lenovo l340 Can the ALC3287 be replaced with the ALC3227?
  • Moddingscreen
    • Dec 2017
    • 86
    • Italia
    Hi everyone, I have a Lenovo L340 on my bench. After hours of work on this motherboard, I identified the culprit preventing it from starting up: the Realtek ALC3287 audio IC. I have some donor boards available, but unfortunately not the exact same model. Since I couldn’t find a datasheet, I was wondering: can I safely replace the ALC3287 with an ALC3227?
    Thanks in advance.
  • mon2
    • 16800
    Based on the available information regarding Realtek audio chipsets, replacing an ALC3287 with an ALC3227 is likely not recommended, as they are generally not considered direct, compatible replacements for each other.
    Here are the key details:
    • Different Codecs: The ALC3287 is a newer, higher-end audio codec often used in modern Lenovo ThinkPads, while the ALC3227 is an older, different codec.
    • Not Listed as Compatible: Technical forums dealing with chip-level repairs (like the Electronics Repair Forum) suggest that ALC3287 is often paired with different alternatives (such as ALC3258) rather than the ALC3227.
    • Driver/BIOS Issues: Replacing an audio codec with a different model often results in "no device" errors or failing audio, as the motherboard's BIOS and OS driver stack need to recognize the specific Device ID (10EC) and Vendor ID.
    • Skill Level: Replacing these QFN-48 SMD chips requires high-level soldering skills.
    Conclusion: It is safer to replace the ALC3287 with another ALC3287 or a directly verified equivalent (like the ALC3204 in specific cases). Using an ALC3227 will likely cause driver or hardware recognition issues.
    • Moddingscreen
      • Dec 2017
      • 86
      • Italia
      Thank you for the reply and for the advice. I’ll try checking the thousands of boards I have for parts recovery; at worst I’ll order a new ALC3287, although I’m sure I have one on some non-working motherboard.
      • Loki_Fido
        Forever NOOB
        • Mar 2025
        • 236
        • Japan
        For future reference.
        ALC3287 and ALC257 are the same.
        • B-SH
          • Mar 2026
          • 15
          I want to see if I am having the same problems. I have a Lenovo yoga 7 slim. 14IRP8. It Starts to boot, fans spin, keyboard lights and then it just hangs there. Fans stop and keyboard stays lit.
          Troubleshooting I found the ALC3287 chip was getting hot. Is this similar to your boot failure?
          • Loki_Fido
            Loki_Fido commented
            Editing a comment
            This sounds like a bios issue. Try to fix and clean the bios.
        • natic
          • Sep 2018
          • 241
          • Slovenia, EU
          This chip should not get hot at all. Remove it from the board and test the laptop without this chip.
          Everything should work normally (except the sound of course).
          • Boardview and Schematic Bot
            Lenovo IdeaPad L340 Gaming Notebook L Specification for Upgrade or Repair
            This specification for the Lenovo IdeaPad L340 Gaming Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L340 Gaming boardview and L340 Gaming schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 04:00 PM
            09-06-2024, 03:30 PM
            Lenovo IdeaPad L340 Notebook L Specification for Upgrade or Repair
            This specification for the Lenovo IdeaPad L340 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L340 boardview and L340 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad L340...
