Macbook Air M1 2020 A2337 - running on reserve battery (without battery)
  • BMCappelletti
    • Nov 2021
    • 196
    • Brasil
    Hi everyone.
    Quick backgrounhd story: Macbook came to me stuck on 5V. According to repair.wiki I could have an issue on L7800. Indeed it was not passing signal through. And I did have an issue on PP5V_BSTLQ_VOUT_SPMU line. I found a cracked cap (C7800) and replaced both failing components.
    Now it negotiates 20V and the computer starts, but I receive the message "you are now running on reserve battery power", as shown on the attached picture. It happens with or without a battery connected. So I am discarding a battery issue, for now (it may be bad, but I will only know for sure when this message stops appearing without a connected battery).
    The battery icon has no power icon on it or anything else.
    I cannot reinstall system, cause it prevents me from doing it with a low power battery.
    I've searched for this error and all I could find were people with the legitimate message showing up, when indeed battery was low.
    Any clue on where I should check for errors first:
    Thanx.
  • mon2
    • 15625
    What is the voltage to ground on:
    CHGR_AUX_DET ; used to detect the power adapter
    C5220 ; test each side
    R5275 ; test each side
    L5230
    • BMCappelletti
      • Nov 2021
      • 196
      • Brasil
      L5230
      C5220 20V each side
      R5275 5V each side
      L5230
      fluctuating, from 4.x V to 11V
      • mon2
        • 15625
        What is the voltage of CHGR_AUX_DET?
        Remove all power. Disconnect the battery. Review the dual mosfets that surround L5230.
        Measure the resistance for each mosfet:
        source / drain
        source / gate
        gate / drain
        Note again that there are 2 such mosfets inside each package. You may have to be creative to measure their tiny stub contacts. We use a single strand of wire from old IDE ribbon cables (PC days). Wrap this single delicate wire around a meter probe to make the wire tip a probe.
        Testing if the mosfets are ok. Each should be hundreds of k ohms or higher else the dual mosfet may be defective.
        • BMCappelletti
          • Nov 2021
          • 196
          • Brasil
          source / drain
          source / gate
          gate / drain
          Used two needles, connected to alligator clips. Doesn't seem to have issues. I could not find shorts. Either OL or on the hundreds ohms.
          For Q5240 pin 9 I used test point PPS5216. For Q5230 pin 10 I used test point PPS215.
          For diagnosing this Macbook I used the penultimate case on this wiki: https://old.repair.wiki/w/A2337_2020_MacBook_Air
          I had 0,03A and meter was cycling. And checking that information on the wiki I found the cracked cap and blown fuse. But I don't really get what is the PMIC they mention on it. Maybe there is a clue on it?
          • mon2
            • 15625
            Post the measurements.
            • BMCappelletti
              • Nov 2021
              • 196
              • Brasil
              Guess it is all there.
              Q5240
              Pins 2 3 4
              to pin 1 - open
              to 8 - open
              to 5 6 7 - 657 ohms
              to 9 (PPS216) - 689 ohms
              Pin 1
              to 5 6 7 - 1030 ohms
              to 8 - open
              to 9 - 110 ohms, and going up
              Pins 5 6 7
              to 8 - open
              to 9 - open
              Pin 8 to 9 - open
              Q5230
              Pins 7 6 5
              to pin 8 - 587 ohms
              to pins 2 3 4 - open
              to pin 1 - open
              to pin 9 - open
              Pin 8
              to 2 3 4 - open
              to 1 - open
              to 9 - open
              to 5 6 7 - 588 ohms
              Pin 2 3 4
              to 1 - open
              to 9 - 686 ohms
              • mon2
                • 15625
                The measurements are in ohms? Not k ohms? Confirm if the meter face shows 'k' ohms. If in ohms, these parts are defective. Suggest to flux (carefully) and remove them for another measurement check while the parts are removed from the board. Share the measurements again.
                • BMCappelletti
                  • Nov 2021
                  • 196
                  • Brasil
                  Yes, ohms. Not k ohms.
                  Measurements pretty much the same from a donor board I have here. Although I have to ideia what is the issue with that one, cause I only bought it for parts.
                  • mon2
                    • 15625
                    Perhaps the measurements are being influenced by other parts on the board.
                    Disconnect the battery. Power up and measure the voltage to ground on:
                    F5200
                    What is the voltage? Is it stable?
