Asus Zenbook 15 UX563FD 20v on first Mosfet D no power not loading
  • dbuergi
    • Jul 2024
    • 201
    • Deutschland
    • tinkering, gym, basketball
    i have this board revision which is not doing anything. The only part on the board getting 30c warm is the 822 resistor on the top left (i hope it's alkso visible with the reflection). On the side to the BQ chip it shows 20v to ground and on the other side 0,7v.
    What i also did until now:
    -removed the dc fets and changed them even if removed measurements where fine.
    -replaced the BQ24780S with a brand new one (pin 6 ACDET shows only 1,7v and this should be my problem since it is dragged down).
    -pin 6 shows 19k ohm and i found the other resistors which go to pin 6 (marked them red and they all show also 19k ohm on this side).
    So any ideas where to look next or what to check? Is there any available boardview for other comparable models?
  • mon2
    • 16444
    From another but similar schematic for Asus. Compare against your board for the high side resistor @ PR8904.
    Remove all power. Meter in resistance mode. Measure the resistance to ground of drain pin on PQ8902. What is the resistance? We are checking if the main power rail is shorted.
    The ACDET voltage is too low. Is the power adapter the original and proper adapter for this Asus model? If not, there will be an expected voltage drop. This can lead to a lower ACDET voltage. If the power adapter is stable @ 19-20V then investigate the high side resistor value @ PR8904. Does the resistance match the schematic value? Usually this threshold needs to be 2v4 or higher to trigger the ACDRV pin = adapter_voltage + REGN voltage = ~25v.
    • dbuergi
      • Jul 2024
      • 201
      • Deutschland
      Hello mon2,
      It's the original charger for this board.
      PQ8902 only shows 2ohm on D but with voltage injection (1,2v and 2a) it draws 1,2v and 0,6a and GPU gets warm.
      Diode mode on mosfets:
      8901: 0,49v and 2,2v
      8901: 0,49v and 1,3v
      Removed they show normal values with OL.
      Back to the BQ area, i got my macro lens out to make a better picture. BTW REGN is 6v.
      Click image for larger version  Name:	DSC09435.jpg Views:	0 Size:	2.18 MB ID:	3826338
      On the right side i have three resistors which have one pin connected to ACDET i marked them with 6.
      In ohms mode one has 19k ohm (bottom left)and the others 10k (top) and 47k (bottom right).
      In this area i have 1,7v.
      Next to the 822 i removed a resistor which showed 130k onboard but outside 300k so it should be faulty.
      • mon2
        • 16444
        The 130k resistor does not look to be linked to the ACDET pin on the charger pin #6. Confirm by using DIODE mode setting on your meter. No power to the board. Touch the meter probes to hear a tone beep.
        One meter probe on pin #6 (ACDET) on the charger IC; other probe on either side of this 130k resistor pad. If you do not hear a tone beep, then this part is not linked to the ACDET pin and should be placed back as before.
        Repeat this probing to find the true high side and low side resistors mating with pin #6 of the charger IC.
        • dbuergi
          • Jul 2024
          • 201
          • Deutschland
          I check again. As posted the three resistors marked with 6 are connected to pin 6 and somehow i missed that the resistor above 822 on top left is also connected to pin 6.
          It shows 47k in ohms mode and with connected charger 1,7v on side connected to pin 6 and 20v on the other side.
          The 20v side is also connected to 822 resistor and the 130k resistor which showed 300k removed from board.
          • mon2
            • 16444
            Use an online resistor based voltage divider calculator to adjust the high side and low side resistors (as required) to output a 2v4 voltage for pin #6. That is, you will have to dial down the high side resistance so that the ACDET voltage increases. Double check the resistor values before proceeding.
            • dbuergi
              • Jul 2024
              • 201
              • Deutschland
              Sorry it took some more reading to get everything right, im still learning.
              I removed the high side resistor and it shows 127k and my low side removed 20k so calculated it should be around 2,7v and fine. The resistors are not my problem any longer and something else is dragging down here?
              • dbuergi
                • Jul 2024
                • 201
                • Deutschland
                I forgot to mention that 43T next to the 10 Ohm resistor should be the BAT54CW from your second pic. Diode mode shows normal values. I also changed my high and low side resistor with same values (high 127k and low 20k). I`m coming out at 2,7v or is the tolerance too big with 0,3v and needs to be adjusted? Normally between 2,4 and 3,1v should be fine.
                I marked everything in the picture. Any other ideas?
                Click image for larger version  Name:	DSC09438.jpg Views:	0 Size:	2.25 MB ID:	3826807
                • mon2
                  • 16444
                  Good on the new ACDET voltage. This range is now OK. Carefully, measure and post the voltage on each pin of this charger IC in a table for a review. Be sure to include the pin # and their function else it is more difficult to compare against a known good charger IC.
                  • dbuergi
                    • Jul 2024
                    • 201
                    • Deutschland
                    Ah sorry my description was bad. I meant 2,7v with the calculator and my replaced resistors. Problem still is the same with 1,7v on pin 6. :-/
                    • mon2
                      • 16444
                      Oh Measure the resistance to ground of ACDET pin. No power to the board during this test. What is the exact resistance at this time?
