Apple Macbook Air A1466 EMC2925 not booting, fan spinning, no chime.
  • veedo
    • May 2016
    • 34
    Hi
    I have a MacBook Air that was completely dead on arrival. During inspection I found a shorted capacitor near the SMC, which appeared to be the main fault. After replacing the capacitor, the short on the rail was cleared. The board then started recognizing the charger, charging normally, and the machine powered on. Initial testing outside the chassis showed normal behaviour.
    However, after full reassembly a new issue appeared. There is no boot chime and no image on the screen, only the fan spins. The power button responds normally, it powers on without the charger connected and reacts to a forced shutdown. I also tested it without the SSD and the behaviour is exactly the same.
    It seems like the machine is hanging very early in the boot sequence. What rails or signals would you recommend checking next. Could this be SMC related, SPI or BIOS corruption, or possibly a missing power good signal after reassembly. Any advice would be appreciated
    A1466
    820-00165-A
  • mon2
    • 16086
    https://logi.wiki/index.php/PM_SLP_S...roubleshooting
    • mon2
      • 16086
      https://logi.wiki/index.php/G3_to_S3..._and_Broadwell
      • reformatt
        • Feb 2020
        • 1693
        Do you have CPU Vcore present? Assume so if you have fan spin. Are the power rails pulsing on/off or just stable? BIOS or missing power rails result in pulsing on/off every few secs.
        If everything is stable, and there was corrosion around the SMC, first thing I do is reball the SMC.
        • vienzen
          MacBook Air A1466 EMC2925 (820-00165-A) Shorted PP3V3_S0
          by vienzen
          1. Problem of macbook is No Display
          2. Found shorted caps on c1212
          3. After removing the shorted caps (c1212) the reading in the c1212 pin1 is .003 in diode mode test, still shorted.
          4. Help me.....
          09-25-2023, 03:05 AM
        • j.bisous
          MacBook Air A1466 - No chime, no picture, fan spinning
          by j.bisous
          Hello!
          I just got and MacBook Air A1466 EMC 2925 (820-00165-A) but it doesn't chime with not light on keyboard and black screen, just the fan spinning.
          I noticed something weird with the fan:
          - When the charger is connected, he powers up on his own (one time fan spining for 5 seconds, stops, then solid normal fan spining until I force the shutdown).
          - When I try to run the Mac on battery, he is just power cycling (fan spinning for 10-15 seconds and then stop before restarting again and so on).
          I already tried to refalshed the BIOS: nothing changed.
          04-15-2021, 02:09 PM
        • psdavid65
          Macbook Air A1466 820-3437-B Booting Problem
          by psdavid65
          I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
          06-20-2024, 12:27 AM
        • Rubedizzle
          MacBook Air A1466 820-00165-A - No POST/Fan Spin, has charging light
          by Rubedizzle
          Hey folks, came across a 2017 13" MacBook Air A1466 820-00165-A system that does not power on. When charger is plugged in, it will show a green then orange light, and eventually green light as the battery gets charged. Just no fan spin or response when pressing power button.
          Tried SMC Reset and NVRAM/PRAM reset etc, nothing.
          Took it apart, and no signs of corrosion anywhere, trackpad cable/keyboard cable all look good. Flipped board over, and U8040 is cracked, see attached. This appears to be a load switch for the audio system. I've ordered a replacement component...
          04-20-2026, 03:30 PM
        • echothegamer
          Macbook A1466 dies when charger disconnected
          by echothegamer
          Hello all,
          Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
          Details:
          Macbook 13' A1466
          Board (820-3209-A)
          Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
          Pictures below of Boardview and schematic...
          I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
          It's an older model and it is very likely that battery has become...
          10-28-2023, 12:00 PM