                    • BMCappelletti
                      • Nov 2021
                      • 196
                      • Brasil
                      F5200
                      Stable 12.3V.
                      • mon2
                        • 15625
                        Then the mosfets are ok as they are switching to buck / boost regulate the 20v or 5v input.
                        Remove all power. Meter in resistance mode. Test the resistance across the battery mosfet @ Q5265.
                        Same measurements.
                        • BMCappelletti
                          • Nov 2021
                          • 196
                          • Brasil
                          Same measurements.
                          So... pins 1 2 and 3 (PPVBAT_AON_CHGR_R)
                          to 4 (CHGR_BGATE) - 1.1 MOhms
                          to 5 (PPVBAT_AON_CONN) - 2.2 MOhms
                          Pin 4 to 5 - 0.94 MOhms
                          • mon2
                            • 15625
                            Looks ok.
                            Does your battery have a voltage at this time? Connect the battery. Connect the power adapter. What is the voltage to ground at the fuse F5200?
                            • BMCappelletti
                              • Nov 2021
                              • 196
                              • Brasil
                              Looks ok.
                              12.3V. As I have the board on the machine, for better connecting the battery, I measured on the same points from F5200, which are PPUS_AON (measured on FP800) and PPVBAT_AON_CHGR_REG, measured on C5258.
                              • mon2
                                • 15625
                                Connect the power adapter. What is the voltage to ground of CHGR_AUX_DET? Don't believe you have posted this measurement.
                                Disconnect the power adapter, what is the voltage @ F5200? This will be the power path from the battery only.
                                • BMCappelletti
                                  • Nov 2021
                                  • 196
                                  • Brasil
                                  5V on CHGR_AUX_DET, measured on R5215 and R5216. R5215 has 20V on the other side. R5216 nothing on the other side. With and without battery.
                                  F5200 is 12.3V with power adapter and goes down when disconnecting power. If testing the same with the battery connected, it is 12.3V and changes to 8.4V for a second, before going down.
                                  • mon2
                                    • 15625
                                    What is the resistance across C5260? This is to measure the full path resistance of the battery charge leg of the circuit.
                                    • BMCappelletti
                                      • Nov 2021
                                      • 196
                                      • Brasil
                                      1.2 ohms accross that cap.
                                      But... check these pictures. Two are from the board I am working on. The third is from a donor board.
                                      • mon2
                                        • 15625
                                        The top side is chipped but check is you have at least 12v3 at the fuse. If yes, for now, ignore.
                                        From your linked wiki…
                                        ~ 12.28-12.35 = Possibly normal, however may indicate a communication issue between the SOC and one of the PMICs or between the SOC and other components as well as corrupt firmware.
                                        Try a DFU.
                                        • drlarsen
                                          MacBook Air M1 A2337 battery/charging issue
                                          by drlarsen
                                          Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                                          I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                                          On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                                          After some hours, the battery status did not improve. Restore via DFU did not help.
                                          I connected the power adapter to a Kill-a-Watt...
                                          07-17-2025, 02:35 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • brockauly
                                          Macbook M1 A2337 EMC 3598 weird battery charging problem
                                          by brockauly
                                          Hi guys,
                                          If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
                                          Then if I unplug the charger and plug it back, it won't charge anymore.
                                          In the first case, main voltage is regulated at ~12.5V and charges the battery.
                                          After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
                                          After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
                                          I found C520A (2.2µ after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
                                          02-05-2025, 10:51 AM
                                        • silver60618
                                          Macbook Pro A1990 - Battery not detected after connector torn off
                                          by silver60618
                                          Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
                                          Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
                                          11-12-2025, 06:36 PM
                                        • manymonsteras
                                          Macbook Pro - A2251 - No power when battery is connected
                                          by manymonsteras
                                          I am hoping to get some advice. I have a 2020 13" Macbook Pro - A2251 that wouldn't turn on. I have done lots of electronics repair in the past but never on Macbooks. I have had this laptop sitting around and I finally decided to take a look at it and see if I could spring some life into it.
                                          First, it wouldn't boot up at all. I did a DFU restore and managed to get it to power on. Did a full restore but the battery was dead and wouldn't charge. I put in a new battery in it but now it won't boot up when the new battery is connected. I ordered a second new battery just in case,...
                                          11-20-2025, 09:42 PM
