OLD model macbook pro intel , problems
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    I guys , so i received a macbook pro old model with intel dual core 2.40ghz
    board model 820-2249-A with power board model 820-2273-A A1260
    Well client arrived mentioning , it was no more charging or lighthing up the magsafe connector but was working with the battery until battery dies (then no more glory ) also we couldn't carry out test to know the veracity of his history .
    cheked the charger and its ok and working. so we have ordered the power board , since its usual in this machine to damage powerboard.
    Board arrived today we have made install .. but no glory no light on magsafe and also not turning on or even charging battery , i disassembly the entire board with power connector just connect everything outside and noticed that both powerboard get hot on a bloody resistor , (470 is what he have marked on it R6907 to be more exact (this on powerboard ) no my doubts is (was this board damaged as well (bought a from a supplyer from france , with 6 month warranty indicating was working 100% perfect or might be my main board damaging this ?im stucked and reallly would like to know what the hell is going on and if anyone ever had such problem ?btw if anyone can share this schematic would be very nice
  • dellxps15
    • Feb 2014
    • 1585
    • italy
    Re: OLD model macbook pro intel , problems
    hi, im getting mad with macbook from long time. its is a white model ?
    edit: seen it is a 15 inch.
    disconnect cable from power board to mainboard and see if it get still hot.
    • highpulse
      i hate HP
      • May 2013
      • 1489
      • portugal
      no it dont , it only warm up when the yellow big flat cable is attached to mainboard , for what i could figure , this happen due to a main IC on the logic board , (it works with battery ) but with DC not . so now i must find were the hell is that IC (mentioned by a friend that repair macs , he says its often .
      Its a 2008 model , alluminium (like the old g4 type but intel .
      EDIT: client says it didnt work both way (cheking battery status its a midle charger , so not working in any way .
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Rezendes
        Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
        by Rezendes
        Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
        I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
        The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
        05-10-2024, 02:18 PM
      • tony359
        2007 Macbook logic board fault
        by tony359
        Good day all,
        I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
        Once the fan was swapped, I installed an OS and it worked fine.
        The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
        Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
        If I see that right, I have missed VCORE on L7100 (page 59)....
        01-23-2025, 06:59 AM
      • Stephen
        A2681 MacBook Air 13" Short on board question.
        by Stephen
        The board turned on before hand but it was liquid damaged, I was able to fix some of the issue with the board, but the battery wasn't charging and so we replaced a few caps and still no luck, swapped out 4 batteries to see if the batteries were bad, and they were all good batteries after final testing. I checked for voltage at PPBUS_AON and no voltage was present which was odd, so I went ahead and replaced U5200 with a new chip since this has something to do with the charging issue and power issue. Replaced but no life still, so went ahead and look for shorts and found an odd area that is shorted...
        12-31-2024, 01:16 PM