                      • dbuergi
                        • Jul 2024
                        • 201
                        • Deutschland
                        19k Ohm
                        • dbuergi
                          • Jul 2024
                          • 201
                          • Deutschland
                          Okay maybe i got the right twist now. Since i have 20v and 0,7v on the 822 resistor something is dragging down on the other side and this point goes to the battery area.
                          The diode on my pic shows voltages in every direction and i have a e7ej tantalum cap (not tue one one my pic) next to the battery connector which is the only one one the Board with no continuity. So could this be the cause?
                          Any information about the precise specs for the diode?
                          • dbuergi
                            • Jul 2024
                            • 201
                            • Deutschland
                            Finally some news. I unsoldered the JB2 ?diode? and finally got my 2,7v on pin 6 back.
                            But! the board is still not working. At the moment i can see that the first DC mosfets tries to switch and stops and does this in a loop. My guess is that it could be a reverse protection diode or p channel mosfet and without it there is no final go. So any ideas on this theorie and maybe anybody can help with replacement identification?
                            Also second mosfet (was also replaced to test if behaviour changes) is still showing 0,49v and 1,3v and has 2 Ohm on source. But it's connected to system rails and voltage injection didn't show any shorts.
                            • dbuergi
                              • Jul 2024
                              • 201
                              • Deutschland
                              Hello mon2,
                              maybe you have any more hints or ideas? I replaced the JB2 which is a BAV99W but the behaviour went back to my 1,7v and no more pulsing on first fet. :-/
                              • mon2
                                • 16444
                                Suggest to place back the original JB2 diode. Not clear on the full details of this JB2 diode and also the internal orientation of the potential dual diodes. That, if this part is with dual diodes, the anode to cathode placement inside will matter.
                                With the original JB2 diode, do you have 2v7? Also, remove all power -> meter in diode mode. Where does the single pin on this JB2 diode travel to on the board?
                                • dbuergi
                                  • Jul 2024
                                  • 201
                                  • Deutschland
                                  No i only get 2,74v with the diode removed. With the diode i get 1,7v and 20v on drain of first DC mosfet. Removed i get 2,74v and the mosfet is pulsing under the thermal cam but there is not anything getting through it. Single pin has 4v and goes to the 822 resistor(one side 4v and other 20v).
                                  I also made some more measurements on the BQ chip:
                                  VCC 20v
                                  ACDRV 0v
                                  ACOK 0v
                                  ACDET 2,74v
                                  REGN 6v
                                  CMPIN 0,3v
                                  BATSRC 0,5-0,7v pulsing
                                  BATDRV 0,155v
                                  BATSRC 0,155v
                                  SRV 0,155v
                                  CMSRV 0-0,54v pulsing
                                  Top right pin of the diode also shows 0,155v when it's on the board and 0v when removed.
                                  So maybe my problem is somewhere in the battery path? Or maybe since CMPIN is too low the fault is somewhere in ACP /ACN/Shunt?
                                  • mon2
                                    • 16444
                                    Yes. What is the resistance to ground of ACN? ACP? This is the main power rail. Testing if it is shorted.
                                    Also the ACDRV voltage should be ~25v to enable so the dcin mosfets are also suspects. If the main power rail is not shorted then the dcin mosfets are to be tested with resistance mode to confirm they are not leaking.
                                    • dbuergi
                                      • Jul 2024
                                      • 201
                                      • Deutschland
                                      Sorry, was a bit busy but now have time to work on this board again.
                                      ACN 8Ohm
                                      ACP 8Ohm
                                      I removed both mosfets from the board and they work normal and show no strange behaviour. Onboard i only get 6 MOhm. With second mosfet removed i get 20v on drain and source of first fet. When both are onboard only 20v on drain of first and nothing else.
                                      • mon2
                                        • 16444
                                        ACN 8Ohm
                                        ACP 8Ohm
                                        If these are resistance values to ground then the main power rail is shorted. Test the resistance to ground of each and every inductor on the board. Confirm if you see a similar measurement near the CPU.
                                        • Boardview and Schematic Bot
                                          ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook Zenbook 14 Flip OLED UN5401QA-KN144W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Zenbook 14 Flip OLED UN5401QA-KN144W boardview and Zenbook 14 Flip OLED UN5401QA-KN144W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 06:31 AM
                                          ASUS ZenBook S UX370UA Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook S UX370UA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S UX370UA boardview and S UX370UA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 06:24 AM
                                          ASUS ZenBook UX550VD-BN011T Notebook Pro Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX550VD-BN011T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX550VD-BN011T boardview and UX550VD-BN011T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 06:08 AM
                                          ASUS ZenBook UM431DA-AM079T Notebook 14 Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UM431DA-AM079T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UM431DA-AM079T boardview and UM431DA-AM079T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 07:50 PM
                                          ASUS ZenBook UX362FA-EL076R Hybrid (2-in-1) Flip 13 Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX362FA-EL076R Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX362FA-EL076R boardview and UX362FA-EL076R schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 11:40 AM
