MacBook Air M1 (A2337 / 820-02016) dead - no power, DFU restore fails after iBSS send, good voltages - NAND dead?
  • Guest
    Hi everyone, first post here – long-time reader though. I have a dead MacBook Air M1 (2020) that won't charge or power on.
    Device info:
    MacBook Air (M1, 2020)
    Model j313ap (A2337, logic board 820-02016)
    Symptom:
    No charging, no power on at all.
    Restore attempts:
    Apple Configurator finds the MacBook in DFU mode, as Linux with lsusb: Bus 001 Device 021: ID 05ac:1227 Apple, Inc. Mobile Device (DFU Mode).
    It looks like the MacBookAir is in firmware boot loop. I have tried to restore 14.x version and 26.2 (latest) version firmware, but just after iBSS send I see at Dmesg: apple-mfi-fastcharge 1-5: USB disconnect, device number 29
    Device restore shows this:
    Command: idevicerestore -e UniversalMac_26.2_25C56_Restore.ipsw
    Found device in DFU mode
    ECID: 7055480287406366
    Identified device as j313ap, MacBookAir10,1
    Device Product Version: N/A
    Device Product Build: N/A
    Extracting BuildManifest from IPSW
    IPSW Product Version: 26.2
    IPSW Product Build: 25C56 Major: 25
    Device supports Image4: true
    Variant: Customer Erase Install (IPSW)
    This restore will erase all device data.
    Performing macOS restore
    ##################################[ WARNING ]#################################
    # You are about to perform an *ERASE* restore. ALL DATA on the target device #
    # will be IRREVERSIBLY DESTROYED. If you want to update your device without #
    # erasing the user data, cancel now and restart without -e or --erase #
    # command line switch. #
    # Type YES and press ENTER to continue, or hit CTRL+C to cancel. #
    > YES
    Checking IPSW for required components...
    All required components found in IPSW
    Getting ApNonce in DFU mode... 7e a0 3f 15 bd 03 bd 5b 79 cd c6 21 7b 76 39 d7 fa f4 e8 88 a3 ac 0a 19 12 c6 b7 d3 be cb 61 56
    Trying to fetch new SHSH blob
    Getting SepNonce in dfu mode... b2 86 47 9d fc b7 b7 96 ab 7f 80 9f a7 a3 60 eb 2a e3 ec 75
    Received SHSH blobs
    Received SHSH blobs
    Received SHSH blobs
    Extracting iBSS.j313.RELEASE.im4p (Firmware/dfu/iBSS.j313.RELEASE.im4p)...
    Personalizing IMG4 component iBSS...
    Sending iBSS (770863 bytes)...
    Uploading [==================================================] 100.0%
    Device did not reconnect in DFU or recovery mode. Possibly invalid iBSS. Reset device and try again.
    Unable to place device into recovery mode from DFU mode
    Voltage measurements:
    LOGIC BOARD DETACHED (NO CONNECTORS EXCEPT USB BOARD):
    PPBUS_AON: 11.96V (C5804)
    PP3V8_AON_VDDMAIN: 3.79V (C5895)
    PP5V_S2: 5.18V (CP717)
    PP3V3_S2_UPC: 3.29V(CF751)
    PP3V3_UPC0_LDO: 3.27V (RF242)
    PP3V3_UPC1_LDO: 3.29V (CF508)
    PP1V5_UPC0_LDO_CORE: 1.59V (CF405)
    PP1V5_UPC1_LDO_CORE: 1.585V (CF505)
    PP1V8_AON: 1.801V (CR851)
    LOGIC BOARD IN PLACE AND ALL CONNECTORS:
    PP1V8_S2: 1.796V (JR850)
    PP1V25_S2: 1.223V (JF202 PIN 12)
    Other tests:
    Multiple USB cables/ports tried.
    Question:
    Voltages look good. Is this almost certainly dead NAND/SSD or are there other common things to check on 820-02016 boards (e.g. PMIC, SoC ROM, etc.)? Worth trying NAND reball/reflow or is the board scrap?
    Thank you in advance for your kind answers.
  • mon2
    • 16656
    Locate the NAND flash power rail. Remove all power. Measure the resistance to ground of this power rail. What is the exact resistance in ohms?
    • Guest
      Thank you for prompt answer. Here are measurements:
      PP0V88_AWAKE_NAND: 216.0 (FLN001)
      PP1V25_AWAKE_NAND: 215.5 (CN03A)
      PP2V5_AWAKE_NAND: 588 kOhm (RN522, varies)
      I found just now that diode D5270 seems to be missing, but that seems to be related to SAVE_BAT_G ....
