Macbook Pro M1 A2338 13"
  • Orux
    • Sep 2025
    • 26
    • Austria
    So i got further now. I sucessfully removed the Icloud Lock from the Macbook. Now it is Installed new. But Everything works but also no Screen wich is no surprise because the Rail is down. What i noticed is that the Battery now is Charging and also having 100% Health. But. It does not boot without a plugged Charger. Is the Problem because it says, no screen no boot?!
    Greetings Tom
    • mon2
      • 14792
      Test with an external display using an usb to hdmi dongle. Do you have video?
      • Orux
        • Sep 2025
        • 26
        • Austria
        Yes Having normal Display. What i recognized is following.
        Battery Charges normal and Macbook runs on Battery. If i power down with Charger and then Open Display or pushing any Button. Macbook starts. If i power down and let it completley shut off then disconnect Charger and hit a Button or open the Display. Macbook Starts with Battery.
        When i let it Sit a while without Charger it does not Start. So The Battery is present but is somehow not connected to the Mainrail to fire it up. And also Screen is no backlight. But rest of the Macbook is working normal.
        • Orux
          • Sep 2025
          • 26
          • Austria
          Hmmm can it be that the little board wich connects the Cells is defect? i Measure not really any Volts on the Points there. So it could be Possible and i can be a little bit Lucky that the Board is defect?! Maybe try to measure the good M1 wich i have here.
          • Orux
            • Sep 2025
            • 26
            • Austria
            I made Progress...... The Battery works fine.... As long as i let the Macbook open i can Power down and boot it up normal. But when i close the Screen its completley disconnected from the Battery. Also when i unplug the Display connector.... So there must be anything wich is shorting it again....
            • Orux
              • Sep 2025
              • 26
              • Austria
              #26
              will a 2018 macbook logic board work as a donor board to repair the backlight caps?!
              • Orux
                • Sep 2025
                • 26
                • Austria
                #27
                mon2 Hey i now have a Board wich can i use for parts. The Board does not start. I testet it but i can now try to make Measurements again. At the Display connector there are many difference........ Those Caps around having higher Ohm than on my board. Is there a List wich Cap should have the amount of ohms?
                Greetings. Tom
                • Orux
                  • Sep 2025
                  • 26
                  • Austria
                  #28
                  OK plugged the Board in the Working Mac with the Working Screen and what should i say. The Screen works there with the Board. So the Screen was the whole diagnosing Problem. Can u fix a Screen or is the Backlight dead? What if i try to open the Inverter board?
                  • mon2
                    • 14792
                    Hey! Travelling through Asia so out of touch. Heat is just unbearable here. Yes, the backlight is worth the effort to repair. We have done this and our case was due to….a shorted cap. Post pics of the inverter board / T-con after opening. AliExpress may offer a working replacement for the same.
                    • Orux
                      • Sep 2025
                      • 26
                      • Austria
                      #30
                      The Tcon Board is dead. To many Shorts on it and i dont know wich caps because no boardview. So i only can replace the Tcon board? how?
                      • mon2
                        • 14792
                        Inject 1 volt onto shorted line. The part will smoke out under the stress.
                        • bigbadbios
                          a2338 2020 Macbook Pro liquid damaged won't turn on- weird issue
                          by bigbadbios
                          I am trying to fix this liquid damaged 2020 Macbook pro and I noticed something weird.
                          When I push on/around the renesas 501cr0b IC, which appears to be a clock generator/ multiplier, If I apply lot of pressure, the device will reach 19.9 volts and seems to be trying to work.
                          I have thoroughly reflowed that area and completely removed that chip (there was some liquid stain in that area) but no help. I have just 5v 0a unless I apply the pressure.
                          Your help is GREATLY appreciated. Thanks!
                          08-18-2024, 05:47 PM
                        • sdogs
                          macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                          by sdogs
                          Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                          First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                          I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                          06-27-2025, 01:58 PM
                        • sdogs
                          by sdogs
                          06-27-2025, 11:26 AM
                        • madjid911
                          A2338 MACBOOK PRO NO POWER
                          by madjid911
                          Hello, can you help me solve this problem: I have a macbook pro A2338 which does not start, motherboard 829-02773-A, no oxidation, the usbc is stuck at 5v it does not trigger the 20v, here are the measurements:
                          PPBUS_AON varied 11V70 12V5
                          PPVBUS_USBC1 5V
                          PP5V_S2_UPC 0V (1mégaohms)
                          PP3V3_UPC1_LD0 3V45
                          PP1V5_UPCA_LDO_CORE 1V5
                          PP3V3_S2 0V
                          PP1V8_AON 0V
                          PP3V8_AON 0V 1ohm short
                          I injected 2v I have 5a but I can't find any heating on the motherboard, I tried in several places of the short but still the same.
                          Do you...
                          09-18-2025, 11:07 AM
                        • Schluchti45
                          MacBook Pro M2 A2338 with PowerSupply it is running, "X" on the battery symbol and FAN is running permanently
                          by Schluchti45
                          I have a MacBook Pro A2338 M2. The MacBook runs with the power supply unit. The fan runs permanently and the battery shows the message “Service recommended”.
                          I have already replaced the battery with a new one, but this has not helped. I have also tried DFU and the system restored the error remains the same.
                          Do any of you have any ideas where I could look or how I should proceed here?...
                          10-22-2024, 11:42 AM
