Toshiba c660D-16L power but doesnt boot
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by meraklinetxHello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by dicky96Hi guys
I have this Toshiba Lifebook A514
When I got it the battery was flat, orange Battery LED on. When you press the power button, with PSU attached, the blue LED by the button (and the one at the front of the laptop) come on, but no fans no signs of life... Nada.
I left it overnight on the charger and the battery did charge - no more orange light and the laptop will now power on without the PSU - but still no signs of life
If you hold the power button in, it will not power down again, you have to switch off power to the PSU
If you do... - Loading...
