Asus TUF Gaming A17 FA707NUR code 43 error
  • boticario
    IN THE LIMBO
    • Mar 2024
    • 27
    • France
    Hi again,
    The first thanks, I’ve been able to keep progressing with the tests, and as of now, I don’t think the problem is in the EC or the VBIOS.
    My Bios request topic here -> https://www.badcaps.net/forum/troubl...ur#post3828581
    After running MATS with the correct version for AD107, the test completes, detects the GPU correctly, and the memory bus responds, but write errors appear consistently in the same subpartitions and with the same bit patterns. This is typical of a physical VRAM failure, not a thermal flag or firmware issue.
    At this point, I’m mostly ruling out:
    • EC flag
    • Thermal flag in VBIOS
    About MODS
    With MODS, the behavior is slightly different and provides useful insight:
    • MODS reports that one memory channel/slot fails to initialize entirely, while the others do enter training.
    • Additionally, Falcon logs show generic errors and trace entries, indicating that the GPU attempts to initialize the memory channel but fails. For example:
    FBFALCON_MAILBOX(02) : 0x23100f0c
    FBFALCON_MAILBOX(03) : 0x75880398
    FALCON_TRACEPC(0) : 0x00003786
    FALCON_TRACEPC(1) : 0x0000377f
    Error Code = 000000000539 (NVRM Generic falcon error)
    MODS reports channel/slot 4 fails to initialize entirely
    • This matches what MATS shows:
      • MATS runs but reports errors in two specific subpartitions
      • MODS shows one channel that doesn’t even train / initialize
    My interpretation so far (without assuming which physical chips are failing yet):
    • Two VRAM subpartitions are clearly faulty (the ones showing MATS errors)
    • One slot is empty (as expected for this SKU), which MODS reports as not initializing
    • Falcon logs reinforce that the GPU finds initialization problems on that channel
    I’m not assuming yet which chips correspond to which errors, I’m just showing the MATS and MODS data. I’m currently verifying in the boardview which slot is actually empty to avoid confusion with a faulty chip.
    I’m currently:
    • Cross-checking MATS results with VRAM1–VRAM4 numbering in the boardview
    • Physically identifying which chips correspond to the failing subpartitions
    • Confirming which slot is truly empty on this FA707NUR SKU
    If anyone already has a mapping (physical position ↔ memory channel / FBIO) or experience with MODS showing a channel that doesn’t initialize while others show errors, it would be extremely helpful. This could save me from repeatedly removing the heatsink.
    Everything points to replacing the failing chips as the next step, but I want to fully understand the MODS behavior first.
    Thanks again for the help.
    P.D. MATS log:
    Found NVIDIA devices :
    [ 0] VGA : 0000:01:00.0
    RM unavailable - won't test GALIT2 FrameBuffer upper memory
    Half-FBPA mask is 0x0, but expected 0x1
    mats version 520.249. Testing AD107 with 10 MB of memory starting with 0 MB.
    Memory Errors on
    Read Error Count: 0
    Write Error Count: 272
    Unknown Error Count: 0
    === MEMORY ERRORS BY SUBPARTITION ===
    SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
    FBIOA0 0 0 0
    FBIOA1 0 104 0
    FBIOB0 0 64 0
    FBIOB1 0 104 0
    Failing Bits:
    A032-A063
    B000-B063​
    P.D2:position in boardview
    Click image for larger version  Name:	Capture d'écran 2026-02-22 005354.png Views:	0 Size:	95.6 KB ID:	3827674à
  • boticario
    IN THE LIMBO
    • Mar 2024
    • 27
    • France
    From my tests and MODS logs, it seems like this could be a VRAM issue, but I’m not entirely sure:
    • 3 × 2 GB chips installed → one might be completely dead, or it could be that the Falcon is not starting this channel because it detects errors in the other two chips; the other two show partial errors
    • 1 empty slot → MODS reports it as “not initializing,” which could be normal
    Falcon seems fine, but could it be affecting the slot/chips?
    Would anyone with experience confirm if replacing the failing chips would be the right step, or if something else might be happening?
