Macbook Air A1932 no sound from speakers
  • Stevechurch
    • Feb 2023
    • 56
    Good afternoon All
    i have a Macbook Air A1932 with no sound from speakers, but it does have sound from jack plug with corded earbuds plugged in
    i have checked left and right amps in diode mode all all checks out ok, i think it is unusual for both speakers to stop working together but i have no history regardin this mac
    i have both 820-01521 and 820-01124 boardview and schematics
    Has anyone encountered this before?
    kind regards
    Steve
  • mon2
    • 16652
    Suggest to blow out the headphone jack connector with compressed air. To remove any possible debris that could be blocking the use of the speakers.
    • Stevechurch
      • Feb 2023
      • 56
      Hi Mon2,
      thanks for replying
      ive just changed out the 820-01124 board and still the same no sound
      also tried anther speaker but that didnt give any sound either
      think i will remove the board again and recheck
      thanks
      Steve
      • mon2
        • 16652
        Check if the audio codecs have been man handled / replaced before you. The reason for this concern is that the audio codecs have special and reserved I2C / SMBUS IDs. Respectively, they must be purchased with the same exact markings from the offshore vendors otherwise the audio codec will not respond to the wrong addressing. I recall that we had to source from different vendors for a similar case. In the Texas Instruments datasheet (believe you are facing the same audio codec) - there is a mention of the I2C address values. From memory, the schematics reference a different address so appears to be a pseudo-custom audio codec from TI for Apple. This discussion is for a macbook with onboard codec. You have a daughterboard version.
        PS: I recall this small board. We had the same and it had a shorted cap onboard. Took a few minutes to locate the bad boy and was repaired. The same daughterboard is > $100 on Aliexpress. No idea why. Confirm the full part # on this board to compare notes. My database shows a -03 and also a -04 version of this daughterboard. No idea on the differences at this time. Try an internet boot of the OS to rule out any local s/w corruption issues.
        • K MI
          MacBook A2485 M1 Max - no sound/video on speakers
          by K MI
          I’m troubleshooting a MacBook Pro 16" A2485 (820-02382, M1 Max) on macOS (Tahoe). Headphones work fine (3.5mm jack + Bluetooth), but internal speakers do not work at all.
          When I try to play any system sound (e.g. afplay /System/Library/Sounds/Glass.aiff), it fails with:
          AudioQueueStart failed ('what')
          Logs from coreaudiod show the Built-In Speaker device trying to start and then failing immediately, e.g.:
          BuiltInSpeakerDevice: starting → IOA2UCDevice::StartIO ... Error: 0xE00002E9 → Underlying device failed to start with error: what
          02-22-2026, 06:32 AM
        • bouch
          unlock macbook air A1932 2019
          by bouch
          hi
          i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
          i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
          i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
          have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
          I need help or information?
          Does anyone have the minat2 activator 1.4 software?
          Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
          Thank yo...
          03-12-2025, 10:14 AM
        • Boardview and Schematic Bot
          Apple MacBook Pro 13 M1 820-02020-A 820-02020 Boardview and Schematic
          Apple MacBook Pro 13 M1 820-02020-A boardview 820-02020 V1.0 Boardview
          Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB
          Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Physical scanning image
          Apple MacBook Pro 13 M1 Late 2020 A2338 820-02020 T668 MLB Location map...
          06-20-2026, 10:11 AM
        • bystry326
          MacBook Air 2019 A1932
          by bystry326
          Hi guys need some help on this Macbook
          History of the fault :
          There has been a some sort of power spike or short on one of those rails PP5V_G3S or PP5V_MAIN_ALSCAM_F . They are connected together via L8570 Inductor with was completely blown away from the board as well as small amount of trace.
          I replaced the inductor and repair the track turned the MacBook on and noticed stray away it was warm . Camera still didn't work at this point so back with multimeter and found the LCD flex cable had a short . Replace with new one and the camera came back to live...
          01-12-2026, 09:43 AM
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