      D5270
      • mon2
        • 16656
        These rails are ok and no shorts here.
        Use a USB-c meter to note the voltage and current draw of this board. Are you at 20v on the power adapter?
        • Guest
          I lack a USB-C power meter at the moment, so I'll have to get one. My power adapter is a 65W PD supply (20V/3.25A). I’ve already ruled out the power supply by trying several others.
          • mon2
            • 16656
            Ok. Amazon should be ok but be sure it is bidirectional. If available to you, consider the Qianli tail tester sold through Mobile Sentrix (UK) and others on Aliexpress.
            Qianli iBridge A3
            https://www.aliexpress.com/item/1005...xoCwb0QAvD_BwE
            Want to test if the PD adapter is being configured to offer 20v otherwise there is a fault in the pd controllers on the logic board which are stand alone components.
            • Guest
ID:	3812454 Click image for larger version
              Today I tried to solder a missing 0201-sized D5270 Zener diode (Zener X3-DFN06) onto the PCB, but the hot-air nozzle on my rework station is too large to melt the Sn63Pb37 solder without causing collateral damage (although I did protect the surrounding components with Kapton tape).
              Attached are two graphs from a USB power meter (I wrote a Python script that reads data from the USB meter via Bluetooth and saves it as a graph). In the first one, the meter is on the power supply side, and as can be seen, when the USB connector is plugged in, the current consumption briefly increases and then drops back to around the 100 mA range. At no point does 20 V appear. The same behavior is observed when the meter is on the MacBook side. I also tried pressing the power button, etc., at the same time.
              It appears that the PD handshake is indeed not working at all. I am not sure whether the missing diode ultimately affects this, as it seems to be related to battery charging.
              • Guest
                Today I was able to solder the diode. Power button do nothing, but restoring firmware kicks 20V up and then drops back to 5V. It seems that now resotre fails to "Unable to place device into recovery mode from DFU mode".
                sudo idevicerestore UniversalMac_26.2_25C56_Restore.ipsw
                idevicerestore 1.0.0-268-g74e3bd9 (libirecovery 1.3.1, libtatsu 1.0.5-3-g60a39f3)
                Variant: Customer Upgrade Install (IPSW)
                This restore will update the device without erasing user data.
                Getting ApNonce in DFU mode... 52 d9 34 47 c0 b9 16 df 7d b1 8c 24 56 8a 9c e7 6a 57 ed a5 89 10 d5 26 0b 84 60 6b 61 d5 24 a0
                Getting SepNonce in dfu mode... dc 30 9a e3 f8 e9 99 16 0b c1 43 24 2a 62 11 54 05 36 30 29
                Received SHSH blobs
                Received SHSH blobs
                Received SHSH blobs
                Nonce: 3b 0b 28 af 29 92 d5 49 07 b1 77 7f 30 fb df aa 21 3c ca fa 77 9e df 9a 7e 47 98 18 20 db b0 26
                Getting SepNonce in dfu mode... fe 5a 2b ca ee 21 e5 6b 50 0e ac 13 e7 b6 e6 08 96 05 e2 37
                Received SHSH blobs
                Personalizing IMG4 component Ap,LocalPolicy...
                Sending Ap,LocalPolicy (3041 bytes)...
                INFO: executing command: lpolrestore
                Extracting t8103ciofw.im4p (Firmware/t8103ciofw.im4p)...
                Personalizing IMG4 component Ap,RestoreCIO...
                Sending Ap,RestoreCIO (179054 bytes)...
                Uploading [ ] 0.0% Unable to send Ap,RestoreCIO component: Unable to upload data to device
                Unable to send Ap,RestoreCIO to device.
                Unable to send component 'Ap,RestoreCIO' to device.sudo idevicerestore UniversalMac_26.2_25C56_Restore.ipsw
                Received SHSH blobs
                Received SHSH blobs
                Received SHSH blobs
                Received SHSH blobs
                Extracting t8103tmufw.im4p (Firmware/t8103tmufw.im4p)...
                Personalizing IMG4 component Ap,RestoreTMU...
                Sending Ap,RestoreTMU (21751 bytes)...
                Uploading [ ] 0.0% Unable to send Ap,RestoreTMU component: Unable to upload data to device
                Unable to send Ap,RestoreTMU to device.