    • boticario
      IN THE LIMBO
      • Mar 2024
      • 27
      • France
      now i thinking i need other mods mats .....
      mats version 520.249. Testing AD107 with 10 MB of memory starting with 0 MB. Memory Errors on Read Error Count: 0 Write Error Count: 0 Unknown Error Count: 0 === MEMORY ERRORS BY SUBPARTITION === SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS ------- ----------- ------------ ------------ FBIOA0 0 0 0 FBIOA1 0 0 0 FBIOB0 0 0 0 FBIOB1 0 0 0 Failing Bits: None Error Code = 00000000 (OK) said PASS i dond untderstand ....
      • boticario
        IN THE LIMBO
        • Mar 2024
        • 27
        • France
        i thinking if posible:
        GPU/VRAM overheats excessively
        EC (IT5570) detects critical temperature
        EC marks thermal flag in its own memory
        EC orders VBIOS to "protect" the GPU
        VBIOS modifies its tables:
        - Reduces voltages (to generate less heat)
        - Changes thermal limits
        - Disables "problematic" memory channels
        - Marks "hardware damaged" flag
        VBIOS saves these modifications to W25Q
        Next boot: VBIOS with "protection" configuration
        GPU doesn't start normally, appears damaged
        this weekend reviewing everything with MODS and MATS. Now attacking the VBIOS backup task.
        Thanks everyone for the help
        • maurinaz
          Request: NVIDIA MATS/MODS UEFI payload for RTX 4070 Laptop (GN22-X11 / AD107)
          by maurinaz
          Hello everyone!
          I need the UEFI-compatible version of NVIDIA MATS/MODS to test VRAM on a
          laptop RTX 4070 GPU (GN22-X11 / AD107). My MSI Stealth 16 Studio laptop
          is UEFI-only (no CSM), so I specifically require the mats.efi payload
          that works on Ada GPUs.
          Local repair technicians here do not have MATS/MODS versions that support
          RTX 40 series, so I need the proper UEFI build (v2.0.0 or newer).
          If anyone can share the correct MATS/MODS package for Ada (UEFI boot),
          or any documentation on how to run mats.efi on RTX 4070 Laptop GPUs,...
          12-10-2025, 03:08 PM
        • chappers
          Nvidia MATS help please - 33 errors on two cards?
          by chappers
          I'm new to MATS and can only use it after watching a Youtube video, downloading the one he linked to (version 400.184) and running it without changing anything. I have no great understanding of it.
          I have 3 graphics cards in the house.
          My son's - Palit GTX 1080 used for 3D games constantly.
          Mine - Nvidia GTX 1080 not used for 3D games, just basic stuff.
          Inno3D RTX 2080 I bought faulty hoping to repair for my son's PC.
          Running MATS on my son's GTX 1080 gives a pass with no errors.
          Running MATS on my GTX 1080 gives...
          08-09-2023, 01:28 PM
        • Loki_Fido
          MODS & MATS for 4080 (520.132)
          by Loki_Fido
          I have a Gigabyte GeForce RTX 4080 Super OC 16 for repair and I have searched the whole web and found only 1 type of Nvidia 520.132 system of file(s).
          I cant use it directly nor integrate it into a different version of the MODS to use it.
          Folk uploaded this and mentioned to burn mods 455 to usb drive and extract above contents into the home folder.
          I've tried and it doesn't do anything. It was a Russian site.
          Am i missing something? I wasted a lot of time trying out this method.
          Is there any version...
          03-10-2026, 06:40 AM
        • konter
          ACER Nitro 5 AN515-55-774Z errors in mats
          by konter
          ACER Nitro 5 AN515-55-774Z ((FH52M LA-J891P REV.1))
          Intel Core i7-10750H
          RTX 2060 6GB GDDR6
          There was a short circuit on the video memory power supply. Replaced all memory with new memory. The short circuit is gone.
          Now the laptop turns on and works. But heats up a lot. Turned on with external cooling. In Windows the video card is detected but after installing the correct drivers it gives error 43.
          In MATS test on 5mb writes a lot of errors on all memory channels on the record. (Attached report)
          When testing on 2mb of memory built into gpu...
          10-19-2024, 11:24 AM
        • eccerr0r
          old X58 triple channel board... memtest86 memory speed?
          by eccerr0r
          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
          06-28-2025, 09:06 AM
