Macbook Pro 16" 2019 No Display After Lid Sensor Issue
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 222
    • Computers, Cars,
    hi guys i have the above MacBook pro 2019 16"
    i did some dust cleaning recently and i somehow damaged the lid angle sensor. so i purchased the nerdtool1 lid angle sensor calibrating tool and a new sensor.
    installed it and followed the instructions to program the sensor.
    and now im still getting no display out of the MacBook pro.
    its booting up ok ive noticed the keyboard and touchbar is all lighting up.
    it was also showing a display before i replaced the damaged sensor and now i cant get any display out of it.
    i noticed down in the left hand corner where the sensor is there was some sort of magnet that also came off i got that back on and i think i lined it up correctly.
    but still im not getting any display.
    have i damaged something more than the sensor in this case ??
    sometimes i can get the display on if i do a couple of PRAM resets and a couple of SMC resets and the new sensor seems to work then as the display goes out if i close it the macbook sleeps and then wakes up also.
    but once shut down im back to the same issue again.
    thanks for any help.
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
  • mon2
    • 16180
    Check your local MobileSentrix (UK) branch if they offer the OEM lid sensor for the same model. Believe that sensor will be factory calibrated but confirm this before purchasing. From our experience, the sensor was just install and use without any additional calibration. Took only a few minutes for the repair. Our client had spilled some drink onto the unit and it was coated with green corrosion. Apple wanted the client to purchase a new unit.
    https://www.mobilesentrix.ca/sleep-wake-sensor-flex-for-macbook-pro-16-a2141-mid-2019
    https://www.mobilesentrix.co.uk/sleep-wake-sensor-flex-for-macbook-pro-16-a2141-mid-2019
    Mobile Sentrix had this OEM (Apple) sensor for under $20 CAD. No nerd tool required.
    Click image for larger version  Name:	lid_sensor.png Views:	0 Size:	785.2 KB ID:	3826015
    • jasonr2000
      Advance Tech
      • Nov 2013
      • 222
      • Computers, Cars,
      hi thanks for the reply.
      I will take a look at there website now.
      I got the tool from nerdtool1 so im sure it will come in handy some day.
      but on another issue would my sensor cause the display not to wake up at all ??
      even after the battery has been disconnected ?
      it was fine until I damaged my lid angle sensor but I can hardly get it to display anything now.
      and if I do it works perfectly fine until its shut down again fully.
      thanks
      Samsung UE46D6530
      Samsung BD-F7500
      Samsung HT-ES6200
      • mon2
        • 16180
        From the limited time of experimenting with the unit in for repair, I recall that the lid sensor, as expected, decides when there is or is not the backlight for the LCD. That is, without a proper lid angle calibration, the sensor may just believe that the lid is always closed so no point to drain the battery by enabling the backlight. I recall that we saw this in action when the trackpad was removed from the normal position. Then when we closed the lid, we could see the backlight disable or enable when opening the clam shell.
        Can you test with an external HDMI screen using a USB-C dongle?
        The nerdtool is interesting but is an arduino or pico pi being used as a SPI programmer. I do believe the project is open-source and on git hub somewhere.
        • jasonr2000
          Advance Tech
          • Nov 2013
          • 222
          • Computers, Cars,
          hi thanks for the other advice I will try this tomorrow and message my findings I have a USB C monitor so would that work the same way ??
          Samsung UE46D6530
          Samsung BD-F7500
          Samsung HT-ES6200
          • jasonr2000
            Advance Tech
            • Nov 2013
            • 222
            • Computers, Cars,
            well after trying with my USB C Monitor its not detected on the Mac ???
            but the strange thing is the display is now working again.
            could it be my cable isn't good enough ??
            Samsung UE46D6530
            Samsung BD-F7500
            Samsung HT-ES6200
            • jasonr2000
              Advance Tech
              • Nov 2013
              • 222
              • Computers, Cars,
              further update it was my USB C cable that was the issue second display is perfect.
              Samsung UE46D6530
              Samsung BD-F7500
              Samsung HT-ES6200
              • mon2
                • 16180
                Test the usb c monitor on another known good device. Also flip the cable by 180 degrees to test the opposite side of the blade. If the display works now then that is good progress.
                • robertboyce
                  MacBook a2159 display issue
                  by robertboyce
                  I’m having a display problem with my MacBook A2159 (2019). The blacks suddenly shifted to a fluorescent blue, but the correct colors return when the screen is moved to a nearly-closed position.
                  I suspect a loose or damaged hinge-area connection, but I’m not an expert. I had it checked at Apple’s iCare and at third‑party repair shops, and they all recommend replacing the entire display — which is very expensive.
                  Does anyone know of an alternative fix or have experience with this issue? Any suggestions would be greatly appreciated.
                  03-09-2026, 10:50 PM
                • veedo
                  Macbook A2442 820-02098 boot and display issue
                  by veedo
                  Hi All
                  I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
                  Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
                  I found component UD290 ( SF0101-I2C) little...
                  04-01-2024, 06:06 AM
                • rounin
                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                  by rounin
                  I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                  🛠 Original Issue
                  The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                  04-19-2025, 01:18 AM
                • forkus
                  MacBook Pro 16" A2485 M1 Max (2021): No internal display - external works fine
                  by forkus
                  I'm troubleshooting a MacBook Pro 16" A2485 M1 Max (Late 2021, board 820-02382) with a completely dead internal display. No image, no backlight. External monitor works perfectly via USB-C or HDMI.
                  Symptoms:
                  • Internal display detected in System Information (shows as "Built-in Liquid Retina XDR Display")
                  • No image (no 100% sure), no backlight (100%)
                  Apple Diagnostics codes: VFD001
                  Measurements taken:
                  • PPBUS_AON_LUXE: 12V (schematic shows 13.1V — running without battery on charger only)
                  • PPVOUT_LUXE (CP834): 0V
                  • No short to ground
                  03-27-2026, 03:40 AM
                • ledbylight
                  M1 A2337 Macbook - No Display, likely due to logic board
                  by ledbylight
                  Hi all!
                  This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                  I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                  11-04-2024, 06:36 PM
