Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Macbook A1534 problem with MacOs installation
  • veedo
    replied
    Date was correct, I've checked it on the beginning, there was no error number during the installation from USB, but I was keep trying to install High Sierra osx about 10 times or maybe more and suddenly installed it successfully. Then I've updated it easily to Big Sure and is working fine. Have no idea what was wrong but its sorted
  • obelix24
    replied
    what error you get during installation from USB ? check in recovery (open terminal) what Date is set. I'd some issues with installation older macos due to frong date set.
  • veedo
    started a topic Macbook A1534 problem with MacOs installation
    I have Macbook A1534 which had Windows 10 installed on it, now customer want to have macos back because windows is slow.
    From disk utility I deleted all partitions ( there was boot camp and macintosh ), created GUID Partition Map / APFS and I'm trying to install High Sierra from USB and its failing in half way, if I use Internet Recovery I have error apple.com/support -5101F, its shows me the option to go under support and mentions that battery have to be replaced.
    Because the battery I can't install the MacOs or it something else? any suggestions please?
  • 24gsm
    MacBook Pro A1708 install macos fail
    by 24gsm
    hi to all
    i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
    after enter to recovery and format hdd 1to .
    after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
    can help please
    Serial Number: FVFXP0U0HV2J
    Config Code: HV2J
    Find My Mac: OFF
    04-16-2025, 03:57 AM
  • duwane
    A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
    by duwane
    Hi All.
    Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
    The issue:
    Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
    10-26-2022, 07:02 AM
  • mnciks11
    MacBook Pro A1708 won’t install the MacOS Sierra
    by mnciks11
    Hello guys
    I'm struggling to install MacOS Sierra on the MacBook Pro A1708 , type -c .
    It giving me an error massage saying “you must plug in and connect your macOS Sierra power adapter before installing”.
    The battery is installed, brand new battery but doesn't charge, i was using an adapter. Im stuck I can't use this MacBook now anymore , I formatted the Ssd , can't do a thing. Is there a way to skip battery checkup or ac check up using Terminal or something please help guys…
    I did the Smc reset and Pram and all other things
    12-03-2021, 09:34 PM
  • PITERPENY
    Macbook pro 16" A2141 not updated
    by PITERPENY
    Hi. I've encountered this problem for the first time. I need help. Has anyone encountered it before and how did you solve it? Only MacOS Catalina can be installed on a MacBook via online recovery, and the Mac works fine (although it's also running slowly). But when I try to update the MacBook, it constantly crashes, and nothing else works except Catalina. Attempts to install Venture or Monterey Jack from an external drive are also impossible. I tried DFU recovery, but I can still only install Catalina and can't update, even though the system offers to update to Tahoe. It's impossible to run any...
    04-19-2026, 12:41 PM
  • stefanbs
    Fit 820-00244-А board in Apple Macbook A1534 2017 820-00687-А
    by stefanbs
    The laptop is Apple Macbook A1534 2017 with board 820-00687-А. The USB-C tester shows no voltage, there is 820-00244-А board available. I looked at both schematics, all connector signals seem to be the same. Did someone try to fit 820-00244-А board in A1534 2017?
    05-11-2025, 01:08 AM
