Macbook A2251 820-01949A - 20v not powering on or charging
  • tccyo22
    • Oct 2019
    • 79
    Hi there, this one has me stumped. Quick back story is this macbook had a very small liquid damage on one side of charge ports which burnt the connector. I've currently got that side of USB ports disconnected and I've replaced the connector and the CD3217 that was stopping the macbook from transitioning to 20v. (It was originally stuck at 5v 0a) and I'm using the other side to diagnose this board.
    I now get 20v and it appears as though the macbook is attempting to boot but it's failing? On connection of usb power I watch the voltage swap from 5v to 20v and sit at 0.1a for 2-3 seconds then it will jump to 0.2a for a second then 0a and will not repeat unless I cut power and supply again.
    All my main power rails are mostly present from the power aliases however
    PPBUS_G3H = 12.65v (Schematic suggest 13.1v so this seems a little low)
    PP1V8_S5 is missing entirely. looking at U7700 the enable signal PM_SLP_SUS_L is missing. R7715 is 0.1ohms.
    I'm a little stuck where to go from here since it looks like PM_SLP_SUS_L comes from the CPU/PCH. Resistance on PM_SLP_SUS_L is 65k ohms.
  • mon2
    • 16067
    Test the nand flash power rail for voltage and also resistance (without power).
    PPVCCQ_ANI_SSD0 (1.8V): This is for the NAND. Shorting here is a common failure.
    Attempt a DFU.
    • tccyo22
      • Oct 2019
      • 79
      Attempt a DFU.
      No short on this rail. I've managed to get it to boot after finding 1 resistor that was partially failed around the damaged area. Always worth going back to double check sometimes as I had missed one or as they say, can't see for looking.
      • mon2
        • 16067
        Excellent.
        • MICHAEL_2013
          Macbook Pro Core I7 A2251 EMC3348 Help Remove MDM
          by MICHAEL_2013
          Good afternoon. My client brought me a Mac A2251 EMC 3348 that he bought at a sale. The computer is completely iCloud-free, but it came with MDM installed. He has tried contacting the company that provides the MDM in every way possible, but they are unwilling to offer a solution. The device is:
          Model A2251 EMC 3348. Serial Number: C02G54CZML85
          Apple MacBook Pro Core i7 2.3, 13" 2020, 512 GB SSD, 16 GB RAM.
          I've tried changing the serial number of the SoC ROM MX25U3235F, but it hasn't worked:
          C02G54CZML84 only works up to Monterey.
          C02G54CZML86 doesn't work (I...
          11-20-2025, 11:18 AM
        • silver60618
          MacbooK A1706 not powering after LCD replacement
          by silver60618
          Hi freinds,
          Hoping to get some insight from someone. I was working on a functioning macbook A1706 2016, with a cracked screen. I replaced the screen and the macbook will not power on.
          On amp meter it gets 20v, 1amp
          - cpu begins to warm right away under thermal cam. much sooner than a spare board I have
          - PPBUS is 13v
          - battery was disconnected during LCD install
          - Trackpad click works during power
          - Keyboard caps lock worked once, but I could not reproduce it
          - I have a tester logicboard, boots up fine with that (rules out any component...
          03-13-2026, 08:00 PM
        • MikoMiko
          MacBook Pro A2251 - 820-01949-A not charging
          by MikoMiko
          Hello everyone, I have a MacBook Pro 13” 2020 (Four ports) (Model A2251 with the 820-01949-A logicboard). It had some minor liquid damage but I carefully cleaned the logic board with alcohol and let it dry as needed. Now I encounter following situation: The MacBook does start but the Battery is not charging when a cable is plugged in any of the ports (I use the powerbrick and cable that came with the device). It had some charge left, so I could safe some data, but I was limited my the 13% and the speed of airdrop. The liquid-damage is almost only limited to the side of the logic board where...
          03-24-2025, 11:09 AM
        • manymonsteras
          Macbook Pro - A2251 - No power when battery is connected
          by manymonsteras
          I am hoping to get some advice. I have a 2020 13" Macbook Pro - A2251 that wouldn't turn on. I have done lots of electronics repair in the past but never on Macbooks. I have had this laptop sitting around and I finally decided to take a look at it and see if I could spring some life into it.
          First, it wouldn't boot up at all. I did a DFU restore and managed to get it to power on. Did a full restore but the battery was dead and wouldn't charge. I put in a new battery in it but now it won't boot up when the new battery is connected. I ordered a second new battery just in case,...
          11-20-2025, 09:42 PM
        • TechSplendid
          MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
          by TechSplendid
          Hi All,
          I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
          Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
          04-09-2025, 02:13 AM
