: 0, direction: 0, requestType: 2, recipient: 0, request: 0, value: 0, length: 12, noDataTO: 60000, completionTO: 60000";
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: command device request for 'getenv anid' failed: 2008
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: no override trust object found
Apr 1 08:38:11 --- last message repeated 1 time ---
"Error message" = "DeviceRequest failed: 0xe000404f (IOKit return code). DeviceRequest was index: 0, direction: 0, requestType: 2, recipient: 0, request: 0, value: 0, length: 16, noDataTO: 60000, completionTO: 60000";
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: command device request for 'getenv ota-uuid' failed: 2008
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Failed to copy env variable, error:21
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: _AMRUSBDeviceSendDeviceRequestTO_block_invoke: AMRUSBDevice error (-536870195): {
"Error message" = "DeviceRequest failed: 0xe00002cd (IOKit return code). DeviceRequest was index: 1, direction: 0, requestType: 0, recipient: 1, request: 11, value: 0, length: 0, noDataTO: 5000, completionTO: 0";
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: error setting interface's alternate setting: 2001 (expected, not fatal).
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: unable to open device_map.txt: No such file or directory
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
"Error message" = "DeviceRequest failed: 0xe000404f (IOKit return code). DeviceRequest was index: 0, direction: 0, requestType: 2, recipient: 0, request: 0, value: 0, length: 19, noDataTO: 60000, completionTO: 60000";
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: command device request for 'getenv radio-error' failed: 2008
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: <Recovery Mode Device 0x600003f29860>: production fused device
"Error message" = "DeviceRequest failed: 0xe000404f (IOKit return code). DeviceRequest was index: 0, direction: 0, requestType: 2, recipient: 0, request: 0, value: 0, length: 18, noDataTO: 60000, completionTO: 60000";
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: command device request for 'getenv boot-stage' failed: 2008
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: amai: _CFDictionaryGetBoolean: dict is NULL
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Failed to get URL for key: RestoreLogo
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Failed to locate boot graphic
Apr 1 08:38:11 macs-MBP com.apple.configurator.xpc.DeviceService[831]: No additional boot images found
Apr 1 08:38:11 macs-MBP MobileDeviceUpdater[770]: Entered:_AMRecoveryDeviceConnected, libusbrestore-device:0x0x7fad06963020
Apr 1 08:38:11 macs-MBP AMPDeviceDiscoveryAgent[827]: Entered:_AMRecoveryDeviceConnected, libusbrestore-device:0x0x7fdf22f28eb0
Apr 1 08:38:11 macs-MBP UARPUpdaterServiceDisplay[1440]: Entered:_AMRecoveryDeviceConnected, libusbrestore-device:0x0x7fc96e723850
Apr 1 08:38:11 macs-MBP MobileDeviceUpdater[770]: Entered:__thr_AMRecoveryDeviceConnected, libusbrestore-device:0x0x7fad06963020
Apr 1 08:38:11 macs-MBP UARPUpdaterServiceDisplay[1440]: Entered:__thr_AMRecoveryDeviceConnected, libusbrestore-device:0x0x7fc96e723850
Apr 1 08:38:11 macs-MBP AMPDeviceDiscoveryAgent[827]: Entered:__thr_AMRecoveryDeviceConnected, libusbrestore-device:0x0x7fdf22f28eb0
Apr 1 08:38:15 macs-MBP com.apple.configurator.xpc.DeviceService[831]: unable to open device_map.txt: No such file or directory
Apr 1 08:38:15 macs-MBP com.apple.configurator.xpc.DeviceService[831]: _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
Apr 1 08:38:15 macs-MBP com.apple.configurator.xpc.DeviceService[831]: _AMRUSBDeviceSendDeviceRequestTO_block_invoke: AMRUSBDevice error (-536854449): {
"Error message" = "DeviceRequest failed: 0xe000404f (IOKit return code). DeviceRequest was index: 0, direction: 0, requestType: 2, recipient: 0, request: 0, value: 0, length: 21, noDataTO: 60000, completionTO: 60000";
