Macbook Air M1 2020 A2337 - running on reserve battery (without battery)
  • BMCappelletti
    • Nov 2021
    • 196
    • Brasil
    #61
    Welll, made some progress.
    Replaced U5340 with one from a donor board. Now the short on PPCHGR_VDDA is gone.
    Still 5V on the meter, though.
    But also 5V on U5340 pin 5 and 1V on the F5200.
    Back to previous step. 5V and no current drawn, at all. Will replace the ISL again. Have one extra.
    • PITERPENY
      • Jul 2023
      • 491
      • Ukraine
      • microelektronics
      #62
      Sorry for interrupting, but have you tried it with a new battery? It looks like the original problem was a deeply discharged battery or a blown fuse, and if you don't have a battery repair tool, the only option is to replace it!
      • BMCappelletti
        • Nov 2021
        • 196
        • Brasil
        #63
        I don't think this board requires a connected battery to negotiate 20V. At least I don't remember connecting one to it when I first solve the original issue. And I have repaired two or three M1s before and also think I never had to connect it.
        • BMCappelletti
          • Nov 2021
          • 196
          • Brasil
          #64
          Well, it took me some time to try again, cause I got a new job and didn´t have much time for it.
          I replaced U5200 and on the very first try got 20V on the meter. Set it aside as it was dinner time.
          Came bak, connected the meter and power again... back to 5V. Q5230 is glowing hot. I lifted L5230 and the short comes from CHGR_PHASE1. So still issues with the ISL chip? Why did it show 20V and the next try went to 5V again?
          • drlarsen
            MacBook Air M1 A2337 battery/charging issue
            by drlarsen
            Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
            I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
            On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
            After some hours, the battery status did not improve. Restore via DFU did not help.
            I connected the power adapter to a Kill-a-Watt...
            07-17-2025, 02:35 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • brockauly
            Macbook M1 A2337 EMC 3598 weird battery charging problem
            by brockauly
            Hi guys,
            If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
            Then if I unplug the charger and plug it back, it won't charge anymore.
            In the first case, main voltage is regulated at ~12.5V and charges the battery.
            After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
            After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
            I found C520A (2.2µ after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
            02-05-2025, 10:51 AM
          • silver60618
            Macbook Pro A1990 - Battery not detected after connector torn off
            by silver60618
            Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
            Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
            11-12-2025, 06:36 PM
          • manymonsteras
            Macbook Pro - A2251 - No power when battery is connected
            by manymonsteras
            I am hoping to get some advice. I have a 2020 13" Macbook Pro - A2251 that wouldn't turn on. I have done lots of electronics repair in the past but never on Macbooks. I have had this laptop sitting around and I finally decided to take a look at it and see if I could spring some life into it.
            First, it wouldn't boot up at all. I did a DFU restore and managed to get it to power on. Did a full restore but the battery was dead and wouldn't charge. I put in a new battery in it but now it won't boot up when the new battery is connected. I ordered a second new battery just in case,...
            11-20-2025, 09:42 PM
