I am having an issue with this laptop, motherboard MS-15911, no schematics found online. Plugged in, battery is charging and the charging light is on but no boot while pressing power button, not even a fan trying to spin.
Battery and usb power supply plugged in, I do have 3.3v and 5v. Main power rail is at 15.80v from the battery. When I unplug battery, main power rail is at 12.20v.
Pressing the switch on the MB turn off the charging light for couple seconds (EC reset I guess) then charging light turns on again but no change while trying to turn on the laptop.
Attached :
- picture of the board with all measures (battery unplugged). Orange circle on the picture = potentially damaged RTC Quartz, eventhough I measured 32kHz with my oscilloscope
- 2 pictures of the RTC Quartz with partial reference and position.
I think I will replace the RTC anyway. Based on very low resistance to ground on GPU coils, I removed them both but no change while trying to boot. I'm a bit stuck on what to verify now, any help would be highly appreciated. For example, how can I check for power good signal on EC ene k89548GF2 ?
Otherwise any schematics would also be very helpful
Attached :