Apr 1 08:38:15 macs-MBP com.apple.configurator.xpc.DeviceService[831]: command device request for 'getenv ramdisk-delay' failed: 2008
Apr 1 08:38:19 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Entered:_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x600003f29860
Apr 1 08:38:19 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Entered:__thr_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x600003f29860
Apr 1 08:38:19 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Recovery mode device disconnected
Apr 1 08:38:19 macs-MBP MobileDeviceUpdater[770]: Entered:_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x7fad06963020
Apr 1 08:38:19 macs-MBP AMPDeviceDiscoveryAgent[827]: Entered:_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x7fdf22f28eb0
Apr 1 08:38:19 macs-MBP MobileDeviceUpdater[770]: Entered:__thr_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x7fad06963020
Apr 1 08:38:19 macs-MBP UARPUpdaterServiceDisplay[1440]: Entered:_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x7fc96e723850
Apr 1 08:38:19 macs-MBP UARPUpdaterServiceDisplay[1440]: Entered:__thr_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x7fc96e723850
Apr 1 08:38:19 macs-MBP AMPDeviceDiscoveryAgent[827]: Entered:__thr_AMRecoveryDeviceDisconnected, libusbrestore-device:0x0x7fdf22f28eb0
Apr 1 08:38:19 macs-MBP MobileDeviceUpdater[770]: Recovery mode device disconnected
Apr 1 08:38:19 macs-MBP UARPUpdaterServiceDisplay[1440]: Recovery mode device disconnected
Apr 1 08:38:19 macs-MBP AMPDeviceDiscoveryAgent[827]: Recovery mode device disconnected
Apr 1 08:38:21 macs-MBP com.apple.configurator.xpc.DeviceService[831]: RestoreOS mode device connected
Apr 1 08:38:23 macs-MBP com.apple.configurator.xpc.DeviceService[831]: amai: AMAuthInstallBundleCopyBuildIdentityForVariant: AMAuthInstallBundleCopyBuildIdentityForVariant: Found variant: Customer Upgrade Install (IPSW)
Apr 1 08:38:23 macs-MBP com.apple.configurator.xpc.DeviceService[831]: no override trust object found
Apr 1 08:38:23 --- last message repeated 1 time ---
Apr 1 08:38:23 macs-MBP com.apple.configurator.xpc.DeviceService[831]: overwrite InstallDiags to false
Apr 1 08:38:23 macs-MBP com.apple.configurator.xpc.DeviceService[831]: unable to open device_map.txt: No such file or directory
Apr 1 08:38:23 macs-MBP com.apple.configurator.xpc.DeviceService[831]: no value returned for BootArgs
Apr 1 08:38:23 macs-MBP com.apple.configurator.xpc.DeviceService[831]: _copyDeviceProperty() failed for restore bootargs
Apr 1 08:38:23 macs-MBP com.apple.configurator.xpc.DeviceService[831]: no value returned for MarketingPartNumber
Apr 1 08:38:23 macs-MBP com.apple.configurator.xpc.DeviceService[831]: _copyDeviceProperty() failed for mpn
Apr 1 08:38:23 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Can't return padding information since it's not in the Restore.plist, looking in BuildManifest.plist
Apr 1 08:38:23 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Established SOCKS proxy for device
Apr 1 08:38:34 macs-MBP com.apple.configurator.xpc.DeviceService[831]: amai: _CFDictionaryGetBoolean: dict is NULL
Apr 1 08:38:36 --- last message repeated 4 times ---
Apr 1 08:38:36 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Entered:_AMMuxedDeviceDisconnected, mux-device:10
Apr 1 08:38:36 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Entered:__thr_AMMuxedDeviceDisconnected, mux-device:10
Apr 1 08:38:36 macs-MBP com.apple.configurator.xpc.DeviceService[831]: RestoreOS mode device disconnected
Apr 1 08:38:36 macs-MBP MobileDeviceUpdater[770]: Entered:_AMMuxedDeviceDisconnected, mux-device:10
Apr 1 08:38:36 macs-MBP AMPDeviceDiscoveryAgent[827]: Entered:_AMMuxedDeviceDisconnected, mux-device:10
Apr 1 08:38:36 macs-MBP MobileDeviceUpdater[770]: Entered:__thr_AMMuxedDeviceDisconnected, mux-device:10
Apr 1 08:38:36 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Invalid remote service device ref.