                Unable to send component 'Ap,RestoreTMU' to device.
                Extracting rans.t8103.release.im4p (Firmware/rans.t8103.release.im4p)...
                Personalizing IMG4 component RestoreANS...
                Sending RestoreANS (976255 bytes)...
                Uploading [ ] 0.0% Unable to send RestoreANS component: Unable to upload data to device
                Unable to send RestoreANS to device.
                Unable to send component 'RestoreANS' to device.
                Extracting ipad13dcp_restore.im4p (Firmware/dcp/ipad13dcp_restore.im4p)...
                Personalizing IMG4 component RestoreDCP...
                Sending RestoreDCP (3893460 bytes)...
                Uploading [ ] 0.0% Unable to send RestoreDCP component: Unable to upload data to device
                Unable to send RestoreDCP to device.
                Unable to send component 'RestoreDCP' to device.
                Unable to send iBoot stage 1 components to device
                Uploading [ ] 0.0% Unable to send RestoreANS component: Unable to upload data to devicesudo idevicerestore UniversalMac_26.2_25C56_Restore.ipsw
                Received SHSH blobs
                Received SHSH blobs
                Received SHSH blobs
                Received SHSH blobs
                Received SHSH blobs
                Received SHSH blobs
                Received SHSH blobs
                Received SHSH blobs
                • Marcus3235
                  Qubo Dash Cam Pro X Stuck During Boot: SigmaStar SSC335R + W25N512GV SPI NAND
                  by Marcus3235
                  Note: I am not a professional electronics/embedded engineer. Everything I've done so far has been learned through YouTube videos, datasheets/forums, and guidance from AI. I've been proceeding cautiously, measuring and documenting each step, and have deliberately avoided writing/erasing the NAND or making irreversible changes.
                  Qubo Dash Cam - SigmaStar SSC335R stuck at "Load BL from SPINAND"
                  I'm trying to recover a Qubo dash camera that stopped booting. Qubo support told me the unit has gone bad and recommended replacing it, so I'm investigating...
                  08-09-2026, 08:45 PM
                • anik0101010
                  [REQ] RCF M18 Digital Mixer - NAND Recovery files (uImage / ubi.img) or Dump
                  by anik0101010
                  I'm working on a bricked RCF M18 digital mixer. The unit was completely dead, but I managed to resurrect the hardware doing a low-level recovery via the internal UART header and the Debug Jumper method (as per RCF Service Note 1903B).
                  I successfully booted from the SD card, wiped the NAND, and flashed U-Boot. The CPU is alive and I now have a working serial console at the RCF-M18# prompt.
                  The Problem:
                  The recovery script halted because the official firmware update provided by RCF on their website (.mpk format, ~1.5MB) is just an application...
                  04-07-2026, 02:34 PM
                • tranquility
                  Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                  by tranquility
                  i want to repair an Onkyo TX-NR809 receiver.
                  symptoms:
                  on power on, display appears and i hear one click. enue functions is given.
                  - no hdmi output
                  - audio output not tested, but i think it is not there
                  - usb sticks are not recognized
                  if i read out the chips with display+standby button + tone+
                  both dts show only ????
                  chip is D830K013BZKB4
                  things i have done:
                  - reflow of the dts chip without taking off and reballing
                  - changed the aluminium caps without the big one with 25v because i dont...
                  08-25-2025, 01:04 AM
                • mattpd
                  PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
                  by mattpd
                  PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
                  No LM damage. UART gives a generic "APU not responding" error.
                  Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
                  I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
                  So to those with experience, would you expect at least a little heat from the NAND during...
                  09-02-2025, 09:42 AM
                • SFBoxing96
                  Macbook Air M1 A2337 820-02016, 20 V 0.07 A
                  by SFBoxing96
                  I've got a dead A2337, liquid damage on chasis, but literally no marks on the PCB.
                  It peaks slightly above 0.1 A after plugging in, then starts to fluctuate between 0.07 and 0.074 A.
                  Not in DFU, but when I forced the bare board with shorting the DFU trace, then the DFU restore failed with "Gave up waiting for device to transition from DFU state to DFU state" (4042).
                  I found some clues that it might be the NAND on the internet. All the AWAKE NAND voltages (0.88, 1.25 and 2.5) are good.
                  I've got a fully working (locked) spare board, but wasnẗ able to find any...
                  03-09-2026, 04:14 AM
