A1706 820-00239 Looping on all ports
  • Markus Plutka
    • Nov 2024
    • 3
    bought a liquid damaged device and am trying to get it fixed as a hobby.
    U7600 was shorted and got replaced. Now all ports power cycle after 2 seconds and none negotiates 20 Volts. Ldo bmc reaches 1.1 v on all before the cycle begins again. PP3v3_G3H is at 3.3v.
    i checked this sequence https://logi.wiki/index.php/CD3215_Bootup_Sequence and get the correct voltages for step 10 (SMBUS_SMC_4_G3H_SCL and SMBUS_SMC_4_G3H_SDA) with 3.4 v each. I don’t use an original charger but one from my Huawey notebook with 65 w. Could this be the cause? Thanks a lot.
  • Markus Plutka
    • Nov 2024
    • 3
    Doesn’t work even with an original charger. What is curios, one port only draws current if the cable is plugged in in a certain way. If I turn it around , the port is dead. This isn’t like this with the other 3 ports
    • mon2
      • Dec 2019
      • 14673
      Inspect the paddle board with the USB connector for possible damage.
      Suggest to use a USB-C meter or the 'Tail tester' by Qianli which is also able to offer diode mode readings of the same batch of signals.
      If you see the port going dark with the meter then there is a short on that side of the USB-C blade. That PD controller is also a suspect. As per the CD3215 articles on logiwiki- check each and every LDO rail on the PD controller.
      What is the voltage of PPBUS_G3H to ground? Remove the fuse on that rail and measure again if out of spec here.
      • DynaxSC
        GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
        by DynaxSC
        I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
        There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
        The board is generally working now, all PCIe ports are working, Windows installs normally.
        However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
        The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
        03-10-2025, 12:27 PM
        Lenovo ThinkPad P43s Mobile workstation P Specification for Upgrade or Repair
        This specification for the Lenovo ThinkPad P43s Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P43s boardview and P43s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
        09-06-2024, 09:40 AM
