i have a macbook air a1466 board id 820-00165a no boot no display no chime with fan spin amber to green light clean board i already tried reset pram still not working also flash its bios. no luck can you help me this one.
a1466 macbook no boot
by Sergio KubCould someone help me?
I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
Could it be the BIOS? -
by jheunnei have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
in first image there is 0v out for lcd
https://ibb.co/5XppmpkH
in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
https://ibb.co/fdJkbJs8 -
by No LanHey everyone,
Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise
I've seen what this community can do, so I'm pretty sure you guys can help me out.
Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only... -
by twonk9098I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
This model has the newer trackpad which is not clickable when turned off.
At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but... - Loading...
