a1278 no image with lcd light
  • jheunne
    • Sep 2022
    • 83
    • philippines
    • games, basketball gadgets movies food
    hi there i have a macbook a1278 core i7 board 820-2396a this board actually works fine i tried to remove the board to transfer it on other frame. when i turned it on screen has light but no image on it now i put it back to its original frame the same issue no image display but it has lcd lights on it. also tried memory change still the same. can you help me for this one.
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • hartleyhare5
    Samsung QE65Q9FN — BN44-00944A (65A board) MOSFET failure (relay clicking on one connect) — advice before power-up
    by hartleyhare5
    Post body:
    I'm working on my Samsung QE65Q9FN (65" Q9FN QLED, European model) with relay clicking and no picture. The power supply board in the display itself is the BN44-00944A, known on the board itself as the 65A board (silk-screened designation). There is also a second board, the 65B, which looks identical but is only partly populated for the LED power.
    Symptom: Continuous relay clicking on the one connect — TV will not start up, no picture. However the standby LED is on constantly — so the standby supply rail appears to be alive and the...
    03-26-2026, 03:47 AM
  • canadaboy25
    Panasonic TC-P54VT25 No image. A or D board?
    by canadaboy25
    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
    01-17-2021, 01:06 AM
  • tuner2000i
    Philips 65PUS8518/12 distorted image after main board replacement
    by tuner2000i
    hello everyone,
    I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
    The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
    07-15-2025, 01:15 PM
