HP G6 core i5 charging problem
  • salawayon
    • Nov 2012
    • 568
    • philippines
    Mobo: DA0R12
    BIOS: F.04
    this unit works good on battery. With charger inserted there's no light at charging port. Tried already replacing the charging pin assembly.
    Infos:
    PQ48 (85U03GH):
    Pin 1=0v, 2=19.9vdc, 3=0.317v, 4=19.9v
    +VH28 @PR104 = 30.13V
    PU2:
    Pin 13=12.46v, 14=2.28v, 16=16.5v, 17=30.12v, 18=15.1v, 20=19.9v
    PQ17:
    pin 1=0v, 2=0.581v, 3=1.712v
    PQ18:
    pin 1=0v, 2=1.631v, 3=1.6v
    U22 = no voltages at all pins...
    Help badly needed...
    Thanks..
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Re: HP G6 core i5 charging problem
    PU9 ,pin 9 ?
    • aanan
      • Dec 2010
      • 222
      • India
      schematic ?
      • cyberhack
        • Feb 2013
        • 466
        • Uk
        Here
        • salawayon
          • Nov 2012
          • 568
          • philippines
          @PU9:
          pin1=19.92v, 6=5.78v, 9=3.223v, 12=5.82v, 15=5.84v...
          • cyberhack
            • Feb 2013
            • 466
            • Uk
            replace pq48,as all the voltages are correct
            • salawayon
              • Nov 2012
              • 568
              • philippines
              I've done that already.. PQ48 pin1=0 and pin3=0.317v... i compared with a good unit but with R13 version, pq48 pin1=28v and pin3=19v...
              • salawayon
                • Nov 2012
                • 568
                • philippines
                Is this problem might be related to bios problem even the unit is working with battery only?
                • dycc
                  Vision
                  • Nov 2011
                  • 624
                  • Côte d'Ivoire
                  Not the bios
                  to be sure that you have no short in the pcb , remove pq18 and check if you got 19v on pq48 pin3
                  if you got voltage without pq18 assume the problem must be between pq18 and pq17 (very rare)
                  normally when it working acin must be 3v ,pq17 behave like a short and acok# = 0v
                  pq18 then behave like an open circuit and you got vh28 (28v) on pq48 pin 1
                  • lezsimply
                    The Wanderer
                    • 645
                    • Philippines
                    @salawayon
                    could you please upload your bios file? we have same laptop. mine got no light on charging port yet voltages are ok. no short. might be bios problem. thanks
                    • lezsimply
                      The Wanderer
                      • 645
                      • Philippines
                      anyone got bios file for this laptop?
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        Please upload your dump.
                        • lezsimply
                          The Wanderer
                          • 645
                          • Philippines
                          Here it is atsio...
                          • salawayon
                            • Nov 2012
                            • 568
                            • philippines
                            Removed pq18, PQ48 is now normal. when unit being switch on, light at charging port flickers only...
                            • salawayon
                              • Nov 2012
                              • 568
                              • philippines
                              Replaced pq17 and pq18 with same result, no output at pq48...
                              • dycc
                                Vision
                                • Nov 2011
                                • 624
                                • Côte d'Ivoire
                                Post back all voltage(first post) without pq18
                                • Scoff
                                  HP Probook 470 G4 - Power and Charging Problem
                                  by Scoff
                                  Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                                  Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                                  07-03-2023, 09:28 AM
                                • ahmarzo
                                  Hp laptop charging problem
                                  by ahmarzo
                                  Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
                                  Charging ic is bq737 with voltages on pin no
                                  1&2 -19v
                                  34&5 -0v
                                  6 -2.56 v
                                  7- 0v
                                  8&9 -3.15v
                                  10 -0v
                                  11 -0.18v
                                  12 & 13 -13v
                                  14&15 -0v
                                  16 -6v
                                  17;18&19 -13v
                                  20 - 19v
                                  Voltages on battery connector are
                                  1&2. -13v
                                  3&4 -3.14 v
                                  5&6 -0v
                                  8&9 are ground...
                                  03-20-2025, 05:13 AM
                                • roman728
                                  Lenovo E15 / NM-C421 Charging Problem
                                  by roman728
                                  Hello guys,
                                  I have a problem with charging circuit in this laptop. Unit came with no power at all (USB-C meter was cycling turning off and on). I discovered that when I unplug battery laptop works on charger only. So after few measurements I found shorted 1st dual mosfet AONY36324. Unfortunately i was not able to order exact this one, so i ordered AONY36352 which i believe is the similar one. Now the problem is, when i connect battery and charger USB-C meter is not cycling anymore, it starts charging (reading 20V@2,7A) but after few seconds it is going down to 20V@0,20A and laptop...
                                  02-20-2024, 03:40 AM
                                • kity92
                                  Edifier x3 Earbuds Blue Light Problem (Charging Problem)
                                  by kity92
                                  I ordered a Bluetooth earbud one and half year ago, and right earbud broke. The light that should have been red when you put it in the charging case started to turn blue continuously(which means earbud is not charging) and after 1 week the earbud completely died. I disassembled right earbud because the warranty finished. I diagnosed the battery was dead, so I charged it with TP4056 and revived the battery.
                                  Right earbud is working now but I still didn't solve charging problem. I checked the charging box with a multimeter. There is 5V. I checked the headphone pins and they are working....
                                  01-13-2022, 01:49 PM
                                • delphi_firebird
                                  Toshiba Qosmio X755 Charging problem
                                  by delphi_firebird
                                  Hello Guys,
                                  I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
                                  - When battery is unplugged i works without any problem.
                                  - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
                                  - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
                                  Can you help me diagnose the problem? I have attached...
                                  10-16-2023, 03:04 AM
