Not sure how up to date this is....
How To Check BIOS/EC firmware version for MSI notebook?
Please check BIOS/EC version by [Help Desk] or [BIOS Setup Utility]
1. How to check BIOS/EC version by Help Desk?
1.1. Open MSI Help Desk.
Note: Help Desk is a built-in application for MSI notebooks. If you couldn’t find this software in your Windows system, please download and install MSI Help Desk from product.
1.2. Click the [System Info].
1.3. BIOS and EC firmware version will display on screen.
Note: MSI Help Desk is only for MSI notebook products.
2. How to check BIOS/EC version by BIOS Setup Utility?
2.1. Power on NB and press [DEL] button when MSI logo is displayed.
2.2. Please select [Main] ->[System Information] to check BIOS version and EC version.
How to Update an MSI BIOS
See attached
Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
How To Check BIOS / EC firmware version for MSI notebook & Update it
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help... -
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by TeslaI have a Dell XPS-15 (9520) with the LA-L402P motherboard. It seems to have bricked itself after a common BIOS-Firmware upgrade. Now, it just shows BIOS screen for a few seconds before turning-itself back Off (and doesn't seem to be fully Posting). I've done these many times before with no problems.
I was hoping to please have my own-thread to work-through this (hopefully successful) repair as a whole. Apart from the possible need to have a BIOS-dump fixed-up, I have a feeling I'm going to have other questions. This includes using my new XGecu-T76 for the first time (should be here... -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... - Loading...
