My Lenovo Legion Slim 5 Gen 8 was unable to post/boot following a failed BIOS upgrade attempt in Lenovo Vantage. As the upgrade installation assistant was running in Windows, the device blue-screened and has not been able to post since.
I have attempted to restore the device using Crisis Mode by taking the following steps:
The firmware file is found and begins flashing. I have a USB drive with an LED light indicator on it so I can tell it's reading data. The device beeps loudly for a 15-20 minute long sequence which is expected. However, after around 20 minutes have passed, the device stops beeping, does not reboot and remains on a black screen.
I have left the device out overnight as I have re-attempted this numerous times and it never reboots, and never ends up posting. Only the keyboard lights up. I can change the keyboard brightness with FN+Space which indicates some functionality, and FN+R triggers Crisis Mode flash when a USB with the macn.bin file is on it.
When pulling the USB, many log files are generated (in the most recent attempt, 121 files were present). An example of one of two of these logs is below:
File: MACN246B.C1S
File: MACN2406.C1S
This appears to be a pattern for the 121 logs that were present. It indicates the file is found, but failed on flashing for a different address (I do not know what this is indicative of as I am new to this).
Additionally, I also tried downloading the full BIOS dump that I found in this post. I renamed the dump to macn.bin and re-attempted Crisis Mode. However, doing that throws a different error where the device never starts beeping and indicates in the logs that the macn.bin file was present but could not be validated:
Relevant Logs:
Any help / explanation as to why it might be failing to flash at those different addresses or what it means that it appears to be flashing the firmware but then proceeds to never recover would be deeply appreciated
- Identified the crisis recovery file expected name to be macn.bin using this guide
- Downloaded the MACN24WW BIOS installation package from Lenovo's website --> Extracted the installation package --> Renamed the ".fd" file to macn.bin
- Placed the macn.bin file on a USB drive formatted to FAT32 in the GPT partition scheme.
- Powered on the device, pressed FN+R with the USB plugged in, observed the loud beeping for 15-20 minutes.
- Repeated these steps for MACN35WW (latest BIOS revision).
File: MACN246B.C1S
Code:
Find Crisis File [Success] Crisis Process: [Fail], update address 0xFF8AE000 fail
Code:
Find Crisis File [Success] Crisis Process: [Fail], update address 0xFF949000 fail
Relevant Logs:
Find Crisis File: [Fail], validate file fail
