Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
HOW to check the power cable of a 2024 24" IMAC that doesn't power ON
  • kjchatman
    • Dec 2012
    • 243
    • united states
    This mac doesn't show any signs or life and won't go into dfu mode so I suspect that the power brick isn't working. I'm not sure how these 143 watt magsafe power supplies work. Should it measure the full 15.9volts without being plugged into the imac or is there a safety circuit in the computer that triggers the 15.9volts from the power chord?
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • ryogadan78
    iMac A1418 - No LED, no power after overvoltage on Ethernet port
    by ryogadan78
    Hi guys, I need your help again.
    I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
    When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
    06-10-2025, 03:49 AM
    by sam_sam_sam
    03-31-2024, 02:12 PM
