HP Victus 16 Hall Effect Sensor Problem
  • legolas777
    • Nov 2026
    • 13
    • Italia
    #41
    Originally posted by SMDFlea
    I have absolutely no knowledge of soldering; I need an IR card that has already been modified.
    • johnbeton
      johnbeton commented
      Editing a comment
      you could find replacement PCB's on ali express
  • legolas777
    • Nov 2026
    • 13
    • Italia
    #42
    Originally posted by ayvalikcomputech
    I replaced the FU6 and the hall sensor(with A1126LLHLT-T Allegro)on HP Victus 16-s0047nt. The laptop would work fine on the power adapter and would work too slow on the battery. There is a fuse (F05) on the flip side of F06. It measured 19 ohms. I replaced it and the laptop works just fine both on battery and power adapter! I used 3amps 0603 smd fuse for F05 and F06.
    I beg you, answer me
    • legolas777
      • Nov 2026
      • 13
      • Italia
      #43
      Dear johnbeton,
      where is the link on Aliexpress about an IR card with ALL modifications, working for Victus 16 ?!?
      • m1ch43lzm
        • Mar 2019
        • 3563
        • Peru
        #44
        Originally posted by legolas777
        Dear johnbeton,
        The issue is a blown fuse on the motherboard, not on the IR/lid sensor board
        As a workaround you can leave the IR board unplugged, you'll miss sleep function when closing the lid
        • legolas777
          • Nov 2026
          • 13
          • Italia
          #45
          Best wishes for the feast of Saint Martin de Porres!
          HP is absurd, I have no words for HP.
          • legolas777
            • Nov 2026
            • 13
            • Italia
            #46
            This is the right solution, but I do not make this kind of bridge. Do you know if I can make a bridge more simple?
            https://www.youtube.com/watch?v=JGk4L24JZBU
            • m1ch43lzm
              • Mar 2019
              • 3563
              • Peru
              #47
              What Sorin did is what he calls a "dodgy" fix, he shorted the 2 middle pins on the connector, but why? It's completely wrong as he's shorting a power line to what looks like a signal line
              But it looks like there's 2 separate 3.3V lines, one for the lid sensor and the other line which looks like it goes to the IR sensor, if one of the sensors gets the correct voltage (3.3V on the IR sensor) you can "borrow" it to power the other sensor (lid), see picture (ignore the missing lid sensor, this picture is from the OMEN 16-wd version where the lid sensor is on the other side), connect those 2 points with a wire, I suggest enamel wire for this, it should work in theory
              I suggest you ask a local cell phone repair shop if you don't have the proper tools or skills
              • legolas777
                legolas777 commented
                Editing a comment
                THE SOLUTION!!!!!! HAVE YOU STUDIED IN ELETRICAL UNIVERSITY????? YOU ARE THE BEST
            • legolas777
              • Nov 2026
              • 13
              • Italia
              #48
              Click image for larger version  Name:	ls-m78ip mod.jpg Views:	0 Size:	71.7 KB ID:	3960963
              Thank you!!!
              Do You mean that I have to connect the two points in this photo below ? Look at my photo.
              • legolas777
                • Nov 2026
                • 13
                • Italia
                #49
                Here it is the correct photo
                • m1ch43lzm
                  • Mar 2019
                  • 3563
                  • Peru
                  #50
                  As long as there's 3.3V on the point on the left (under JPR68 text) it should work, you're just "borrowing" power from the other sensor
                  • legolas777
                    • Nov 2026
                    • 13
                    • Italia
                    #51
                    For this bridge in the photo below a local smartphone shop asked me 30 euros: is it a good price? But moreover: with this bridge in the photo, will this IR CARD work ?
                    • legolas777
                      • Nov 2026
                      • 13
                      • Italia
                      #52
                      Thank you!!!
                      YOU ARE THE BEST MAN IN THE WORLD, I HAVE SOLVED!!!!!!
                      • legolas777
                        • Nov 2026
                        • 13
                        • Italia
                        #53
                        m1ch43lzm YOU ARE THE BEST IN THE WORLD
