Asus UX582Z no longer charges the battery
  • orasl
    • Jun 2025
    • 13
    • Epinac
    Hi Super BADCAPS :-)
    Today i have a challenge... New Asus UX582Z laptop with 2 screen.
    The motherboard is well powered and the charger is not in a short circuit. Before the computer no longer turns on, it no longer charges the battery, then once the battery runs out, the computer obviously does not turn on anymore.
    I noted several voltage points on the motherboard, but it seems that at the battery charge output the voltage is not correct.
    I have the impression that a mosfet does not open a few times because it lacks power on the main one while the power is ok on the rest of the motherboard.
    The computer’s motherboard is UX582ZS and attached are some photos and some photos with voltage annotations.
    I tried to follow the methods of your forum to eliminate possible defects of the motherboard, but without result.
    Do you have an idea?
    Thank you and have a nice day
  • mon2
    • 16068
    Review the mosfet near the DC adapter connector. Remove all power. Meter in resistance mode.
    Measure the resistance across this mosfet:
    source (1-2-3) & drain (5-6-7-8)
    source & gate (4)
    gate & drain
    Post each measurement. Each such measurement should be hundreds of k ohms or higher else is likely to be defective.
    • orasl
      • Jun 2025
      • 13
      • Epinac
      Hi from france Mon2
      and thank you for your help ! it is really very appreciated.
      The mosfet next to the DC adapet connector is PKCH2BB
      For source & drain measurement is 507 Ohms << defective ?
      source & gate 28 Ohms
      gate & drain 43 Ohms
      He might be the culprit!
      do you think I order this : https://www.ebay.fr/itm/365577747159...Bk9SR9it5sqoZw
      • mon2
        • 16068
        Yup! Waaaay too low of resistance values. Any chance you have an old motherboard at your disposal? This is a jellybean N-channel mosfet. If you can find the very common 5x6mm device on another motherboard, confirm it is N-channel and swap this part out.
        Also suggest to test the resistance to ground of each of these pins. That is, we want to confirm that there is not a shortd part downstream that caused this mosfet to become defective. From our experience, the branded mosfets are of higher quality than offshore generics used by motherboard companies. For example, the TI mosfet is a good choice but certainly hunt for old donor motherboards. The actual part number is not important but higher the current support (ie. low Rds value) - the better.
        Recommend to flux and remove this part. Allow it to cool down. Then measure the same pins while the mosfet is on your work bench. Suspecting that the measurements will remain low = mosfet is defective.
        While this part is off the board, proceed to test the resistance to ground of the pcb pads for this part. Checking if there is a short downstream.
        • orasl
          • Jun 2025
          • 13
          • Epinac
          Wait , I think there's a mistake in my measurements... I'm using the LCR-ST1 (https://www.fnirsi.com/fr/products/l...zG1M5loT2rYbrA), but I've just tested it again and the readings are completely different... I'll try another tester
          Thanks for the advice. I'll give it all a go and let you know how it goes tomorrow. That's really kind of you.
          • orasl
            • Jun 2025
            • 13
            • Epinac
            Hi mon2, i hope today your are fine !
            I have found mosfet N-channel on old motherboard and i have swap this. No result :-(
            Before swap I tested it as you said, once the component was removed, checking the component's contacts on the motherboard and ground, and there's no short circuit.
            I measured the removed component; here are the values. It seems to be faulty, though.
            Perhaps I'm not measuring correctly with the tester?
            • mon2
              • 16068
              Your meter is the manual select type.
              The 89k2 ohms = 89.2k ohms is considered to be very low for a good mosfet so we can assume that this mosfet is defective. You can try reversing the meter leads but likely this value will remain low.
              The tests with the '1' = OL = over limit for the selected meter scale. You are on the 200k ohm scale but the measurement is > 200k ohms so the meter shows the '1'. Proceed to switch to a higher meter scale and you should have a valid measurement. Either way, the 89k ohms is showing that his mosfet is defective.
              Repeat the same test with the new mosfet you have soldered onto the board. Respectively, nearby the new mosfet, there will be the 2nd DC in mosfet. Often there are 2 x DCin mosfets in the power path. Some have 4. Assuming that you have 2 in this region, repeat the same tests on the 2nd DCin mosfets.
              Nearby these mosfets will the battery charger IC. Share a pic of this IC so we can study which design is onboard. As per the charger sticky article by piernov, the DCin mosfets are the key suspects.
              • dhenion
                Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                by dhenion
                I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                The original board was:
                ASUS X510UNR REV 3.0 A
                The replacement board is:
                ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                01-30-2024, 01:45 PM
              • cope
                Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
                by cope
                I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
                Some history:
                Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
                As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
                Now, with a new battery the system will start up and run off...
                05-13-2024, 09:40 AM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • wamo
                Asus GL753 Dosnt turn ON with battery connected
                by wamo
                Hello everyone, I'm a bit stuck and would like to see if you can give me any ideas about what's happening, or if anyone else has experienced something similar.
                I'm working on an ASUS GL753V, whose original battery failed (it swelled up) and was replaced. However, the computer is behaving as follows: with just the charger, it turns on and works stably; with just the battery (the old or the new one), it tries to turn on (LEDs and keyboard light up) but immediately shuts down; with both the battery and charger, it also tries to turn on and then shuts down.
                I thought it was...
                02-27-2026, 10:08 AM
              • rob777
                Asus TUF won’t run off battery
                by rob777
                I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
                I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
                Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
                Thanks....
                05-27-2025, 07:07 PM
