Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
HP DAG7HAMB8F0 rev F NO IMAGE/NO BACKLIGHT internal display but works HDMI
  • nicoar10
    • Dec 2024
    • 21
    • spain
    Hello! In this case I have an HP with motherboard DAG7HAMB8F0 rev F. The laptop powers on and shows video on an external display, but not on the internal screen. There is no image / no backlight.
    I have checked and I do have 3.3 V at the display connector. There is also no short circuit at the display connector. I have checked the 3 V and backlight fuses and they are OK.
    What I can’t understand from this schematic is that I cannot find the backlight boost circuit. According to the schematic, this display works with the same VIN supply, which passes through a fuse and is then labeled “backlight.”
    EDP LINES SHOW NORMAL VALUES TOO
    I FOUND DIGITAL_CLK_L 0.073 SEEMS LOW with lcd connected. If disconnect up more than 0.400.
    I test with know good LCD too.
    Any help is welcome!
  • Vusal
    Senior Tech.
    • Feb 2016
    • 71
    • Azerbaijan
    Now, there's something else. If there's an image in the background on the panel and there's no backlighting, that's another issue.
    If there's no image or light in the background, that's another issue.
    1. If you only want to analyze the backlighting, the panel must have main voltage and LCD_VCC. For backlighting, you need to check VADJ and BLON. VADJ performs scanning, i.e., the pmm signal, while BLON is the enable signal.
    • arkkkk
      Baykunl DRO Digital Readout D80M-3V - TFT LCD no image, backlight works
      by arkkkk
      Hello everyone
      A friend gave me this Baykunl D80 DRO (Digital Readout) he uses for a lathe/milling machine. The LCD stopped working, shows no image or color whatsoever, but the backlight works.
      When you power up, sometimes you can see a brief image but for like 1ms then it goes black. That kinda tells me the LCD is actually good and the issue lies elsewhere.
      The board has:
      • 1x ST STM32F103VET6 Micro-controller
      • 1x RAIO RA8876LN4 LCD controller
      • 1x Winbond W9864G6KH-6 SDRAM
      • 1x Winbond W25Q128JV Serial Flash Memory
      • 1x ATMEL ATMLH834 EEPROM
      • 3x Texas
      01-08-2026, 09:43 AM
    • signal.quest
      Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
      by signal.quest
      I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
      03-17-2024, 10:14 AM
    • zaurus81
      Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
      by zaurus81
      This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
      The board is equipped...
      01-16-2025, 03:54 AM
    • prw07
      A1398 2015 820-00426 No image and display backlight before log in on macOS
      by prw07
      Image and display backlight are present while macOS is load but the display turns off before log in. The laptop is working (hear sounds), but without image and backlight. Internal LCD normal is worked in safe mode also when connect external LCD.
      I think the problem is with the integrated graphics iGPU.
      Is it possible to disable iGPU ?...
      12-19-2023, 11:26 AM
    • webhx
      820-00134-A iMac 27" Late 2015 - No display, backlight works
      by webhx
      Hello
      I received 27" iMac, Late 2015 model that's broken. I don't know what exactly happened but it appears to be unopened and there are no marks indicating prior repair attempts.
      Initially it didn't display anything on the screen and backlight didn't work. Only 2 diagnostic LEDs would light up and 3rd was very faint. I opened it and found F4400 fuse near eDP connector to be blown. Replaced it with a suitable part and backlight came back to life. Unfortunately it still doesn't display anything on the screen. Now I get 4 green diagnostic LEDs.
      I can hear the chime...
      01-29-2023, 11:00 AM
