Acer Aspire E1-531 Not powering ON with AC adapter.
  • shijeesh
    • Mar 2011
    • 65
    Dear Technical Team,
    Acer Aspire E1-531 Not powering ON with AC adapter, but it powering ON with Battery . The 19v is only in PQ9 Drain and 0v in PQ9 Source and 0.4v in Gate terminal. Charging IC BQ24725ARGRR.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3582
    • slovakia
    Re: Acer Aspire E1-531 Not powering ON with AC adapter.
    this ic is sooooo faulty that i bet your is bad. have 5 laptop in a row with that bad chip.
    if wanna run system without it/no battery charging, no battery/, just inject 19V to base of first mosfet, or to 4th pin of this ic /ACDRV/
    ofcourse as first check if u have acdet and acok signals that detects adapter
    • shijeesh
      • Mar 2011
      • 65
      BQ24725 pin 5 ACOK = 0v and pin 6 ACDET=2.5v . Sometime its working PQ9 Gate voltage is 25.4v that time battery charging is ok
      • shijeesh
        • Mar 2011
        • 65
        Sir please reply
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3582
          • slovakia
          my only reply is to change it. im allready waiting for new pieces if this ic.
          i just inject 19v to acdrv signal, working without battery and waiting for new chips
          • shijeesh
            • Mar 2011
            • 65
            I need expert help for solve it.
            • Ikung
              • Nov 2013
              • 34
              • Malaysia
              try replace pq9
              • Shadow255
                • South Africa
                I have exactly the same problem as shijeesh:
                ACOK = 0v
                ACDET=2.5v
                VCC (on bq24725A) = 19V
                ACDRV pulses (1Hz, 4V peak, 2.5ms width)
                When pulsed, one can see the voltage at Vin being carried through to P1 (after PQ9) and also to P2 (after PQ10).
                I do not understand why ACOK does not reflect the presence of power. The datasheet for bq24725A state the following requirement for ACOK to go high:
                AC adapter detection open drain output. It is pulled HIGH to external pull-up supply rail by external pull-up resistor when voltage on ACDET pin is between 2.4V and 3.15V, and voltage on VCC is above UVLO and voltage on VCC pin is 275mV above voltage on SRN pin, indicating a valid adapter is present to start charge. If any one of the above conditions can not meet, it is pulled LOW to GND by internal MOSFET. Connect a 10kΩ pull up resistor from ACOK to the pull-up supply rail
                Any ideas?
                • shijeesh
                  • Mar 2011
                  • 65
                  Replace PQ9 and PQ10
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    Also,
                    A common protection method used in most laptop designs is a diode between the ACDET pin and the Vbatt rail. A resistor bleeds a small current to the Vbatt rail which normally causes the voltage to rise. If there is a short or leakage to ground, the voltage doesn't rise enough causing the diode to keep the ACDET pin too low.
                      Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
                      This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                      09-06-2024, 05:27 AM
                      Acer Aspire LAPTOP ASPIRE 5 A517-52-58VS Notebook 5 Specification for Upgrade or Repair
                      This specification for the Acer Aspire LAPTOP ASPIRE 5 A517-52-58VS Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LAPTOP ASPIRE 5 A517-52-58VS boardview and LAPTOP ASPIRE 5 A517-52-58VS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                      09-07-2024, 05:50 AM
                      Acer Aspire Aspire XC-340 PC XC Specification for Upgrade or Repair
                      This specification for the Acer Aspire Aspire XC-340 PC can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire XC-340 boardview and Aspire XC-340 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                      09-07-2024, 02:00 AM
                      ACER Aspire Aspire TC-886 Aspire TC i7-9700 Specification for Upgrade or Repair
                      This specification for the ACER Aspire Aspire TC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire TC-886 boardview and Aspire Aspire TC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-12-2024, 03:28 PM
                      ACER Aspire Aspire TC-885 Aspire TC i7-8700 Specification for Upgrade or Repair
                      This specification for the ACER Aspire Aspire TC-885 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire TC-885 boardview and Aspire Aspire TC-885 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