Apr 1 08:38:36 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Invalid ECID passed to make key with
Apr 1 08:38:36 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Failed to create ecid key for RSD device
Apr 1 08:38:36 macs-MBP MobileDeviceUpdater[770]: RestoreOS mode device disconnected
Apr 1 08:38:36 macs-MBP AMPDeviceDiscoveryAgent[827]: Entered:__thr_AMMuxedDeviceDisconnected, mux-device:10
Apr 1 08:38:36 macs-MBP AMPDeviceDiscoveryAgent[827]: RestoreOS mode device disconnected
Apr 1 08:38:37 macs-MBP MobileDeviceUpdater[770]: Invalid remote service device ref.
Apr 1 08:38:37 macs-MBP MobileDeviceUpdater[770]: Invalid ECID passed to make key with
Apr 1 08:38:37 macs-MBP MobileDeviceUpdater[770]: Failed to create ecid key for RSD device
Apr 1 08:38:37 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Entered:_AMDFUDeviceConnected, libusbrestore-device:0x0x6000035295c0
Apr 1 08:38:37 macs-MBP com.apple.configurator.xpc.DeviceService[831]: DFU mode device connected
Apr 1 08:38:37 macs-MBP AMPDeviceDiscoveryAgent[827]: Entered:_AMDFUDeviceConnected, libusbrestore-device:0x0x7fdf22f28eb0
Apr 1 08:38:37 macs-MBP com.apple.configurator.xpc.DeviceService[831]: State is now set to error: RestoreOS device removed before restored completed
Apr 1 08:38:37 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Device isn't booted but USB is up.
Apr 1 08:38:37 macs-MBP com.apple.configurator.xpc.DeviceService[831]: RestoreOS device removed before restored completed
Apr 1 08:38:37 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Can't set NULL log URL for log
Apr 1 08:38:37 --- last message repeated 2 times ---
Apr 1 08:38:37 macs-MBP com.apple.configurator.xpc.DeviceService[831]: Can't send blind command since device is not in recovery mode
Apr 1 08:38:37 macs-MBP com.apple.configurator.xpc.DeviceService[831]: failed to get board config from DFU mode device
Apr 1 08:38:37 --- last message repeated 1 time ---
Apr 1 08:38:37 macs-MBP AMPDeviceDiscoveryAgent[827]: _findMatchingLocationID: Failure to create 'locationID' property from IORegistryEntry
Apr 1 08:38:37 macs-MBP UARPUpdaterServiceDisplay[1556]: Entered:_AMDFUDeviceConnected, libusbrestore-device:0x0x7fb8ed712340
Apr 1 08:38:37 macs-MBP UARPUpdaterServiceDisplay[1556]: This is here just to make sure we empty our found devices queue
Apr 1 08:38:37 macs-MBP UARPUpdaterServiceDisplay[1556]: _findMatchingLocationID: Failure to create 'locationID' property from IORegistryEntry
Apr 1 08:38:37 macs-MBP UARPUpdaterServiceDisplay[1556]: (null)
Apr 1 08:38:38 macs-MBP com.apple.configurator.xpc.DeviceService[831]: failed to get board config from DFU mode device
Apr 1 08:38:38 --- last message repeated 1 time ---
FU remaining-cycles:2 (current state)] -> [state:Recovery remaining-cycles:2] -> [state:RestoreOS remaining-cycles:1]Apr 1 08:38:04 macs-MBP com.apple.configurator.xpc.DeviceService[831]: DFU mode device can't get board config with NULL device map
